Help;; eeprom won't read/write beyond address 255
Results 1 to 14 of 14
    This works fine with PBP 2.60a and MPLAB ver 8.53.
    DATA @300, "a","s","c","i","i"
    Dat VAR BYTE
    Index VAR WORD
        FOR Index = 300 TO 304
            READ Index,Dat
            HSEROUT [Dat,13,10]
        NEXT
    Here:
        GOTO Here
    Spits it out as expected in the serial output window, and MPLAB shows all data in the EEPROM view window.
    Of course you need a word size variable for the index pointer when the address is > 255.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2007
    Vancouver, BC, Canada
    hi I bring this thread up because i have trouble compiling eeprom passed the 256 bytes
    chip used 18f2620 it has 1024x8 byte of eeprom
    pbp pro version 2.60a
    mplab ide 8.63
    mpasm v5.39
    microcode studio 4.0.0.0
    so please point out what i did wrong.
    Please help and thank you.
    I have tried both the DATA and EEPROM, both cannot compile more than 256 byte of eeprom
    my code is enclosed.
    '*  Author  : KVLV                                              *
    '*  Notice  : Copyright (c) 2010 VANCOUVER                      *
    '*  Date    : 12/27/2010                                        *
    'chip use 18F2620
    DEFINE LOADER_USED 1 'for bootstrap loader
    define OSC 20
    'define HSER_BAUD 19200  ' on pc side set to 19200 8N1 (8 data bits, no parity bit, 1 stop bit)
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 20h
    INCLUDE "Modedefs.bas"
    L var word
    B var word
    M var word
    temp var word
    'Mask var byte
    X var word  '[5]
    'Y VAR BIT[40]
    C VAR word
    S var byte[5]
    data %00000000, %00000000, %00000000, %00000000, %00000000 'space
    data %00000000, %00000000, %01111001, %00000000, %00000000 '!
    data %00000000, %01110000, %00000000, %01110000, %00000000 'double_quotes
    data %00010100, %01111111, %00010100, %01111111, %00010100 'hash
    data %00010010, %00101010, %01111111, %00101010, %00100100 'dollar_sign
    data %01100010, %01100100, %00001000, %00010011, %00100011 'percent
    data %00110110, %01001001, %01010101, %00100010, %00000101 'ampersand
    data %00000000, %01010000, %01100000, %00000000, %00000000 'apostrophe
    data %00000000, %00011100, %00100010, %01000001, %00000000 'left_parenthesis
    data %00000000, %01000001, %00100010, %00011100, %00000000 'right_parenthesis
    data %00010100, %00001000, %00111110, %00001000, %00010100 'asterisk
    data %00001000, %00001000, %00111110, %00001000, %00001000 'plus
    data %00000000, %00000101, %00000110, %00000000, %00000000 'comma
    data %00001000, %00001000, %00001000, %00001000, %00001000 'minus
    data %00000000, %00000011, %00000011, %00000000, %00000000 'full_stop
    data %00000010, %00000100, %00001000, %00010000, %00100000 'forward_slash
    data %00111110, %01000101, %01001001, %01010001, %00111110 'zero
    data %00000000, %00100001, %01111111, %00000001, %00000000 'one
    data %00100001, %01000011, %01000101, %01001001, %00110001 'two
    data %01000010, %01000001, %01010001, %01101001, %01000110 'three
    data %00001100, %00010100, %00100100, %01111111, %00000100 'four
    data %01110010, %01010001, %01010001, %01010001, %01001110 'five
    data %00011110, %00101001, %01001001, %01001001, %00000110 'six
    data %01000000, %01000111, %01001000, %01010000, %01100000 'seven
    data %00110110, %01001001, %01001001, %01001001, %00110110 'eight
    data %00110000, %01001001, %01001001, %01001010, %00111100 'nine
    data %00000000, %00110110, %00110110, %00000000, %00000000 'colon
    data %00000000, %00110101, %00110110, %00000000, %00000000 'semicolon
