Setup baudrate on hardware uart on 18F4520
Results 1 to 2 of 2
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Default Setup baudrate on hardware uart on 18F4520
    Hello
    With this code i init the uart, suposed with the baudrate 2400, but on the Microcode communication Tool it works correctly only if i select 9600.
    Anyone know what is the problem?
    Thanks for explanation
    Best regards
    Pedro
    DEFINE OSC 16
    INCLUDE "modedefs.bas"
    INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    INT_LIST macro
    INT_Handler RX_INT, _IntRx, PBP, yes
    INT_CREATE
    @ INT_ENABLE RX_INT
    ' Initialize USART
    TRISC = %10111111 ' Set TX (PortC.6) to out, rest in
    SPBRG = 25 ' Set baud rate to 2400
    RCSTA = %10010000 ' Enable serial port and continuous receive
    TXSTA = %00100000 ' Enable transmit and asynchronous mode
    Pedro Pinto Guest
    Hello again
    Problem is solved reading a old post and thanks PicMultiCalc program
    Best regards
    Pedro
