Embedded strings in code mpasm error
Results 1 to 10 of 10
    malc-c's Avatar
    malc-c Guest
    Not that I have the answer, but if you could inform us what the target PIC is it might helpw those with more knowledge than I to advise.
    My guess is that you need to edit the associated .INC file for the chip you are using by commenting out the config lines. This file is located in the PBP folder.
    EG:
    ;*  18F4580.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2008 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 09/15/08                                        *
    ;*  Version   : 2.60                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F4580, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F4580.INC"	; MPASM  Header
            ;__CONFIG    _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            ;__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
            ;__CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
            ;__CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_1024_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	8
    Also... if using microcode studio to edit... make sure you have the correct target chip selected
    Hi, Brian
    As Malc gently tells ...
    I am totally unable to understand what you are talking about... as long as your project is " top secret classified " !!!
    Could you provide a piece of program with config part, and enough to understand what you try to do ... ???
    I only suppose the " MCP23S17 " secret code appears somewhere ...
    Could this help ??? http://www.picbasic.co.uk/forum/show...951&pagenumber=
    Ok ... once more Darrel has striken here ... http://www.pbpgroup.com/modules/wfse...p?articleid=10
    Jul 2010
    My chip is a 18f4620.
    This is basically the code (Below) I am trying to use. It did work just a few days ago but now is compiling with the error I had listed.
    Really I am only posting the part of the code that is failing to compile. Problem with "Wout".
    '*  Name    : STRINGS-16.PBP                                    *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 6/12/2005                                         *
    '*  Note:  Strings must be NULL Terminated                      *
    DEFINE LOADER_USED 1       ' If using bootloader
    DEFINE HSER_TXSTA  24h     ' Use this for Higher Baud Rates
    DEFINE HSER_SPBRG  25      ' 9600 Baud at 4mhz
    Addr        var word
    Char        var byte
    Clear
    goto StartLoop ' Required
    String1:
    @ da "This is a string",0
    AnotherString:
    @ da "Here is another string",0
    '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout       ; Returns the Address of a Label as a Word
        CHK?RP Wout
        movlw low Label
        movwf Wout
        movlw High Label
        movwf Wout + 1
    StartLoop  ' This loop repeats continuously just as a test.
       @ GetAddress _String1, _Addr        ' Get address of String
       gosub StringOut                     ' Send the String
       hserout [13,10]                     ' New Line
       @ GetAddress _AnotherString, _Addr  ' Get address of String
    goto StartLoop                         ' Repeat
    StringOut:  ' Send the string out via Hserout
        Readcode Addr, Char           ' Get a character
        if Char  = 0 then StringDone  ' Look for Null char, Stop if found
        hserout [Char]                ' Send char
        Addr = Addr + 1               ' Point to next character
        goto StringOut                ' Continue with rest of the string
      StringDone:
    Is Wout defined as a VAR?
    In the ASM part
    _Wout
    Jul 2010
    It is used in C:\PBP\PBPPI18L.LIB but does not seem to be declared as a var in that file.
    In the ASM part
    _Wout
    Hi, Brian
    Darrel's code compiles without any problem, either with MPLAB 8.56 or MCS
    PBP is 2.60 a
    soooo ... error is elsewhere ...
    Jul 2010
    It compiles fine on my laptop too, and did compile on my work computer also. But not today. Now it is giving those stated errors and I'm trying to track down what is causing it. I am trying to figure out why "wout" is showing up as not defined on my work computer.
    Brian
    Hi, Brian
    PBP is 2.60 a
