A header wizard - Page 6
Page 6 of 6 FirstFirst ... 23456
Results 201 to 230 of 230
Thread: A header wizard
  1. #201
    Dec 2008
    Los Angeles, CA
    Smile
    This project is GREAT! I look forward to using it.
    I vote #1.
    I'm thanking you in advance right now.
  2. #202
    Hi, Paul
    There's a very important button Missing ....
    The " DONATE " button ...
    Worth it ... I Think !
  3. #203
    Jumping in in the middle here....
    I definitely vote for #1. The other two consumes more codespace and takes longer to execute. The execution time may not matter much but saving codespace is good.
    A benefit of #2 (and #3) though is that you could include comments on a bit to bit basis which makes it easier to see what each bit does.
    Feb 2010
    USA, New England
    Hello,
    Alas, it will use #1 and #3... Users will have the choice. Checking the "Use ADC Aliases" box gets the nice and wordy #3. Leaving it unchecked gives the more terse #1.
    #3 Does use a little more code space but should be more helpful in laying everything out clearly for the less experienced. The aliases also match the the names given for the bits in the datasheet, which could be helpful maybe.
    #1 will be there for the more hardcore or those who need to conserve every byte.
    Anyway, it became clear to me that there is no way around doing my homework. I'm going through every PIC that PBP supports, getting the datasheet, and logging the ADC configuration bits and registers into a spreadsheet. I started with the 10F202 and am working my way down the list, and I'm roughly a quarter of the way through. Here's some interesting numbers:
    -The header wizard identifies 394 PIC microcontrollers supported by PBP. I've gotten my data for 101 of them so far.
    -Of those 101, 53 have built-in ADCs.
    -Of those 53, there are 15 different combinations of ADC setups. Two of those combinations will set up the ADCs on 24 different PICs while five are unique to a single PIC.
    -There really appears to be only 2 or 3 general ways of setting up the ADC (with a couple of unique outliers), primary differences being the number of channels.
    -So far, there are 35 different ADC register bits. (I.e., ANS0, PCFG0, CHS0, etc.)
    Ok, so maybe they're not really all that interesting...8^) But I'm seeing some distinct patterns showing up that will make implementing the Header Wizard's code a little easier.
    My guess is that it will take me another 3 or 4 days to finish gathering the data then another couple of days to implement it in code. So my target is to have a new version posted for next weekend, that will contain all of the bug fixes from the last one and add the ADC configuration.
    Best Regards,
    Paul
  5. #205
    Hi Paul,
    Just curious, are you using the *.device file for anything.
  6. #206
    Aug 2010
    Maryland, USA
    @Paul, I do find that very intresting. I am wondering, if you do this through google docs, the spreedsheet could be worked on by more people. I am guessing the information you need will be needed for each feature you want to add. Thats a huge volume of "homework". Or maybe share the format you need it in and we can work on other areas for you.
    As a side note, you are gonna be Jedi master of "PIC" data when you are done reading all those datasheets, or just jelly brain.
    -Bert
  7. #207
    Feb 2010
    USA, New England
    Hi Paul,
    Hello Dave,
    No, just the MPASM *.INC files What's a "*.device" file?
    Best Regards,
    Paul
  8. #208
    Walter Told us about them here
    http://www.picbasic.co.uk/forum/show...3897#post93897
    Might be just as easy the way you are going though...
  9. #209
    Feb 2010
    USA, New England
    Hi Bert,
    Thanks for the suggestion, but in this case at least I'm going to continue to plod through on my own as it is an excellent tool for expanding my own understanding. Plus I'll be completing my collection of PBP-capable datasheets--I'm gonna have the whole set!
    Interestingly, the spreadsheet becomes a potential configuration file that would obviate the need to parse the .INC files at all...! Not sure I want to go there or not.
    As far as becoming a configuration Jedi, well I'd call that a benefit!
    Best Regards,
    Paul
  10. #210
    Feb 2010
    USA, New England
    Wow, I should have looked at that closer before. I might take that route. Thanks for making me take a second look!
    Best Regards,
    Paul
  11. #211
    Sep 2010
    Default Hi all!
    Greetings to all! Here there was a speech about program ProtonHeaderMaker.
    I have written this program. But I had difficulties with series PIC18 as I am not strongly familiar with it. I have plans in the future to copy this program. It is my first rather large project. Also, I by analogy tried to write the program and for PBP. I will not spread it, as it - in Russian. It is the crude project as I could not be engaged simultaneously in both projects. Probably, it is useful to someone.
    I try to develop picbasic in Russia, therefore have written this program. It is difficult to buy licence compiler PBP from us or Proton.
    I placed this file on "depositfiles" only because on my site to download a file, it is necessary to be registered, and it is inconvenient to people not from Russia. Here the reference for direct downloading:
    protonheadermaker here
  12. #212
    Very Nice. Great job Slazonger. Thanks for sharing that with us! What programming language did you use?
    Thanks again,
    Walter
    http://www.scalerobotics.com
  13. #213
    Sep 2010
    Default You are welcome!
    I'm use delphi. I have some ideas for this program - for example, include pdu coder/decoder e.t.c. Thanks for interesting for my program.
  14. #214
    Feb 2010
    USA, New England
    Quote Originally Posted by Slazonger View Post
    Hello Slazonger,
    I love Delphi! Are you willing to share your source code?
    Best Regards,
    Paul
  15. #215
    Sep 2010
    Default i'm not assured
    I love Delphi two! But my source code is raw. I'm not professional programmer. And what for to you a code? May be, when I will complete, the source code will be shared, but I am not assured...
