SPI - The basics
Results 1 to 19 of 19
    There are several ways to do it, but I would probably go for something like this;
    The upper 4-bits for DAC channel A, with 2x gain, with A active, will remain constant. So create a constant like ASel CON 4096. This would be the following in 16-bit binary: %0001000000000000.
    The lower 12-bits, with the 2 least significant bits ignored, + ASel would be your value to send to the DAC to adjust the channel A output.
    Just use a word variable. Load your word variable with any value from 0 to 1023, then shift this left x 2 so the 2 LSBs are 0, then add the ASel constant for the value to shiftout.
    Say your word var is ChanA, and it's = 501. ChanA = (ChanA << 2) + ASel.
    501d = %0000000111110101. Shifted left x 2 it's %0000011111010100. When you add the ASel constant, it ends up being %0001011111010100.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2010
    Thanks Bruce-
    All the seperate components came together and everything is working great. Your help above was great!!!
    Mar 2009
    Just had my first attempt dabbling with SPI this evening - fail!
    I'm trying to control a AD5206 (six digital pots in the one IC package - http://www.analog.com/static/importe...D5204_5206.pdf)
    To test that the wiper on the nominated pot moves I've put 5V on the High side of the internal pot6 pin, & 0V on the low side of pot6 pin. I'm trying to set pot 6's wiper to the midway point (it's a 256 position pot, so I'm sending a value of 127) - but the wiper is not going to 2.5V ....it just sits at 5V.
    I've try to join all the 'SPI' elements together (as taken from several threads!). The only bit I'm not totally sure about (& it's pretty fundamental!) is how to send just 11 bits to the AD5206 (the format is three bits to select which of the 6 internal digital pots you want the wiper to move, then send the data to actually control the wiper (3 'variable resistor select' bits + 8 databits so 11 bits in total).
    Any ideas....
    @ __CONFIG _FCMEN_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOR_OFF & _PWRTE_OFF
    '16F690 Pin Connections....
    ' PIN# NAME     USE & CONNECTION
    '  1   Vdd      +5VDC power supply
    '  9   RC7      SDO (serial Data out)
    '  10  RB7      HSEROUT pIN
    '  11  RB6      SPI Clock out
    '  13  RB4      SDI (serial Data In)
    '  16  RCO      CS Chip Select (to pin 3 on AD5206)   output
    '  20  Vss      Ground
    DEFINE  OSC 8          ' set Oscillator at 8Mhz.
    DEFINE  NO_CLRWDT 1   ' PBP doesn't clear WDT automatically
    DEFINE HSER_SPBRG 25   'HSEROUT Stuff.
    DEFINE HSER_TXSTA 24h  'HSEROUT Stuff.
    DEFINE HSER_CLROERR 1  'HSEROUT Stuff.
    txsta = %10100100       'setup the tx register
    RCSTA.7 = 1             'Enable RB7 for TX USART
    INTCON.0 = 0            'clears the RABIF Flag (to 0), COULD be 1 on reset (unique to F690)
    ANSEL      = 0          'disable AtoD.
    ANSELH     = 0          'disable AtoD.
    OPTION_REG = %00000111  'enable weak pullups.
    WPUB     = %00010000   'enable weak pullups on the SDI RB4 (input from digital pot)
    '------SPI setup
    SSPEN VAR SSPCON.5   ' SSP Enable bit
    CKP   VAR SSPCON.4   ' Clock Polarity Select
    SMP   VAR SSPSTAT.7  ' Data input sample phase
    CKE   VAR SSPSTAT.6  ' Clock Edge Select bit
    SSPIF VAR PIR1.3     ' SPI interrupt flag
    SSPCON.5=1 'enable SSP
    SSPCON.4=1 'Clock idles high bit name CKP
    SSPCON.3=0 ' bit 3 to 0 indicate clock speed. bit 0 set means clock = OSC/16 = 1.25 MHz
    SSPCON.2=0
    SSPCON.1=0
    SSPCON.0=1
    SSPSTAT.7=1 ' SPI Master mode
    SSPSTAT.6=0 ' data transmitted on rising edge of SCK
    SCK     var PortB.6  'clock pin
    CS      var PORTC.0     'chip select
    SDI     var PortB.4    'data in
    SDO     var PortC.7      'data out
    AD5206  var word    'word used to send 3 control bits  + 8 data bits
    TrisC.0 = 0    'Chip Select (CS)
    TrisB.6 = 0    'SPI Clock Out
    TrisB.7 = 0    'Debug Out
    ' AD5206 Variable resistor select 'Control' bits as as follows....
    '000 Select Variable resistor1
    '001 Select Variable resistor2
    '010 Select Variable resistor3
    '011 Select Variable resistor4
    '100 Select Variable resistor5
    '101 Select Variable resistor6
    AD5206 = %00001010111111   'upper byte = select Variable Resistor 6 (ref the table above) , lower byte = set VR6 wiper value to midway
    high CS
    ' CODE TO CONTROL SPI POTENTIOMETER AD5206
        gosub WriteSPI
        goto Main
    WriteSPI:
        LOW CS
        Shiftout SDO, SCk, 1, [AD5206 \11] ' not sure about this bit!!
        high cs
    SHIFTOUT is a software SPI communications routine. If you use it, don't enable the PICs hardware SPI. If you do, then the hardware SPI takes control of these pins, and SHIFTOUT won't work.
    -Bruce
    tech at rentron.com
    Mar 2009
    Thanks for the heads up.
    Ok....struggling here! (being completely new to SPI!)
    I'd assumed the reason that SPI hw being available on the PIC was to assist in ease of comms with SPI devices....but now youre saying that h/w should not be used when shiftout is used? So (n00b hat on again!).... Why use shiftout wrt SPI then?
    How does shiftout 'marry' up with the SPI master clock (when using h/w presumably there's tight correlation between the SPI buffers being read out at the right time etc)
    If not using shiftout (as in my above code), how would getting an 11 bit control stream out the SDO pin (the least 3 significant bits of an upper byte + a complete lower byte) be approached in hw?
    It's pretty much the same for any built-in hardware peripheral.
    Once you enable a peripheral, it takes control of the pins. With PBP SHIFTIN & SHIFTOUT you can use most any pin. With the hardware peripheral you're stuck using whatever pins are used for the hardware peripheral.
    Melabs has a few examples for using hardware SPI here http://melabs.com/resources/samples-pbp-general.htm but I would stick with SHIFTOUT & SHIFTIN unless you just want to learn how the hardware works.
    -Bruce
    tech at rentron.com
    Mar 2009
    Thank (as ever) Bruce....I managed to get the hardware working (while testing I was sending a data byte of zeros to the digipot ....which ahem, being zeros don't show up on the PIC's SDO pin...doh, lol. Also, I was clocking data out of the pic on the wrong edge of the clock, which meant the least significant of the data byte was going awol from the digipot's perspective)
    So, while I'm what's the pros and cons of s/w SPI vs hw SPI?
    From the top of my head (and some assumptions)...
    sw SPI ...
    pros - flexibility of pin assignments, bit centric.
    cons - slower? can't use interrupts in the same program (this is an assumption on my part as I know serout/debug get corrupted when interrupts are used in the same program)
    hw SPI ...
    pros - can use interrupts in the same program?, faster?
    cons - tied to using the allocated SPI pins. byte centric?