    data %00001000, %00010100, %00100010, %01000001, %00000000 'less_than
    data %00010100, %00010100, %00010100, %00010100, %00010100 'equals
    data %00000000, %01000001, %00100010, %00010100, %00001000 'greater_than
    data %00100000, %01000000, %01000101, %01001000, %00110000 'question_mark
    data %00100110, %01001001, %01001111, %01000001, %00111110 'at
    data %00111111, %01000100, %01000100, %01000100, %00111111 'A
    data %01111111, %01001001, %01001001, %01001001, %00110110 'B
    data %00111110, %01000001, %01000001, %01000001, %00100010 'C
    data %01111111, %01000001, %01000001, %00100010, %00011100 'D
    data %01111111, %01001001, %01001001, %01001001, %01000001 'E
    data %01111111, %01001000, %01001000, %01001000, %01000000 'F
    data %00111110, %01000001, %01001001, %01001001, %00101111 'G
    data %01111111, %00001000, %00001000, %00001000, %01111111 'H
    data %00000000, %01000001, %01111111, %01000001, %00000000 'I
    data %00000010, %00000001, %01000001, %01111110, %01000000 'J
    data %01111111, %00001000, %00010100, %00100010, %01000001 'K
    data %01111111, %00000001, %00000001, %00000001, %00000001 'L
    data %01111111, %00100000, %00011000, %00100000, %01111111 'M
    data %01111111, %00010000, %00001000, %00000100, %01111111 'N
    data %00111110, %01000001, %01000001, %01000001, %00111110 'O
    data %01111111, %01001000, %01001000, %01001000, %00110000 'P
    data %00111110, %01000001, %01000101, %01000010, %00111101 'Q
    data %01111111, %01001000, %01001100, %01001010, %00110001 'R
    data %00110001, %01001001, %01001001, %01001001, %01000110 'S
    data %01000000, %01000000, %01111111, %01000000, %01000000 'T
    data %01111110, %00000001, %00000001, %00000001, %01111110 'U
    data %01111100, %00000010, %00000001, %00000010, %01111100 'V
    data %01111110, %00000001, %00001110, %00000001, %01111110 'W
    data %01100011, %00010100, %00001000, %00010100, %01100011 'X
    data %01110000, %00001000, %00000111, %00001000, %01110000 'Y
    data %01000011, %01000101, %01001001, %01010001, %01100001 'Z
    data %00000000, %01111111, %01000001, %01000001, %00000000 'left_square
    data %00100000, %00010000, %00001000, %00000100, %00000010 'back_slash
    data %00000000, %01000001, %01000001, %01111111, %00000000 'right_square
    data %00010000, %00100000, %01000000, %00100000, %00010000 'circumflex
    data %00000001, %00000001, %00000001, %00000001, %00000001 'underscore
    data %00000000, %01000000, %00100000, %00010000, %00000000 'grave_accent
    data %00000010, %00010101, %00010101, %00010101, %00001111 'a
    data %01111111, %00001001, %00001001, %00001001, %00000110 'b
    data %00001110, %00010001, %00010001, %00010001, %00010001 'c
    data %00000110, %00001001, %00001001, %00001001, %01111111 'd
    data %00001110, %00010101, %00010101, %00010101, %00001101 'e
    data %00000000, %00001000, %00111111, %01001000, %00100000 'f
    data %00001001, %00010101, %00010101, %00010101, %00011110 'g
    data %01111111, %00001000, %00001000, %00001000, %00000111 'h
    data %00000000, %00000000, %00101111, %00000000, %00000000 'i
    data %00000010, %00000001, %00000001, %01011110, %00000000 'j
    data %00000000, %01111111, %00000100, %00001010, %00010001 'k
    data %00000000, %01000001, %01111111, %00000001, %00000000 'l
    data %00011111, %00010000, %00001110, %00010000, %00011111 'm
    data %00011111, %00001000, %00010000, %00010000, %00001111 'n
    data %00001110, %00010001, %00010001, %00010001, %00001110 'o
    data %00011111, %00010100, %00010100, %00010100, %00001000 'p
    data %00001000, %00010100, %00010100, %00010100, %00011111 'q