  16. #216
    Feb 2010
    USA, New England
    Hello Slazonger,
    I am working on a roughly similar sort of program for the PICBASIC Pro compiler, mostly for fun. It would be interesting to see another person's way of approaching some of the problems.
    I've learned most of my programming by reading books and practicing. I do get paid to program, but mostly because I work in a very specialized industry. If there is anything I can do to to help with your program let me know--I talk to very few Delphi programmers. I will make the source code for my program freely available in about a week.
    Best Regards,
    Paul
  17. #217
    Hey Bert,
    Something more for you to play with.
    http://wiz.mackrackit.cambs.net/
    I am glad Paul is doing one that actually works.
  18. #218
    Sep 2010
    I, as well as you, studied delphi a trial and error method, looking periodically in books. Don't misunderstand, but I don't want to spread source code from the left unfinished program. This program was developed only for two languages - Russian and English, and contains some decisions to which I guessed itself, and also the lines containing Russian words. I consider that this code isn't optimum and isn't practical. It will be simply a shame to me with it. And I want to correct it taking into account many factors. Also GUI leaves much to be desired. While the program is accessible in a network to users. I wrote it to lift interest of the Russian users to PICbasic. But, as I have already written, it is difficult to find a place where it is possible to find PBP or Proton in Russia. All know pleasure which you test at use license software. Here with it it is difficult and expensive if to buy abroad.
    Simply, get acquainted with carried out functions. If there are questions, write [email protected]
  19. #219
    Feb 2010
    USA, New England
    Default Quick Update
    Hello All,
    Just wanted to let you all know that I've been working diligently on the header wizard. I've had to effectively re-write the whole thing. I also wrote a utility that parses the various files (dev, inc, and some spreadsheets I made) to create a single text configuration file. This way the app won't have to depend on files from anywhere else, but can easily be updated as new chips are added.
    On the down side, my self-imposed deadline for having a new beta for the weekend is going to slip. I've got some actual work-work (the kind that pays bills) with a hard deadline coming up.
    On the bright side, I really have been working at this project obsessively. The time I've spent reading datasheets and trolling through the inc and dev files will pay off as the project is expanded.
    So I'll figure another week. Don't hesitate to harass (gently) if I go too long without posting something...
    Best Regards,
    Paul
  20. #220
    That sounds like the BRIGHT side!!!
  21. #221
    Feb 2010
    USA, New England
    Default Yet Another Update...
    I've been spending my free moments working on this application. I think I've gotten it basically working (at least for some basic PBP defines, pull-ups, port latches and states, and now the ADC) and I'm doing some debugging and prettying it up a little. It detects if comparators and usarts are present but doesn't do any of those configurations yet.
    But, I'm gonna take the rest of the night off...8^) Just wanted to let you know it is still active and moving forward. Possibly Wednesday for the next beta.
    Best Regards,
    Paul
  22. #222
    Thanks again Paul.
    I am looking forward to it.
  23. #223
    Feb 2010
    USA, New England
    Default PBP Header Wizard v0.1, Build #5
    Hi All,
    Got the new version for you to try out (attached).
    Incidentally, from now on I'll just keep updating this file with the latest version.
    There are now two files within the zip file. Jut unzip these to the same folder. No paths to MPASM or PBP are required. It will create an ini file (again in that same folder) that currently just retains the last PIC selected.
    If you've followed the thread this far you should be able to figure out how to work it. There are extra tabs that appear (Comparator, USART, etc.) that don't do anything yet other than appear when appropriate for the selected PIC. The output is rough but accurate, I believe...
    Please let me know any errors, bugs, problems, or inconsistencies, you run into. I'll work on any of these that show up over the next few days then dive back into comparator setup.
    Best Regards,
    Paul
    Very impressive Paul ... and I am still playing...
    And you thought you wouldn't have a new version out till Wednesday!
  25. #225
    Very nice Paul!!!
    Just a note for when you work on the comparator setup.
    You said the comparator did not do anything. It changes the ADC to digital.
  26. #226
    Feb 2010
    USA, New England
    Okay you got me there. The checkboxes for setting ADC and Comparator ports to digital are linked (because you might have one but not the other). If you check one the other is also checked.
    Details, details...
    Best Regards,
    Paul
  27. #227
    Feb 2010
    USA, New England
    Of course the original target was a week and a half ago...
    Best Regards,
    Paul
  28. #228
    Sep 2005
    France
    Default Re: A header wizard
    No news for the header wizard ?
    And for the Darrel "Fonctioning Configurator" too ?
    Aug 2010
    Maryland, USA
    Quote Originally Posted by harryweb View Post
    This may be my fault. I offered to help Paul find some information, then got really busy and didn't finish my side of the task. Sorry Paul and sorry all.
    I have not forgot about it, and will provide him the information if he is still willing to continue this project.
    -Bert
  30. #230
    Feb 2010
    USA, New England
    harryweb, thanks for asking and bringing this up again.
    Bert, you're a heckufa standup guy to try to take some blame. But you've earned none.
    I was pretty pleased with the last beta. Then I actually tried using it on a new applications and is absolutely stunk. I got discouraged, and things started getting busy at work again (thank goodness for that). I'll take a fresh look at the code over the next couple of days and come up with a plan.
    As far as what Darrel was alluding to I have no idea--maybe the fact that he's working for MELabs now (hooray!) was it?
    Best Regards,
    Paul
