How to use For Next Loop to run sequence light ?
Results 1 to 14 of 14
    Aug 2010
    Default How to use For Next Loop to run sequence light ?
    @ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT, MCLR_OFF
    CMCON = 7
    Counter var Byte
    Counter = 0
    Routine:
    For Counter = 0 to 6
    High PortB.Counter
    Next Counter
    Low PortB.Counter
    Next Counter
    GoTo Routine
    Apparently:
    High PortB.Counter
    and
    Low PortB.Counter
    is giving me errors, I could have done this with no errors:
    High Counter
    Next Counter
    but this will be a PICBasic command and I will not be able to control PortA.
    How do I use the For Next Loop to handle PortA too ?
    PortA.something ... something must be a CONSTANT ...
    so, try indexing PortA
    PortA.0[counter] = 1
    ; OR
    HIGH PortA.0[counter]
    Should compile fine.
    Aug 2010
    I've tried it, and it does compile
    Unfortunately, when I put it in my circuit, only PortB.0 Blinks!
    Ooo Nooooo!!!!
    CMCON = 7
    Counter var Byte
    SubRoutine:
    For Counter = 0 to 2
    high PortB.0[Counter]
    high PortA.0[Counter]
    Next Counter
    Pause 500
    Low PortB.0[Counter]
    Low PortA.0[Counter]
    Next Counter
    pause 800
    Goto SubRoutine
    Miami, Florida USA
    Quote Originally Posted by Bracer View Post
    Ooo Nooooo!!!!
    Include this lines in your program
    TRISA = 0 ' Make them all outputs
    TRISB = 0
    Anonymous
    Aug 2010
    Thanks.
    Ok Now all the LEDs light up.
    BUT only PortB.0 and PortB.1 Blinks.
    Again, this the code:
    CMCON = 7
    TRISB = 0
    Counter var Byte
    SubRoutine:
    Next Counter
    Pause 600
    Next Counter
    Goto SubRoutine
    Thanks.
    CMCON = 7
    TRISB = 0
    Counter var Byte
    SubRoutine:
    Next Counter
    Pause 600
    Next Counter
    Goto SubRoutine
    Hi, Bracer
    I suspect a RMW issue ... as HIGH and LOW already cares of driving inputs and outputs
    How much current do you send to your Leds ???
    try to limit it to 5 mA per Led ... as a first try.
    as a second try ...
    CMCON = 7
    TRISB = 0
    Counter var Byte
    SubRoutine:
    PORTA = PORTA | % 00000111
    PORTB = PORTB | % 00000111
    Pause 600
    PORTA = PORTA & % 11111000
    PORTB = PORTB & % 11111000
    Goto SubRoutine
    a scheme of your circuit really would be welcome ...
    Aug 2010
    I am getting a
    WARNING Line 20: Bad token "%".
    WARNING Line 21: Bad token "%".
    WARNING Line 24: Bad token "%".
    WARNING Line 25: Bad token "%".
    WARNING Line 24: 11111000 Numeric overflow, value truncated. (Test.pbp)
    WARNING Line 25: 11111000 Numeric overflow, value truncated. (Test.pbp)
    When I copy and paste the code your exact codes.
    You are right Acetronics, I am using a +6V, but I did try the manual "High PortA.0" way to manually set each pin and it works.
    Every single pins are all functional, so it couldn't have been a pin damage issue.
    The schematic is really empty, Pin 5 to the negative and Pin 14 to the positive,
    PortB.0 ~ PortB.2 to LEDs.
    PortA.0 ~PortA.2 to LEDs, that's all.
    Miami, Florida USA
    I am getting a
    There is no space betweeen the % and the binaty number; Example: %00000111
    Anonymous
    Hi, Bracer
    sorry for the "space" ...
    For your leds ... place a series resistor : 220 Ohms as a minimum @ 6v supply ...
    I know some do not use resistors ... but it creates RMW issues !!!
    You MUST keep current inside the specified limits ( ABSOLUTE limits: 25 ma - 100 mA per full port ) , but do not rely on the internal limitation ... or you'll get surprises !!!
    Aug 2010
    WOW Acetronics....
    You are so cool!
    Make PortA and PortB's 0~2 lights up.