    data %00011111, %00001000, %00010000, %00010000, %00001000 'r
    data %00001001, %00010101, %00010101, %00010101, %00010010 's
    data %00010000, %00010000, %01111110, %00010001, %00010010 't
    data %00011110, %00000001, %00000001, %00000001, %00011110 'u
    data %00011100, %00000010, %00000001, %00000010, %00011100 'v
    data %00011110, %00000001, %00000110, %00000001, %00011110 'w
    data %00010001, %00001010, %00000100, %00001010, %00010001 'x
    data %00010000, %00001001, %00000110, %00001000, %00010000 'y
    data %00010001, %00010011, %00010101, %00011001, %00010001 'z
    data %00001000, %00110110, %01000001, %01000001, %00000000 'leftcurly
    data %00000000, %00000000, %01111111, %00000000, %00000000 'vertline
    data %00000000, %01000001, %01000001, %00110110, %00001000 'rightcurly
    data %00000100, %00001000, %00001000, %00001000, %00010000 'tilde
    data %01111111, %01000001, %01000001, %01000001, %01111111 'del
    TRISA=%00000000       '0=output
    TRISB=%00000000       '1 = input
    TRISC=%00000000
    ADCON0=%11000000
    ADCON1=%00000111
    CMCON =%00000111                   ' Comparators = off
    INTCON2.7=0 ' Enable Pull-Up's    PIC18F2620   'VERIFIED
    '    temp=l
    '    'display data sideway
    '    for M=0 to 4
    '        read l,x
    '        hserout ["L:",dec3 l, " X:",bin8 x,13,10]
    '        l=l+1
    '        if l>175 then
    '            l=170
    '        endif
    '    next m
    '    s[0]= %01111111     'these lines work
    '    s[1]= %01000001
    '    s[2]= %01000001
    '    s[3]= %01000001
    '    s[4]= %01111111
    '      for c=470 to 474
    '           write c,s[c-470]
    '           pause 1
    '      next c
          for c=0 to 475 step 5
            hserout ["C:", dec c,13,10]
            gosub rotate
          next c
          hserout ["That's all folk!",13,10]
    'setup variable
    'set c as location of
    'call this
    'ex:
    ' c=0
    ' gosub rotate
    Rotate:   'rotate 90 counterclockwise
        l=c
        temp=l
        for m=0 to 4
            read l, x
            hserout [bin x.7]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.6]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.5]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.4]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.3]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.2]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.1]
            l=l+1
        next m
        hserout [13,10]
        l=temp
        for m=0 to 4
            read l, x
            hserout [bin x.0]
            l=l+1
        next m
        hserout [13,10,13,10]
    ________________
    KV
    KVLV, Are you sure you are compiling it with the right chip selected? I have been using 18F2620's for the last few years with almost all of the eeprom used. I have never had such a problem. Your code at first glance looks as though it should work.
    Oct 2007
    Dave,
    yes, i did verify the chip use 18f2620.
    also i use windows 7 32b
    i have done/checked all the info from the top post to this end.
    I just wanted someone on the other side compile and verify that it worked.
    i have also have read the DATA/EEPROM that in this statement
    "If the optional Location value is omitted, the first DATA
    statement starts storing at address 0 and subsequent statements store at
    the following locations."
    or this "If the optional Location value is
    omitted, the first EEPROM statement starts storing at address 0 and
    subsequent statements store at the following locations."
    ________________
    KV
    Compile works down here for the code you posted. Success 1678 bytes.
