I'm not using an interrupt as such I'm polling the Timer1 flag.
Some code extracts here below
My Serin2 command is here in the code.Code:Initialise: 'Initialise 250ms Timer 8mhz clock PreLoad = 3035 'Preload Constant Loads Timer with 3035 to get 250ms ticks PIE1.0 = 1 'Enable TMR1 Interrupts (Not sure about this) TMR1L = PreLoad.LowByte 'Load the Timer with preload value TMR1H = PreLoad.HighByte 'Load the Timer with preload value TMR1IF = 0 'Clear TMR1 int flag
So you can see i intialise the timer for 250ms ticks. Then poll the flag. If it is set then I execute some code and then reinitialise the timer adding any overrun to the preload value.Code:IF TMR1IF = 0 THEN TimerJump 'If 250ms has not elapsed then jump over below section T1CON.0=0 'Stop the Clock TMR1RunOn.Highbyte = TMR1H 'Load the Run-On (Over-Run) value (if any) TMR1RunOn.Lowbyte = TMR1L 'Load the Run-On (Over-Run) value (if any) TMR1RunOn = PreLoad + TMR1RunOn 'Calculate new Preload setting to include any timer overrun TMR1H = TMR1RunOn.HighByte 'Load the timer with new value TMR1L = TMR1RunOn.LowByte 'Load the timer with new value T1CON.0=1 'Restart the Clock TMR1IF = 0 'Clear TMR1 int flag 'PIR1.0=0 'Reset TMR1's Interupt Flag (Not sure about this)
