How to use For Next Loop to run sequence light ?
Results 1 to 14 of 14
    Aug 2010
    I've tried it, and it does compile
    Unfortunately, when I put it in my circuit, only PortB.0 Blinks!
    Ooo Nooooo!!!!
    @ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT, MCLR_OFF
    CMCON = 7
    Counter var Byte
    SubRoutine:
    For Counter = 0 to 2
    high PortB.0[Counter]
    high PortA.0[Counter]
    Next Counter
    Pause 500
    Low PortB.0[Counter]
    Low PortA.0[Counter]
    Next Counter
    pause 800
    Goto SubRoutine
    Miami, Florida USA
    Quote Originally Posted by Bracer View Post
    Ooo Nooooo!!!!
    Include this lines in your program
    TRISA = 0 ' Make them all outputs
    TRISB = 0
    Anonymous
    Aug 2010
    Thanks.
    Ok Now all the LEDs light up.
    BUT only PortB.0 and PortB.1 Blinks.
    Again, this the code:
    CMCON = 7
    TRISB = 0
    Counter var Byte
    SubRoutine:
    Next Counter
    Pause 600
    Next Counter
    Goto SubRoutine
    Thanks.
    CMCON = 7
    TRISB = 0
    Counter var Byte
    SubRoutine:
    Next Counter
    Pause 600
    Next Counter
    Goto SubRoutine
    Hi, Bracer
    I suspect a RMW issue ... as HIGH and LOW already cares of driving inputs and outputs
    How much current do you send to your Leds ???
    try to limit it to 5 mA per Led ... as a first try.
    as a second try ...
    CMCON = 7
    TRISB = 0
    Counter var Byte
    SubRoutine:
    PORTA = PORTA | % 00000111
    PORTB = PORTB | % 00000111
    Pause 600
    PORTA = PORTA & % 11111000
    PORTB = PORTB & % 11111000
    Goto SubRoutine
    a scheme of your circuit really would be welcome ...
    Aug 2010
    I am getting a
    WARNING Line 20: Bad token "%".
    WARNING Line 21: Bad token "%".
    WARNING Line 24: Bad token "%".
    WARNING Line 25: Bad token "%".
    WARNING Line 24: 11111000 Numeric overflow, value truncated. (Test.pbp)
    WARNING Line 25: 11111000 Numeric overflow, value truncated. (Test.pbp)
    When I copy and paste the code your exact codes.
    You are right Acetronics, I am using a +6V, but I did try the manual "High PortA.0" way to manually set each pin and it works.
    Every single pins are all functional, so it couldn't have been a pin damage issue.
    The schematic is really empty, Pin 5 to the negative and Pin 14 to the positive,
    PortB.0 ~ PortB.2 to LEDs.
    PortA.0 ~PortA.2 to LEDs, that's all.
    Miami, Florida USA
    I am getting a
    There is no space betweeen the % and the binaty number; Example: %00000111
    Anonymous
    Hi, Bracer
    sorry for the "space" ...
    For your leds ... place a series resistor : 220 Ohms as a minimum @ 6v supply ...
    I know some do not use resistors ... but it creates RMW issues !!!
    You MUST keep current inside the specified limits ( ABSOLUTE limits: 25 ma - 100 mA per full port ) , but do not rely on the internal limitation ... or you'll get surprises !!!
