serial coms - again
Results 1 to 40 of 58
    malc-c's Avatar
    malc-c Guest
    Paul, thanks once again for the reply.
    To simplify the testing between the applicatication this chap in Canada has written and my PBP code I've gone back to basics and written a simple test application that simply sends the output to the PC and then test the updating from the PC application.
    ;----[USART defines]--------------------------------------------------------
    DEFINE HSER_RCSTA 90h                           ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 20h                           ' Enable transmit, BRGH = 0
    DEFINE HSER_CLROERR 1                           ' Clear overflow automatically
    DEFINE HSER_SPBRG 25                            ' 115200 Baud @ 48MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1                                   ' Enable 16 bit baudrate generator
    ColumnWidth CON 10
    TempWD            VAR WORD
    RCIF              VAR PIR1.5                    ' USART receive flag
    GIE               VAR INTCON.7
    alarmhigh         VAR WORD[4]                   ' used to store the desired high temp alarm values
        alarmhigh1       VAR alarmhigh[0]
        alarmhigh2       VAR alarmhigh[1]
        alarmhigh3       VAR alarmhigh[2]
        alarmhigh4       VAR alarmhigh[3]
    alarmlow        VAR WORD[4]                   ' used to store the desired low temp alarm values
        alarmlow1       VAR alarmlow[0]
        alarmlow2       VAR alarmlow[1]
        alarmlow3       VAR alarmlow[2]
        alarmlow4       VAR alarmlow[3]
    lightsetHR          VAR WORD[4]                 ' user to set light on hour
      lightsetHR1       VAR lightsetHR[0]
      lightsetHR2       VAR lightsetHR[1]
      lightsetHR3       VAR lightsetHR[2]
      lightsetHR4       VAR lightsetHR[3]
    lightsetMN          VAR WORD[4]
      lightsetMN1       VAR lightsetMN[0]
      lightsetMN2       VAR lightsetMN[1]
      lightsetMN3       VAR lightsetMN[2]
      lightsetMN4       VAR lightsetMN[3]
    lightoffHR          VAR WORD[4]
      lightoffHR1       VAR lightoffHR[0]
      lightoffHR2       VAR lightoffHR[1]
      lightoffHR3       VAR lightoffHR[2]
      lightoffHR4       VAR lightoffHR[3]
    lightoffMN          VAR WORD[4]
      lightoffMN1       VAR lightoffMN[0]
      lightoffMN2       VAR lightoffMN[1]
      lightoffMN3       VAR lightoffMN[2]
      lightoffMN4       VAR lightoffMN[3]
    StartHour	         VAR WORD[4]
      StartHour1         VAR StartHour[0]
      StartHour2         VAR StartHour[1]
      StartHour3         VAR StartHour[2]
      StartHour4         VAR StartHour[3]
    StartMin             VAR WORD[4]
      StartMin1          VAR StartMin[0]
      StartMin2          VAR StartMin[1]
      StartMin3          VAR StartMin[2]
      StartMin4          VAR StartMin[3]
    StopHour   	         VAR WORD[4]
      StopHour1          VAR StopHour[0]
      StopHour2          VAR StopHour[1]
      StopHour3          VAR StopHour[2]
      StopHour4          VAR StopHour[3]
    StopMin     	     VAR WORD[4]
      StopMin1           VAR StopMin[0]
      StopMin2           VAR StopMin[1]
      StopMin3           VAR StopMin[2]
      StopMin4           VAR StopMin[3]
    Droptemp	     VAR WORD[4]
    droptemp1     var Droptemp[0]
    droptemp2       var Droptemp[1]
    droptemp3       var Droptemp[2]
    droptemp4       var Droptemp[3]
    Temperatures      VAR WORD[4]
      Temp1           VAR Temperatures[0]
      Temp2           VAR Temperatures[1]
      Temp3           VAR Temperatures[2]
      Temp4           VAR Temperatures[3]
    SetPoints         VAR WORD[4]                   ' used to store the desired temperature setting
      SetPoint1       VAR SetPoints[0]
      SetPoint2       VAR SetPoints[1]
      SetPoint3       VAR SetPoints[2]
      SetPoint4       VAR SetPoints[3]
    normtemp          VAR WORD[4]                   ' used to store the desired temperature setting
      normtemp1       VAR normtemp[0]
      normtemp2       VAR normtemp[1]