    Windows XP
    mplab ide 8.60
    mpasm v5.38
    microcode studio 3.0.0.5
    http://www.scalerobotics.com
    Oct 2007
    my compilation came up with 1686 bytes
    fyi: i used tiny bootloader to load the hex file to the pic and also
    use my trusted programmer to load the hex file.
    the display cannot pass the 256 bytes of eeprom.
    i am sure the READ/WRITE command work fine.
    these code work fine
    '    s[1]= %01000001
    '    s[2]= %01000001
    '    s[3]= %01000001
    '    s[4]= %01111111
    '      for c=470 to 474
    '           write c,s[c-470]
    '           pause 1
    '      next c
    i am question the DATA/EEPROM are not working.
    this is from the tiny booloader
    Connected to \\.\COM1 at 115200
      HEX: 2 min old, INHX32,18Fcode+cfg+eeprom , total=1686 bytes.
      Searching for PIC ...
      Found:18F 2620/4620
      eeprom addr:000h <- 00h
      eeprom addr:001h <- 00h
      eeprom addr:002h <- 00h
      eeprom addr:003h <- 00h
      eeprom addr:004h <- 00h
      eeprom addr:005h <- 00h
      eeprom addr:006h <- 00h
      eeprom addr:007h <- 79h
      eeprom addr:008h <- 00h
      eeprom addr:009h <- 00h
      eeprom addr:00Ah <- 00h
      eeprom addr:00Bh <- 70h
      eeprom addr:00Ch <- 00h
      eeprom addr:00Dh <- 70h
      eeprom addr:00Eh <- 00h
      eeprom addr:00Fh <- 14h
      eeprom addr:010h <- 7Fh
      eeprom addr:011h <- 14h
      eeprom addr:012h <- 7Fh
      eeprom addr:013h <- 14h
      eeprom addr:014h <- 12h
      eeprom addr:015h <- 2Ah
      eeprom addr:016h <- 7Fh
      eeprom addr:017h <- 2Ah
      eeprom addr:018h <- 24h
      eeprom addr:019h <- 62h
      eeprom addr:01Ah <- 64h
      eeprom addr:01Bh <- 08h
      eeprom addr:01Ch <- 13h
      eeprom addr:01Dh <- 23h
      eeprom addr:01Eh <- 36h
      eeprom addr:01Fh <- 49h
      eeprom addr:020h <- 55h
      eeprom addr:021h <- 22h
      eeprom addr:022h <- 05h
      eeprom addr:023h <- 00h
      eeprom addr:024h <- 50h
      eeprom addr:025h <- 60h
      eeprom addr:026h <- 00h
      eeprom addr:027h <- 00h
      eeprom addr:028h <- 00h
      eeprom addr:029h <- 1Ch
      eeprom addr:02Ah <- 22h
      eeprom addr:02Bh <- 41h
      eeprom addr:02Ch <- 00h
      eeprom addr:02Dh <- 00h
      eeprom addr:02Eh <- 41h
      eeprom addr:02Fh <- 22h
      eeprom addr:030h <- 1Ch
      eeprom addr:031h <- 00h
      eeprom addr:032h <- 14h
      eeprom addr:033h <- 08h
      eeprom addr:034h <- 3Eh
      eeprom addr:035h <- 08h
      eeprom addr:036h <- 14h
      eeprom addr:037h <- 08h
      eeprom addr:038h <- 08h
      eeprom addr:039h <- 3Eh
      eeprom addr:03Ah <- 08h
      eeprom addr:03Bh <- 08h
      eeprom addr:03Ch <- 00h
      eeprom addr:03Dh <- 05h
      eeprom addr:03Eh <- 06h
      eeprom addr:03Fh <- 00h
      eeprom addr:040h <- 00h
      eeprom addr:041h <- 08h
      eeprom addr:042h <- 08h
