Quote Originally Posted by Bracer View Post
I am getting a
WARNING Line 20: Bad token "%".
WARNING Line 21: Bad token "%".
WARNING Line 24: Bad token "%".
WARNING Line 25: Bad token "%".
WARNING Line 24: 11111000 Numeric overflow, value truncated. (Test.pbp)
WARNING Line 25: 11111000 Numeric overflow, value truncated. (Test.pbp)
When I copy and paste the code your exact codes.
You are right Acetronics, I am using a +6V, but I did try the manual "High PortA.0" way to manually set each pin and it works.
Every single pins are all functional, so it couldn't have been a pin damage issue.
The schematic is really empty, Pin 5 to the negative and Pin 14 to the positive,
PortB.0 ~ PortB.2 to LEDs.
PortA.0 ~PortA.2 to LEDs, that's all.
There is no space betweeen the % and the binaty number; Example: %00000111
