Try running it a slower baud rate, just as a test - say 2400 baud.
It is because you just say HSERIN [DEC Normtemp[0]] so PBP grabs the first character which is 7 - change that to DEC3 to grab three digits and properly convert it to 789.One thing I have noticed, When I simplify the code to simply read the variable and send say S789 from the serial communicator the LCD changes but displays 007 as if it's picked up the 1st byte and then ignored the rest.
And this is because you removed the DEC modifier so PBP again grabs one character and 55 is the ASCII code for "7".If I change the HSERIN line by removing DEC statement the LCD displays 055 ???? - I was expecting at least 078 ???
You have to remember that the PC (in this case) doesn't send the "value" 789 it sends the the individual digits representing the number as text "S", "7", "8", "9" if you look at that transmision with your serial port monitor you'll see that what is sent is 83 55 56 57 which are the ASCII codes for S789.
The DEC modifier converts the text representation of the value into an actual value. If you remove it the value stored in the variable will be the value received - which is 55 when you send "7".
