RA.4 Open collector,...
Results 1 to 15 of 15
    If turning an LED on is tripping reset you might want a larger cap on the reg output or larger series resistor for the LED. BOR definitely shouldn't trip unless you're dropping a lot of power.
    Edit: Check the datasheet for Vbor. You may already be running marginal.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I'll do that this evening, Thanks to everyone for your help.
    I did read about the Vbor, but also in the electrical specifications, it state minimum brown out reset voltage is 3.65V. Using a 3.3V regulator I rekon that cuts that out of the picture.
    Well, I don't mean to get off of my original thread but since I am here and ya'll are reading this...
    When using Darryl Taylors Interrup's and MPASM how does one set the config bits,thats where I can turn it off, I have been using this PBP compiler with sucess :
    @ DEVICE PIC16F628a,XT_OSC
    @ DEVICE pic16F628a, WDT_OFF
    @ DEVICE pic16F628a, PWRT_ON
    @ DEVICE pic16F628a, MCLR_ON
    @ DEVICE pic16F628a, BOD_OFF
    @ DEVICE pic16F628a, LVP_OFF
    @ DEVICE pic16F628a, CPD_OFF
    @ DEVICE pic16F628a, PROTECT_OFF
    I have even opened the 16F628A.INC in the PBP directory and it is turned off with the above added to my code when I compile using MPASM it won't compile, I get a bunch of errors. If I delete the above it compiles fine.
    Meanwhile, I am reading Melanie's post again to see what I've missed: http://www.picbasic.co.uk/forum/cont...o-your-Program
    Thank you
    Aug 2008
    Portugal
    Hi;
    You must do it like this;
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF &_PWRTE_OFF
    See this post;
    http://www.picbasic.co.uk/forum/show...hlight=16f628a
    Thanks and Regards;
    Gadelhas
    Thanks Gadelhas for the fast reply, I tried to compile using that and I get this error:
    @ __CONFIG _XT_OSC & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    CMCON=%00000111
    VRCON = 0
    PAUSEus 10
    TRISA = %00000110
    TRISB = %11110001
    PORTA = %00000000
    PORTB = %00000000
    OPTION_REG.7 = 0
    OPTION_REG.6 = 0
    rf var porta.4
    low rf
    high rf
    Error[118]c:\program~1\testled.asm 83 : overwriting previous address contents (2007)
    What does this mean?
    Many Thanks
    Perhaps I could use the external brown out protection with the 3.3V regulator as shown on the datasheet, I like the Example2 version.
    Aug 2008
    Portugal
    Hi;
    To not give that error you need to go to the file of your pic model in the PBP directory and comment that line, like this;
    ;*  16F628A.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2003 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 11/06/03                                        *
    ;*  Version   : 2.45                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F62xA.INC'  ; PM header
            device  pic16F628A, xt_osc, wdt_on, mclr_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F628A, r = dec, w = -302
            INCLUDE "P16F628A.INC"  ; MPASM  Header
            ;__config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF '- COMENT THIS LINE WITH ";" ATE THE BEGINNING
            NOLIST
            LIST
    Thanks and Regards;
    Gadelhas
