A header wizard - Page 5
Results 161 to 200 of 230
Thread: A header wizard
Threaded View
  1. #19
    Hi Paul. Thanks for the new version.
    Please have a look at the attached picture. It has some garbage under File Utility menus.
    Also when starting the application it askes fo the Microchip directory.
    a) since it is by default installed in a known place, can this be autmated?
    b) the window that request to manually find the directory is at the back ground and not visible.
    And it then assumes that my PBP is at c:\pbp
    If I have my PBP in a different place, say c:\pbp243 it gives an error message for MPASM not found!
    After the error messages if I set the paths in Utility/Settings menu, all are OK after.
    In ADC tab, if All Analog Ports to Digital is checked, then there is no point in Configure Built in ADC. An being in the ADC, it does not set the ADCON0/ADCON1 registers. (I tested the 16F887)
    Can you add also a PWM tab?
    Now this is a reminder if possible to add in a later version: Timers, Comparators, Interrupts.
    The last note is about the aesthetic ofte windows. Can this be OS based to look more slick and related to the current OS system?
