Need help with interrupt
Results 1 to 7 of 7
    Oct 2008
    Default Need help with interrupt
    I'm trying to learn DT's Interrupt, from the original I modify a little. I added 2 buttons to trigger the external interrupt.. but don't know how, it works only on Button 1.
    INCLUDE "modedefs.bas"
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    TrisB = %00000111
    PortB = %00000000
    LED1   VAR  PORTB.6
    x      var  byte
    x=0
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
      PAUSE 1
      High PortB.7
      pause 20
      low PortB.7
      Pause 20
    GOTO Main
    ToggleLED1:
         serout 5,2400, [$FE, 1]
         serout 5,2400,[254,192]
         SEROUT 5,2400,[" Val ",#x] ' Send x value to LCD
         TOGGLE LED1
         x=x+1
    @ INT_RETURN
    Can any one tell me what I'm missing?
    thanks in advance
    Aug 2008
    Portugal
    Quote Originally Posted by mbox View Post
    TrisB = %00000111
    PortB = %00000000
    LED1   VAR  PORTB.6
    x      var  byte
    x=0
      PAUSE 1
      High PortB.7
      pause 20
      low PortB.7
      Pause 20
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
         x=x+1
    @ INT_RETURN
    thanks in advance
    I only can see one button connected to External Interrupt RB0. PIC16F628, only haves 1 External Interrupt, that is the RB0 Pin. The other butons that you add to the circuit, will not work as interruopt.
    Thanks and Regards;
    Gadelhas
    Oct 2008
    Quote Originally Posted by gadelhas View Post
    Hi gadelhas, thanks for the quick reply.
    Lightbulb
    Hi, Folks
    I think something has to be cleared ...
    You also can get " interrupt on change " interrupt with Port B.4 to B.7 ... or ' comparator interrupts" from the Comparator inputs ...
    so, the 3 buttons can generate their own interrupt ...
    Obviously the scheme has to be modified to place the buttons on the right pins ....
    Aug 2008
    Portugal
    Hi, Folks
    Not only the sheme but also the interrupt source on PBP code. Instead of INT_INT, must put RBC_INT, to make it Interrupt on PortB Change.
    Thanks and Regards;
    Gadelhas
    Mar 2009
    so you need two buttons to generate an interrupt?
    I've just been through all this pain & rx'ed a lot of help on my recent thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=13558
    To summarise....you can have two switches connected to just the one PIC 'INT' pin - but you'll need to connect some diodes if going that way (I posted a schematic on the above thread).
    Else, as Bruce kindly informed me on that very thread, you can use Interrupt on Change...which was a little more involved (but not a whole lot more)...& which doesn't need diodes & gives you a whole lot more options wrt which PIC pins you can connect your switches to.
    Oct 2008
    Quote Originally Posted by HankMcSpank View Post
    Thanks guys for the support, I will explore more on this when I get home...