      normtemp3       VAR normtemp[2]
      normtemp4       VAR normtemp[3]
    FlashStar         VAR BIT
    nTest var byte
    ;set test values
    Temperatures[0]=230
    Temperatures[1]=240
    Temperatures[2]=250
    Temperatures[3]=260
    normtemp[0]=240
    normtemp[1]=250
    normtemp[2]=260
    normtemp[3]=270
    alarmlow[0]=180
    alarmlow[1]=180
    alarmlow[2]=180
    alarmlow[3]=180
    alarmhigh[0]=360
    alarmhigh[1]=360
    alarmhigh[2]=360
    alarmhigh[3]=360
    StartHour1=00
    StartHour2=00
    StartHour3=00
    StartHour4=00
    StartMin1=00
    StartMin2=00
    StartMin3=00
    StartMin4=00
    StopHour1=00
    StopHour2=00
    StopHour3=00
    StopHour4=00
    StopMin1=00
    StopMin2=00
    StopMin3=00
    StopMin4=00
    Droptemp[0]=180
    Droptemp[1]=180
    Droptemp[2]=180
    Droptemp[3]=180
    lightsetHR1=00
    lightsetHR2=00
    lightsetMN1=00
    lightsetMN2=00
    lightoffHR1=00
    lightoffHR2=00
    lightoffMN1=00
    lightoffMN2=00
      ;______________________________________________________________
    If PIR1.5 = 1 Then 'check to see if there is data in the serial buffer
    	HSERIN[nTest]
    	if nTest = "S" then
    gosub Term_RX
    for tempwd = 0 to 3
    setpoints(tempwd)=normtemp(tempwd)
    next
    LCDOut $FE,$D4+8,#setpoints(0)dig 2,#setpoints(0)dig 1,$FE,$D4+11,#setpoints(1)dig 2,#setpoints(1)dig 1  ' show current set temperatures
    LCDOut $FE,$D4+14,#setpoints(2)dig 2,#setpoints(2)dig 1,$FE,$D4+17,#setpoints(3)dig 2,#setpoints(3)dig 1
    LCDOUT $FE,$80 + 18,("*"&FlashStar*$FF)|(" "&~(FlashStar*$FF)) ; flash a star to show sample time, but used to indicate Alarm settings monitored
        FlashStar = !FlashStar
    Hserout [DEC3 Temperatures[0]]
    Hserout [DEC3 Temperatures[1]]
    Hserout [DEC3 Temperatures[2]]
    Hserout [DEC3 Temperatures[3]]
    HSEROUT [dec3 normtemp[0]]
    HSEROUT [dec3 normtemp[1]]
    HSEROUT [dec3 normtemp[2]]
    HSEROUT [dec3 normtemp[3]]
    Hserout [dec3 alarmlow[0]]
    Hserout [dec3 alarmlow[1]]
    Hserout [dec alarmlow[2]]
    Hserout [dec alarmlow[3]]
    Hserout [dec3 alarmhigh[0]]
    Hserout [dec3 alarmhigh[1]]
    Hserout [dec3 alarmhigh[2]]
    Hserout [dec3 alarmhigh[3]]
    hserout [#StartHour[0] DIG 1,#StartHour[0] DIG 0,#StartMin[0] DIG 1,#StartMin[0] DIG 0]
    hserout [#StartHour[1] DIG 1,#StartHour[1] DIG 0,#StartMin[1] DIG 1,#StartMin[1] DIG 0]
    hserout [#StartHour[2] DIG 1,#StartHour[2] DIG 0,#StartMin[2] DIG 1,#StartMin[2] DIG 0]
    hserout [#StartHour[3] DIG 1,#StartHour[3] DIG 0,#StartMin[3] DIG 1,#StartMin[3] DIG 0]
    hserout [#StopHour[0] DIG 1,#StopHour[0] DIG 0,#StopMin[0] DIG 1,#StopMin[0] DIG 0]
    hserout [#StopHour[1] DIG 1,#StopHour[1] DIG 0,#StopMin[1] DIG 1,#StopMin[1] DIG 0]
    hserout [#StopHour[2] DIG 1,#StopHour[2] DIG 0,#StopMin[2] DIG 1,#StopMin[2] DIG 0]
    hserout [#StopHour[3] DIG 1,#StopHour[3] DIG 0,#StopMin[3] DIG 1,#StopMin[3] DIG 0]
    Hserout [dec3 Droptemp[0]]
    Hserout [dec3 Droptemp[1]]
    Hserout [dec3 Droptemp[2]]
    Hserout [dec3 Droptemp[3]]
    hserout [#lightsetHR[0] DIG 1,#lightsetHR[0] DIG 0,#lightsetMN[0] DIG 1,#lightsetMN[0] DIG 0]
    hserout [#lightsetHR[1] DIG 1,#lightsetHR[1] DIG 0,#lightsetMN[1] DIG 1,#lightsetMN[1] DIG 0]
    hserout [#lightoffHR[0] DIG 1,#lightoffHR[0] DIG 0,#lightoffMN[0] DIG 1,#lightOFFMN[0] DIG 0]
    hserout [#lightoffHR[1] DIG 1,#lightoffHR[1] DIG 0,#lightoffMN[1] DIG 1,#lightOFFMN[1] DIG 0]
    pause 200
    Term_RX:
    HSERin [dec3 normtemp[0]]
    The application is simply sending S followed by three digits for normtemp[0] in DEC format, with no carriage returns - However when I click the update button of the application the PIC freezes for around 10 min. I've proved the PIC is responding to the PC app by changing the "S" to "X" (or any other character) which is ignored when the update button is pressed.
    Unfortunately given the time difference (I'm in the UK he's in Canada) the logistics of implementing the suggestions of handshaking the way you suggest is not forthcoming.