      eeprom addr:043h <- 08h
      eeprom addr:044h <- 08h
      eeprom addr:045h <- 08h
      eeprom addr:046h <- 00h
      eeprom addr:047h <- 03h
      eeprom addr:048h <- 03h
      eeprom addr:049h <- 00h
      eeprom addr:04Ah <- 00h
      eeprom addr:04Bh <- 02h
      eeprom addr:04Ch <- 04h
      eeprom addr:04Dh <- 08h
      eeprom addr:04Eh <- 10h
      eeprom addr:04Fh <- 20h
      eeprom addr:050h <- 3Eh
      eeprom addr:051h <- 45h
      eeprom addr:052h <- 49h
      eeprom addr:053h <- 51h
      eeprom addr:054h <- 3Eh
      eeprom addr:055h <- 00h
      eeprom addr:056h <- 21h
      eeprom addr:057h <- 7Fh
      eeprom addr:058h <- 01h
      eeprom addr:059h <- 00h
      eeprom addr:05Ah <- 21h
      eeprom addr:05Bh <- 43h
      eeprom addr:05Ch <- 45h
      eeprom addr:05Dh <- 49h
      eeprom addr:05Eh <- 31h
      eeprom addr:05Fh <- 42h
      eeprom addr:060h <- 41h
      eeprom addr:061h <- 51h
      eeprom addr:062h <- 69h
      eeprom addr:063h <- 46h
      eeprom addr:064h <- 0Ch
      eeprom addr:065h <- 14h
      eeprom addr:066h <- 24h
      eeprom addr:067h <- 7Fh
      eeprom addr:068h <- 04h
      eeprom addr:069h <- 72h
      eeprom addr:06Ah <- 51h
      eeprom addr:06Bh <- 51h
      eeprom addr:06Ch <- 51h
      eeprom addr:06Dh <- 4Eh
      eeprom addr:06Eh <- 1Eh
      eeprom addr:06Fh <- 29h
      eeprom addr:070h <- 49h
      eeprom addr:071h <- 49h
      eeprom addr:072h <- 06h
      eeprom addr:073h <- 40h
      eeprom addr:074h <- 47h
      eeprom addr:075h <- 48h
      eeprom addr:076h <- 50h
      eeprom addr:077h <- 60h
      eeprom addr:078h <- 36h
      eeprom addr:079h <- 49h
      eeprom addr:07Ah <- 49h
      eeprom addr:07Bh <- 49h
      eeprom addr:07Ch <- 36h
      eeprom addr:07Dh <- 30h
      eeprom addr:07Eh <- 49h
      eeprom addr:07Fh <- 49h
      eeprom addr:080h <- 4Ah
      eeprom addr:081h <- 3Ch
      eeprom addr:082h <- 00h
      eeprom addr:083h <- 36h
      eeprom addr:084h <- 36h
      eeprom addr:085h <- 00h
      eeprom addr:086h <- 00h
      eeprom addr:087h <- 00h
      eeprom addr:088h <- 35h
      eeprom addr:089h <- 36h
      eeprom addr:08Ah <- 00h
      eeprom addr:08Bh <- 00h
      eeprom addr:08Ch <- 08h
      eeprom addr:08Dh <- 14h
      eeprom addr:08Eh <- 22h
      eeprom addr:08Fh <- 41h
      eeprom addr:090h <- 00h
      eeprom addr:091h <- 14h
      eeprom addr:092h <- 14h
      eeprom addr:093h <- 14h
      eeprom addr:094h <- 14h
      eeprom addr:095h <- 14h
      eeprom addr:096h <- 00h
      eeprom addr:097h <- 41h
      eeprom addr:098h <- 22h
      eeprom addr:099h <- 14h
      eeprom addr:09Ah <- 08h
      eeprom addr:09Bh <- 20h
      eeprom addr:09Ch <- 40h
      eeprom addr:09Dh <- 45h
      eeprom addr:09Eh <- 48h
      eeprom addr:09Fh <- 30h
      eeprom addr:0A0h <- 26h
      eeprom addr:0A1h <- 49h
      eeprom addr:0A2h <- 4Fh
