Transmission!
Results 1 to 7 of 7
Thread: Transmission!
    according to me i just have to serially send data to the radio and then it will transmit it. No more extra connections required. i just wanna know the particular commands for sending serial data (i.e through tx and rx pins of port c).
    serout2
    hserout
    How are you going to use the devices?
    Do you have your own board or using the DIGI's dev kit?
    The XBees require TTL Serial connection, not inversed by a driver when connecting to a microcontroller.
    I suggest use the dev. kit to test them and set parameters, then connect to a micro.
    May 2010
    Thanks Mack for the commands. But can u tell me precisely how to use them? Should there be some defines before i use these serial out commands? I have given the code, can you manipulate it accordingly?
    I have Xbee XBIB board for one radio while ill plug the other radio in my own board where the microcontroller is placed (off course). I can set the parameters of my radio through this board and device software given by DIGI.
    Quote Originally Posted by uaf5000 View Post
    Hmmmm
    I do not normally say this but.... RTFM
    Then let us know the parts you do not understand.
    HSERIN does have defines.
