pbp 2.60a upgrade
Results 1 to 31 of 31
    Aug 2009
    Paso Robles California
    Default no clue
    ok so I changed the defines from this
    @ DEVICE PIC16F628A,HS_OSC,WDT_ON,PWRT_ON,PROTECT_ON
    to this
    @ __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    and now the errors just keep coming
    Executing: "C:\PBP\PBPMPLAB.BAT" -ampasmwin -k# -p16F628A "test.bas"
    Executing: "C:\PBP\PBPW.EXE" -ampasmwin -k# -p16F628A "ltest.bas"
    PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Error[118] C:\0 FILES\2MPLAB\test.ASM 116 : Overwriting previous address contents (2007)
    Halting build on first failure as requested.
    BUILD FAILED: Mon Aug 30 14:44:39 2010
    Looks like you did not comment the config lines in the PBP inc file.
    See the thread I linked to above.