      eeprom addr:0A3h <- 41h
      eeprom addr:0A4h <- 3Eh
      eeprom addr:0A5h <- 3Fh
      eeprom addr:0A6h <- 44h
      eeprom addr:0A7h <- 44h
      eeprom addr:0A8h <- 44h
      eeprom addr:0A9h <- 3Fh
      eeprom addr:0AAh <- 7Fh
      eeprom addr:0ABh <- 49h
      eeprom addr:0ACh <- 49h
      eeprom addr:0ADh <- 49h
      eeprom addr:0AEh <- 36h
      eeprom addr:0AFh <- 3Eh
      eeprom addr:0B0h <- 41h
      eeprom addr:0B1h <- 41h
      eeprom addr:0B2h <- 41h
      eeprom addr:0B3h <- 22h
      eeprom addr:0B4h <- 7Fh
      eeprom addr:0B5h <- 41h
      eeprom addr:0B6h <- 41h
      eeprom addr:0B7h <- 22h
      eeprom addr:0B8h <- 1Ch
      eeprom addr:0B9h <- 7Fh
      eeprom addr:0BAh <- 49h
      eeprom addr:0BBh <- 49h
      eeprom addr:0BCh <- 49h
      eeprom addr:0BDh <- 41h
      eeprom addr:0BEh <- 7Fh
      eeprom addr:0BFh <- 48h
      eeprom addr:0C0h <- 48h
      eeprom addr:0C1h <- 48h
      eeprom addr:0C2h <- 40h
      eeprom addr:0C3h <- 3Eh
      eeprom addr:0C4h <- 41h
      eeprom addr:0C5h <- 49h
      eeprom addr:0C6h <- 49h
      eeprom addr:0C7h <- 2Fh
      eeprom addr:0C8h <- 7Fh
      eeprom addr:0C9h <- 08h
      eeprom addr:0CAh <- 08h
      eeprom addr:0CBh <- 08h
      eeprom addr:0CCh <- 7Fh
      eeprom addr:0CDh <- 00h
      eeprom addr:0CEh <- 41h
      eeprom addr:0CFh <- 7Fh
      eeprom addr:0D0h <- 41h
      eeprom addr:0D1h <- 00h
      eeprom addr:0D2h <- 02h
      eeprom addr:0D3h <- 01h
      eeprom addr:0D4h <- 41h
      eeprom addr:0D5h <- 7Eh
      eeprom addr:0D6h <- 40h
      eeprom addr:0D7h <- 7Fh
      eeprom addr:0D8h <- 08h
      eeprom addr:0D9h <- 14h
      eeprom addr:0DAh <- 22h
      eeprom addr:0DBh <- 41h
      eeprom addr:0DCh <- 7Fh
      eeprom addr:0DDh <- 01h
      eeprom addr:0DEh <- 01h
      eeprom addr:0DFh <- 01h
      eeprom addr:0E0h <- 01h
      eeprom addr:0E1h <- 7Fh
      eeprom addr:0E2h <- 20h
      eeprom addr:0E3h <- 18h
      eeprom addr:0E4h <- 20h
      eeprom addr:0E5h <- 7Fh
      eeprom addr:0E6h <- 7Fh
      eeprom addr:0E7h <- 10h
      eeprom addr:0E8h <- 08h
      eeprom addr:0E9h <- 04h
      eeprom addr:0EAh <- 7Fh
      eeprom addr:0EBh <- 3Eh
      eeprom addr:0ECh <- 41h
      eeprom addr:0EDh <- 41h
      eeprom addr:0EEh <- 41h
      eeprom addr:0EFh <- 3Eh
      eeprom addr:0F0h <- 7Fh
      eeprom addr:0F1h <- 48h
      eeprom addr:0F2h <- 48h
      eeprom addr:0F3h <- 48h
      eeprom addr:0F4h <- 30h
      eeprom addr:0F5h <- 3Eh
      eeprom addr:0F6h <- 41h
      eeprom addr:0F7h <- 45h
      eeprom addr:0F8h <- 42h
      eeprom addr:0F9h <- 3Dh
      eeprom addr:0FAh <- 7Fh
      eeprom addr:0FBh <- 48h
      eeprom addr:0FCh <- 4Ch
      eeprom addr:0FDh <- 4Ah
      eeprom addr:0FEh <- 31h
      eeprom addr:0FFh <- 31h
      WRITE OK  at 9:17,   time:4.242 sec
    the enclose picture is from my programmer soft.