    PORTA = PORTA | %00000111
    PORTB = PORTB | %00000111
    Make PortA and PortB's 0~2 lights Down.
    PORTA = PORTA & %11111000
    PORTB = PORTB & %11111000
    Completely works...wow...in just one line you have set 3 lights from PortB to light up...
    It suddenly makes this whole "High PortB.0" look barbaric!
    I don't exactly know "How" you set it, but I did try to experiment, I went ahead and try to make the light goes from the outside two lights to the inside one light, basically:
    High PortB.0
    High PortB.2
    Low PortB.1
    Pause 500
    Low PortB.0
    Low PortB.2
    High PortB.1
    Pause 500
    Low PortB.0
    Low PortB.2
    Low PortB.1
    Pause 500
    But me...trying to "copy" your way, not knowing what I am doing, do this:
    PORTA = PORTA | %00000101
    PORTB = PORTB | %00000101
    Pause 500
    PORTA = PORTA & %00000010
    PORTB = PORTB & %00000010
    Let's just say the lights acted weird, I have no idea what "|" in the code does either than it's probably "Or" ?
    Not to mention "&" either than C's "And" ?
    But they are single and not in pairs...some sort of bit shifters ?
    Must trying to understand this concept...one line to control all Port Outputs....so powerful...but so mysterious to me...
    Anyway thanks Acetronics, I use a 470 ohm for the LEDs under +6V
    Pause 500
    PORTA = PORTA | %00000101 = Read PORTA and set to 1 ports A0 and A2
    PORTA = PORTA & %00000010 = Read PORTA and clear ports A0 and A2
    you use " | " ( OR ) to SET portspins and & ( AND ) to clear them ... but no mix allowed
    you can try ...
    Subroutine:
    PORTA = PORTA ^ %00000111 ' FLIPS the bits with a " 1 "
    PORTB = PORTB ^ %00000111
    GOTO Subroutine
    see your manual " Bitwise Operators " section $4.16.17
    Aug 2010
    Thank you Acetronics, thanks to you, I now understand everything I need to understand for my Build from scratch Tricorder Project.
    This is the note I have compiled based on what you have explained.
    'Make them all outputs, Remember Pin 4, PortA.5 will always be Input Only
    'And Pin 3, PortA.4 needs a pull up resistor.
    'Understand that these two lines will make High, all Pins
    'meaning the LEDs will ALL light up.
    TRISA = 0 'Set all PortA Pins as Outputs
    TRISB = 0 'Set all PortB Pins as Outputs
    'Make All PortA and PortB's lights Down, the "&" here means "Clear".
    PORTA = PORTA & %00000000
    PORTB = PORTB & %00000000
    Make PortA and PortB's .0 lights up, the "|" here means "Set".
    PORTA = PORTA | %00000001
    PORTB = PORTB | %00000001
    [This is a powerful concept Bracer, with this you no longer need to do the:
    High PortB.0 crap.
    A single line to clear all and a single line to set all, the ONLY THING YOU MUST
    take note is to line up your LEDs from PortB.7 to PortB.0 in your device instead
    of 0 to 7, this is because as you can see, this one line code is backward, setting
    the last digit to 1 actually set Port*.0 and %10000000 sets Port*.7 to high.
    So to make it easier for you to visualize your
    lights animations [I'm repeating myself here], set your LEDs on your device from
    Port*.7 [Or whatever is the highest port number you use for output] to lowest.
    [This also means that setting:
    PORTA = PORTA | %00100000
    is useless because PortA.5 [Pin 4] can only be use for input detection,
    setting it to high means nothing.
    You can see my Tricorder project here:
    http://www.bracercom.com/wip/content...der/index.html
    It's still very much in WIP but I will be sure to give you credit when I've come to the electronic part of the Tricorder.
    Hi, Bracer
    May be ... you should have a look to NOKIA graphic screens ...costless and ... marvellous color effects ...
    Aug 2010
    NOKIA graphic screens with 16F628a ?
    Wow...I have like no idea how...
    I wouldn't even know how to begin with that.
    Try this Google link to search the forum, I think it has been done in here already.
    http://www.google.com/custom?hl=en&c...ch&sitesearch=
