After banging around for a while, I was able to get this to give me good data from the inclinometer:
My LOGIC pod had a bit of a rough time trying to make sense of the unusual length of data and that threw me for a bit, but the HSEROUT showed that all was good. .Code:CS_I VAR PORTD.0 ' chip select Inclinomteter CS_D VAR PORTC.3 ' chip select D/A SCK VAR PORTD.3 ' clock SDI VAR PORTD.2 ' data IN , MISO SDO VAR PORTD.1 ' data OUT, MOSI IncIn var word HIGH CS_I HIGH CS_D LOW SCK HIGH CS_I 'I = %00001000 'send TeMP command I = %00010000 'send RDAX Main: GOSUB iNCrDG hserout ["IncRdg ",bin IncIn," ",DEC IncIn," ",10,13] PAUSE 100 goto main '**** Subs ********************************* ;---- Sub to read the inclinometer ------------------ IncRdg: LOW CS_I ' enable writes to Inclinometer SHIFTOUT SDO,SCK,1,[I] 'sends command to READ SHIFTIN SDI,SCK,0,[IncIn\11] HIGH CS_I RETURN
Hope that help someone.
Bo