    ________________
    KV
    Oct 2007
    Thanks scalerobotics.
    I have a temp solution, workaround.
    this program will write the needed data to the eeprom and use the one posted above to read.
    '*  Author  : KVLV                                              *
    '*  Date    : 12/30/2010                                        *
    'chip use 18F2620
    define OSC 20
    B0 var word[1024]
    C var word
    TRISC=%00000000
    ADCON0=%11000000
    ADCON1=%00000111
    'data %00110001, %01001001, %01001001, %01001001, %01000110 'S
    b0[255]=%00110010:b0[256]=%01001001:b0[257]=%01001001:b0[258]=%01001001:b0[259]=%00100110 'S   'corrected dec 30.2010
    b0[260]=%01000000:b0[261]=%01000000:b0[262]=%01111111:b0[263]=%01000000:b0[264]=%01000000 'T
    b0[265]=%01111110:b0[266]=%00000001:b0[267]=%00000001:b0[268]=%00000001:b0[269]=%01111110 'U
    b0[270]=%01111100:b0[271]=%00000010:b0[272]=%00000001:b0[273]=%00000010:b0[274]=%01111100 'V
    b0[275]=%01111110:b0[276]=%00000001:b0[277]=%00001110:b0[278]=%00000001:b0[279]=%01111110 'W
    b0[280]=%01100011:b0[281]=%00010100:b0[282]=%00001000:b0[283]=%00010100:b0[284]=%01100011 'X
    b0[285]=%01110000:b0[286]=%00001000:b0[287]=%00000111:b0[288]=%00001000:b0[289]=%01110000 'Y
    b0[290]=%01000011:b0[291]=%01000101:b0[292]=%01001001:b0[293]=%01010001:b0[294]=%01100001 'Z
    b0[295]=%00000000:b0[296]=%01111111:b0[297]=%01000001:b0[298]=%01000001:b0[299]=%00000000 'left_square
    b0[300]=%00100000:b0[301]=%00010000:b0[302]=%00001000:b0[303]=%00000100:b0[304]=%00000010 'back_slash
    b0[305]=%00000000:b0[306]=%01000001:b0[307]=%01000001:b0[308]=%01111111:b0[309]=%00000000 'right_square
    b0[310]=%00010000:b0[311]=%00100000:b0[312]=%01000000:b0[313]=%00100000:b0[314]=%00010000 'circumflex
    b0[315]=%00000001:b0[316]=%00000001:b0[317]=%00000001:b0[318]=%00000001:b0[319]=%00000001 'underscore
    b0[320]=%00000000:b0[321]=%01000000:b0[322]=%00100000:b0[323]=%00010000:b0[324]=%00000000 'grave_accent
    b0[325]=%00000010:b0[326]=%00010101:b0[327]=%00010101:b0[328]=%00010101:b0[329]=%00001111 'a
    b0[330]=%01111111:b0[331]=%00001001:b0[332]=%00001001:b0[333]=%00001001:b0[334]=%00000110 'b
    b0[335]=%00001110:b0[336]=%00010001:b0[337]=%00010001:b0[338]=%00010001:b0[339]=%00010001 'c
    b0[340]=%00000110:b0[341]=%00001001:b0[342]=%00001001:b0[343]=%00001001:b0[344]=%01111111 'd
    b0[345]=%00001110:b0[346]=%00010101:b0[347]=%00010101:b0[348]=%00010101:b0[349]=%00001101 'e
    b0[350]=%00000000:b0[351]=%00001000:b0[352]=%00111111:b0[353]=%01001000:b0[354]=%00100000 'f
