serial coms - again
Results 1 to 40 of 58
    malc-c's Avatar
    malc-c Guest
    Any reason why
    hserout [#StartHour[0] DIG 1,#StartHour[0] DIG 0,#StartMin[0] DIG 1,#StartMin[0] DIG 0]
    compiles, but
    hserin [#StartHour[0] DIG 1,#StartHour[0] DIG 0,#StartMin[0] DIG 1,#StartMin[0] DIG 0]
    Throws up an "expected ]" error. I've tried adding ] to nearly all possible permutations and still can't get it nto compile
    Bombay, India
    Hi Malc_c
    I was curious to see this thread and got into this pretty late.
    How big is the serial data packet that you send down to the PIC?
    From the details you gave, I think you have problems PC->PIC (downstream)
    If that is true, are you buffering your received characters on the PIC? If not, then the least you can do is make the PC space out the characters in time. Put a few mS gap between each character sent to the PIC to avoid losing characters on the PIC
    How do you synch the receive to the start of the incoming stream of data? Do you have a synch character to look for?
    It will be better to look over the whole code to find the problem.
    malc-c's Avatar
    malc-c Guest
    Hi and thanks for the advice. The PC application simply send "Q" to the PIC every 10 seconds. The PIC responds to the Q by sending the 100 odd digits for the variables as described in previous posts above. When the application is used to update or set the PIC, the application has an "update" button which sends an "S" followed by the same 100 odd digits, followed by a "Q" to read back the values just written. The application does not send variable data to the PIC at any other time.
    I agree that it's difficult to diagnose what might be happening without the complete code - please drop me a PM with an e-mail address and I'll mail you the code.
    Bombay, India
    Hi Malcolm
    PM sent. Just in case you don't get it, you can PM me
    malc-c's Avatar
    malc-c Guest
    Jerson, and Henrik for the PM's - I've responded via e-mail
    Many thanks
    malc-c's Avatar
    malc-c Guest
    OK I'm at a loss - I don't know if it's the code that's the problem, the PIC, or the development board.
    The corruption now appears to be limited to just the bottom line of the 4 x 20 LCD. I've noticed that it tends to over-write the clock that's down in the bottom left of the display
    The normal display looks like
    Yet sometimes at random time the clock got over-written for a split second and the sometime sets points will revert back to 00, like this, sometimes
    This is even when running without the serial cable connected. When I've got the serial cable hooked up and the 27th Q is sent the PIC either reboots and the LCD screen looks like the one above, or it doesn't reboot but displays a scrolling garbage like
    Thinking it might be a problem with the LCD I took the one out of my prototype controller that's been used to keep my snakes warm... this too displays the same issue when plugged into the EasyPIC5 board.
    So.. I started loading the same version of HEX that has been running in the prototype for the past two months (which has the original coms DT wrote for use with Hyperterm and doesn't use the PC app Charles has produced) and that too over-wrote the clock leaving 15 after the minutes.
    OK maybe the RTC module I'm using is causing the issue, possibly corrupting the values
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]  ; read DS1307 chip
    If RTCHour.6=1 then
    CounterA=(RTCHour>>4)&$01                           ' Work-Out 12 or 24 hour Display for Hours
    CounterA=(RTCHour>>4)&$03
    CounterA=CounterA*10+(RTCHour&$0F)                  ' Display Hours appropriately for 12 or 24 hour Mode
    If RTCHour.6=1 then
    LCDOut $FE,$D4,#CounterA
    LCDOut $FE,$D4,#CounterA Dig 1,#CounterA Dig 0
    LCDOut ":",#(RTCMin>>4)&$0F,#RTCMin&$0F
    for arguments sake it could be writing 26:6415 (which once on setting the time I found the variables used to equal such stupid numbers) and the when it goes back to displaying 16:26 the 15 is left behind - no problem, I can simply add LCDOut $FE,$D4+5," " to over-write it... BUT this doesn't explain why when I send Q to the PIC manually via the Hyperterm program, or use Charlies PC application to poll the PIC that it re-boots on the 27th Q, even when the DS1307 module has been removed.
    The way I can tell it reboots is that after all the initialization, the first thing the PIC does is jump to an "about" subroutine that simply displays the current version of the code on the LCD, then jumps to the main program loop, so it has to be reset to display this screen.
    Note:
    I've subsequently moved the section which reads the stored values for each variable so now when it reboots the set temperatures are no longer zeroed as shown in the second image.
    Bombay, India
    Hi Malcolm
    Can you try to just slow down the updates to LCD to say once every second? Sometimes updating the LCD too quickly can cause such behaviour
    Jerson
