PIC16F677 and READ/WRITE
Results 1 to 5 of 5
    Nov 2007
    West Covina, CA
    Default PIC16F677 and READ/WRITE
    Hi all,
    I've been using both 16F677 and 16f685 chips as availability allowed with same program without any problems until I introduced the READ and WRITE functions on the 16F677.
    I get the error: Error[113]: Symbol not previously defined (EEPGD)
    The data sheet shows:
    10.1.1 EECON1 AND EECON2 REGISTERS EECON1 is the control register for EE memory accesses. Control bit EEPGD (PIC16F685/PIC16F689/PIC16F690) determines if the access will be a program or data memory access.
    And also when referring to EECON1.7:
    Note 1: PIC16F685/PIC16F689/PIC16F690 only.
    I stripped the code down to a minimum to compile with READ and WRITE commented out or not to see if it compiles without error using PICBasic Pro 2.47 and MPASM.
    This is only a sample routine to demo the compilation error. I hope that someone can shed some light on this.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_ON & _BOR_OFF
    OSCCON = %01001000      ' Oscillator set to 1MHz
    PORTA = %00000000       ' Turn off all PORTA
    ANSEL = 0               ' Sets all PORTA inputs to digital inputs
    TRISA = %00011111       ' Sets all PORTA pins as inputs except RA5
    PORTB = %00000000       ' Turn off all PORTB
    ANSELH = 0              ' Sets analog inputs 8 ~ 11 to digital inputs
    TRISB = %10000000       ' Sets RB4~6 as outputs and RB7 as input
    PORTC = %00000000       ' Turn off all PORTC
    TRISC = %00000000       ' Sets all PORTC pins as outputs
    CM1CON0.7 = 0		    ' Analog comparator #1 off
    CM1CON0.5 = 0           ' Comparator #1 output disabled
    CM2CON0.7 = 0           ' Analog comparator #2 off
    CM2CON0.5 = 0           ' Comparator #0 output disabled
    ADCON0 = 0              ' A/D OFF
    OPTION_REG.7 = 1        ' Global weak pull-up enable bit enabled
    WPUA = %00010111        ' Weak pull-ups enable on PORTA inputs
    WPUB = %00000000        ' Weak pull-ups disabled on PORTB inputs
    '                           Variables
    x       VAR BYTE
    ' Set EEPROM default value at location 2 for 2 Modes at initial program
    ' then this value is user selectable via Mode button.
        EEPROM 2, [2]
        PAUSE 10
    '                           Test loop
    x = 7
    loop:
            READ 2, x
            PAUSE 10
    '        WRITE 2, x
            PAUSE 10
    GOTO loop
    Thank you all for your input...
    Louie
    Nov 2007
    West Covina, CA
    Talking Problem solved?
    I guess this was a tough one and don't feel so bad now. After researching and more searching it became obvious.
    Even though the PIC16F677 has 256 bytes of EEPROM availble but I can't use it because it seems the compiler is trying to use EEPGD that is only used in the rest of the series... Don't use it!
    The PIC16F685, 687, 689 & 690 are only around $0.25 more. Problem solved.
    Louie
    Nov 2007
    West Covina, CA
    Default The need was sure to come back...
    Well as it turns out, just avoiding the problem did not solve it.
    The PIC16F685 does not provide the SSP hardware I'll be needing now so more searching found Darrel's guidance (thanks again Darrel!) http://www.picbasic.co.uk/forum/showthread.php?t=12424
    So comparing both INC files shows that the PIC16F677 was missing the EEPGD in the BANK 3 Register:
    portion of PIC16F685 INC file:
    ;----- BANK 3 REGISTER DEFINITIONS ----------------------------------------
    ;----- EECON1 -------------------------------------------------------------
    EEPGD                        EQU     H'0007'
    WRERR                        EQU     H'0003'
    WREN                         EQU     H'0002'
    WR                           EQU     H'0001'
    RD                           EQU     H'0000'
    same section of PIC16F677 INC file:
    WRERR                        EQU     H'0003'
    WREN                         EQU     H'0002'
    WR                           EQU     H'0001'
    RD                           EQU     H'0000'
    Updated to:
    EEPGD                        EQU     H'0007' ; Added 11/8/2010
    WRERR                        EQU     H'0003'
    WREN                         EQU     H'0002'
    WR                           EQU     H'0001'
    RD                           EQU     H'0000'
    Compiled without errors and I can now use the EEPROM in the PIC16F677!
    A big Thank You! to all who contribute their expertise and time to help others along.
    Louie
    Hi Louie,
    I'm glad you got it working, although I'm not sure how my other post helped.
    Would it help if I mentioned that 2.47 was the first time that family was included in PBP.
    And the 677 EEPROM issue was fixed in PBP version 2.50?
    OK, probably not ...
    ________________
    Nov 2007
    West Covina, CA
    Actually it does...
    It confirms I need to stop dragging my feet and dig out my receipt for Bruce so I can update!
    Louie
