Help on PIC16F767
Results 1 to 11 of 11
    Feb 2007
    Default Help on PIC16F767
    Dear all,
    i am facing a problem when using the PIC16F767: when i touch the oscillator pin and remove my finger, it stops running !! usualy when touching this pin the PIC stops runing (any other pic number) and when removing the finger it resumes. (i know it is not necessary to touch it but sometimes it is happening alone, and touching it is instead of waiting few minutes to happen alone), any help for that ??
    Hi, Rony ...
    Could you, please, provide your program header ??? ( ALL configs + pins assigned )
    Feb 2007
    DEFINE OSC 20
    PORTA = %00000000
    PORTB = %00000000
    PORTC = %00000000
    TRISA = %10111111
    TRISB = %00000000
    TRISC = %10100010
    OPTION_REG = %00000111
    INTCON = %00000000
    ADCON0 = %00000000
    ADCON1 = %00001111
    ADCON2 = %00000000
    CMCON = %00000111
    T1CON = %00000000
    TMR2 = 0
    PR2 = 0
    CCPR1L = 0
    CCPR2L = 0
    CCPR3L = 0
    CCP1CON = 0
    CCP2CON = 0
    CCP3CON = 0
    T2CON = 0
    PIR1 = 0
    PIR2 = 0
    PIE1 = 0
    PIE2 = 0
    PCON = %00000011
    Feb 2007
    i think it is not stoping, but it is going very very very slow.....
    Feb 2007
    i forget to say:
    i changed the Oscillator, i tried with a resonator, i put a 100nF on the + and - very near to the PIC, i tried with 8MHz ... without sucess
    Feb 2007
    i am using the following:
    @ device pic16F767, hs_osc, wdt_off, pwrt_on, protect_on, mclr_off
    lvp_off is not applicable with this PIC
    => same problem
    Aug 2008
    Portugal
    HI;
    Try put this on the header, before the oscilator Define, and them test!
    @ __config _HS_OSC & _LVP_OFF
    Thanks and Regards;
    Gadelhas
