Need help with Pot command
Results 1 to 3 of 3
Threaded View
    Oct 2008
    Default Need help with Pot command
    Hi everyone, I want to learn how to use POT command so I tried some codes and try also to simulate it on protues.
    Include "modedefs.bas"	' Include serial modes
    TRISB =%00000001
    Portb =%00000000
    ' Allocate variables
    x Var Byte
       CMCON = 7     ' Set PORTA to digital
       Pause 100     ' Wait for LCD to start
    mainloop:
       Pot PORTB.0, 127, x
       Serout PortB.1,T9600, [$Fe,1]
       serout PortB.1,T9600,[" Pot ",#x] ' Send value to LCD
       Pause 100                 ' for delays
       Goto mainloop             ' Do it again
    I tried to play around with the variable potentiometer to see if its displays varies, but it jumps from 2-8-15-47-255. How can I make it increment by 1 to have a smooth display to 255? I tried to change the pot resistance between 5-10K but no luck.
