Hello
I'm trying to write a set of universal subroutines that I can transfer different predefined output pins into as opposed to writing a number of subs that except for pin designations and variables look almost the same. I'm using the "MIBAM" setup but this could be applied to any regular code. I tried to alias the pin names. That made all of the outputs sequentially active but I couldn't find a way to "un" alias those pins and so have no program control.
I also tried to use the original sample array variables in the for next loops (a piece of the code is shown below) but got an error message saying that
"array variables are not allowed in for next loops". That was a surprise.
Is there anyway of doing what I think that I may have explained here?
THANKS
'using MPASM and array variables
'does not work
x = 1
N = 0
FOR objectb[x] = Brightness to N STEP -1 ; Ramp down 1 by 1
PAUSE Speed
NEXT objectb[x]
'MIBAM CODE
' array removed test
@__config_HS_OSC ;& _WDT_OFF & _PWRTE_ON & _LVP_OFF & _BODEN_OFF
;----[ MIBAM Setup ]--------------------------------------------------------
;____[ For 12F/16F only - Interrupt Context save locations]_________________
wsave var byte $20 SYSTEM ' location for W if in bank0
;wsave var byte $70 SYSTEM ' Alternate save location for W
' if using $70, comment out wsave1-3
' --- IF any of these next three lines cause an error ?? -------------------
' Comment them out to fix the problem ----
' -- The chip being used determines which variables are needed -------------
wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
'wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3
'---DO NOT change these-----------------------------------------------------
ssave VAR BYTE BANK0 SYSTEM ' location for STATUS register
psave VAR BYTE BANK0 SYSTEM ' location for PCLATH register
BAM_COUNT CON 13 ; How many BAM Pins are used?
INCLUDE "MIBAM.pbp" ; Mirror Image BAM module
CMCON = 7
DEFINE OSC 20
mybyte var byte
K var byte
B var byte
W var byte
J var byte
N var byte
'Speed var byte
X var word
CenterSW VAR PORTB.0 'input switch
Uni0 var byte
Uni1 var byte
Uni2 var byte
Uni3 var byte
Uni4 var byte
Uni5 var byte
Uni6 var byte
Uni7 var byte
Uni8 var byte
Uni9 var byte
Uni10 var byte
TRISB = %00000001 'SW INPUT
TRISA = %00000000
BAM_LIST macro ; Define PIN's to use for BAM
;BAM_PIN PORTB, 0, _
BAM_PIN PORTB, 1, _RaR
;BAM_PIN PORTB, 2, _
BAM_PIN PORTB, 3, _RaL
BAM_PIN PORTB, 4, _NosLR
BAM_PIN PORTB, 5, _RaC
BAM_PIN PORTB, 6, _RaH
BAM_PIN PORTB, 7, _Mo
BAM_PIN PORTA, 0, _LgC
BAM_PIN PORTA, 1, _LgB
BAM_PIN PORTA, 2, _LgA
BAM_PIN PORTA, 3, _WinR
BAM_PIN PORTA, 4, _WinL
BAM_INIT BAM_LIST ; Initialize the Pins
Speed CON 1 ; Smaller = Fasterspeed
Brightness CON 255 ; Max DutyCycle
Main: 'initialize
RAbank:
RaR var uni1 'do Rabank
RaC var Uni2
RaL var Uni3
RaH var Uni4
gosub Universalsub:
LGbank: 'do LGbank
LgA var uni1
LgB var Uni2
LgC var Uni3
gosub Universalsub:
WINbank:
WinL var uni8 'do WINbank
WinR var Uni9
NosLR var Uni10
Mo var uni10
Universalsub: 'universal routine
For J = 1 to 60
FOR Uni1 = Brightness to N STEP -1 ; Ramp down 1 by 1
gosub check
PAUSE Speed
NEXT Uni1
FOR Uni2 = Brightness to N STEP -1
gosub check
PAUSE Speed
NEXT Uni2
FOR Uni3 = Brightness to N STEP -1
gosub check
PAUSE Speed
NEXT Uni3
FOR Uni1 = N to Brightness -1 ; Ramp up 1 by 1
gosub check
PAUSE Speed
NEXT Uni1
FOR Uni2 = N to Brightness -1
gosub check
PAUSE Speed
NEXT Uni2
FOR Uni3 = N to Brightness -1
gosub check
PAUSE Speed
NEXT Uni3
Next J
check: 'dummied out for now
GOTO Main