    b0[355]=%00001001:b0[356]=%00010101:b0[357]=%00010101:b0[358]=%00010101:b0[359]=%00011110 'g
    b0[360]=%01111111:b0[361]=%00001000:b0[362]=%00001000:b0[363]=%00001000:b0[364]=%00000111 'h
    b0[365]=%00000000:b0[366]=%00000000:b0[367]=%00101111:b0[368]=%00000000:b0[369]=%00000000 'i
    b0[370]=%00000010:b0[371]=%00000001:b0[372]=%00000001:b0[373]=%01011110:b0[374]=%00000000 'j
    b0[375]=%00000000:b0[376]=%01111111:b0[377]=%00000100:b0[378]=%00001010:b0[379]=%00010001 'k
    b0[380]=%00000000:b0[381]=%01000001:b0[382]=%01111111:b0[383]=%00000001:b0[384]=%00000000 'l
    b0[385]=%00011111:b0[386]=%00010000:b0[387]=%00001110:b0[388]=%00010000:b0[389]=%00011111 'm
    b0[390]=%00011111:b0[391]=%00001000:b0[392]=%00010000:b0[393]=%00010000:b0[394]=%00001111 'n
    b0[395]=%00001110:b0[396]=%00010001:b0[397]=%00010001:b0[398]=%00010001:b0[399]=%00001110 'o
    b0[400]=%00011111:b0[401]=%00010100:b0[402]=%00010100:b0[403]=%00010100:b0[404]=%00001000 'p
    b0[405]=%00001000:b0[406]=%00010100:b0[407]=%00010100:b0[408]=%00010100:b0[409]=%00011111 'q
    b0[410]=%00011111:b0[411]=%00001000:b0[412]=%00010000:b0[413]=%00010000:b0[414]=%00001000 'r
    b0[415]=%00001001:b0[416]=%00010101:b0[417]=%00010101:b0[418]=%00010101:b0[419]=%00010010 's
    b0[420]=%00010000:b0[421]=%00010000:b0[422]=%01111110:b0[423]=%00010001:b0[424]=%00010010 't
    b0[425]=%00011110:b0[426]=%00000001:b0[427]=%00000001:b0[428]=%00000001:b0[429]=%00011110 'u
    b0[430]=%00011100:b0[431]=%00000010:b0[432]=%00000001:b0[433]=%00000010:b0[434]=%00011100 'v
    b0[435]=%00011110:b0[436]=%00000001:b0[437]=%00000110:b0[438]=%00000001:b0[439]=%00011110 'w
    b0[440]=%00010001:b0[441]=%00001010:b0[442]=%00000100:b0[443]=%00001010:b0[444]=%00010001 'x
    b0[445]=%00010000:b0[446]=%00001001:b0[447]=%00000110:b0[448]=%00001000:b0[449]=%00010000 'y
    b0[450]=%00010001:b0[451]=%00010011:b0[452]=%00010101:b0[453]=%00011001:b0[454]=%00010001 'z
    b0[455]=%00001000:b0[456]=%00110110:b0[457]=%01000001:b0[458]=%01000001:b0[459]=%00000000 'leftcurly
    b0[460]=%00000000:b0[461]=%00000000:b0[462]=%01111111:b0[463]=%00000000:b0[464]=%00000000 'vertline
    b0[465]=%00000000:b0[466]=%01000001:b0[467]=%01000001:b0[468]=%00110110:b0[469]=%00001000 'rightcurly
    b0[470]=%00000100:b0[471]=%00001000:b0[472]=%00001000:b0[473]=%00001000:b0[474]=%00010000 'tilde
    b0[475]=%01111111:b0[476]=%01000001:b0[477]=%01000001:b0[478]=%01000001:b0[479]=%01111111 'del
    b0[480]=$ef 'eof
          for c=255 to 480
               write c,b0[c]
               pause 1
          next c
    ________________
    KV
