I'm trying to learn DT's Interrupt, from the original I modify a little. I added 2 buttons to trigger the external interrupt.. but don't know how, it works only on Button 1.Can any one tell me what I'm missing?Code:INCLUDE "modedefs.bas" INCLUDE "DT_INTS-14.bas" ; Base Interrupt System INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts TrisB = %00000111 PortB = %00000000 LED1 VAR PORTB.6 x var byte x=0 ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler INT_INT, _ToggleLED1, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE INT_INT ; enable external (INT) interrupts Main: PAUSE 1 High PortB.7 pause 20 low PortB.7 Pause 20 GOTO Main '---[INT - interrupt handler]--------------------------------------------------- ToggleLED1: serout 5,2400, [$FE, 1] serout 5,2400,[254,192] SEROUT 5,2400,[" Val ",#x] ' Send x value to LCD TOGGLE LED1 x=x+1 @ INT_RETURN
thanks in advance