    Any suggestions
    Feb 2010
    USA, New England
    Hi Malcom,
    Try changing the end of your code to this:
    Term_RX:
    	TempWD = 0
    	HSERIN 1000,RX_Bombed,[DEC3 TempWD]
    	normtemp[0] = TempWD
    RX_Bombed:
    	HSEROUT ["Term_RX bombed out, all we got was", dec TempWD,13,10]
    This should at least provide some insight into what's going on inside the PIC.
    In your test application you ought to put a pause of at least 10 msec or so between when the "S" and the rest of the data are sent. You could also probably test this using the Serial Communicator inside of MicroCode Studio, if you have that. Hyperterm would also work.
    I couldn't find your OSC define in this thread. Which oscillator speed are you using?
    Oh, and DOH! I just recalled that I think you "terminate" the DEC3 by sending something that isn't a numeric ASCII character. Try sending a carriage return or a line feed after the 3-character value.
    Best Regards,
    Paul
    malc-c's Avatar
    malc-c Guest
    Default Banging head against wall !
    This is really doing my head in... My friends application simply sends Q on launch, and the S+three digits representing the new value for just one variable followed by Q. Yet I keep getting incorrect values in the receive variable.
    Here's the test code. For testing purpose all the values for each variable is fixed to populate his PC application. The only variable that is updated is the Target Temperature for Unit 1.
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 48                     ; uses 12Mhz xtal
    ADCON1 = $0F
    clear
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    ;----[Port settings]----------------------------------------------------
    TRISA = %11001111
    TRISB = %00000000
    TRISD = %00001111
    CMCON = 7                                       ' disable Comparators
    SPBRGH = 0
    ColumnWidth CON 10
    TempWD            VAR WORD
    GIE               VAR INTCON.7
    tr var byte
    StopMin     	     VAR WORD[4]
    droptemp4       var Droptemp[3]                 ; these will be set via pots
    spModes           VAR BYTE[4]                   ' controls how set point is adjusted PC or POT
      spMode1         VAR spModes[0]
      spMode2         VAR spModes[1]
      spMode3         VAR spModes[2]
      spMode4         VAR spModes[3]
    FlashStar         VAR BIT
    nTest var byte
    temphold var byte
    temp var byte
    ;set test values
    Temperatures[0]=230
    Temperatures[1]=240
    Temperatures[2]=250
    Temperatures[3]=260
    normtemp[0]=240
    normtemp[1]=250
    normtemp[2]=260
    normtemp[3]=270
    alarmlow[0]=180
    alarmlow[1]=180
    alarmlow[2]=180
    alarmlow[3]=180
    alarmhigh[0]=360
    alarmhigh[1]=360
    alarmhigh[2]=360
    alarmhigh[3]=360
    StartHour1=00
    StartHour2=00
    StartHour3=00
    StartHour4=00
    StartMin1=00
    StartMin2=00
    StartMin3=00
    StartMin4=00
    StopHour1=00
    StopHour2=00
    StopHour3=00
    StopHour4=00
    StopMin1=00
    StopMin2=00
    StopMin3=00
    StopMin4=00
    Droptemp[0]=180
    Droptemp[1]=180
    Droptemp[2]=180
    Droptemp[3]=180
    lightsetHR1=00
    lightsetHR2=00
    lightsetMN1=00
    lightsetMN2=00
    lightoffHR1=00
    lightoffHR2=00
    lightoffMN1=00
    lightoffMN2=00
    FOR TempWD = 0 TO 1000
    IF RCIF=1 THEN GOSUB Term_RX
    PAUSE 2
    NEXT TempWD
    setpoints(0)=normtemp(0)
    LCDOut $FE,$D4,#setpoints(0)dig 2,#setpoints(0)dig 1,#setpoints(0)dig 0
    pause 200
    send:
    Term_RX:
        HSERIN[nTest]
        SELECT CASE nTest
        CASE "S"
                HSERIN [normtemp[0]]
                setpoints(0)=normtemp[0]
        END SELECT
        gosub send
    On booting the PIC it displays the value of normtemp[0] as 240 on the LCD. I've used a serial port monitor and when the application is launched the port sniffer confirms that Q was sent and the PIC dumped the string of values to the port, which the application pics up and populates the text boxes correctly.
    The application has been written to allow the user to enter the desired target temperature directly in the associated text box as required such as 45.2 and then click on the UPDATE button. This then sends S followed by the new value as a three digit number in the same format as the PBP code. This can be confirmed by the port sniffer
    However, the LCD display then reads 052, and this is then sent back to the PC application (as can be seen if you follow through the digits in the com sniffer top window.
    I think by fluke I did manage to get it to work once where the normtemp[0] variable was correctly updated, but that was after a restart of both the windows application and the PIC. What's been suggested is that I need the PBP code to check that the PICs buffer is empty, but I'm not sure on how to best do that.
    Eventually we need to be able to update all the values in the rest of the boxes, and it my understanding my friends application will simply send all the values back in one data stream that will match the same as that transmitted (less the first 12 digits as it doesn't need to update the current temperatures - this is a one way transmission from the PIC). Thus the RX section will have HSERIN for each variables as per the HSEROUT section - will this compound the problem or can someone suggest a better way of doing this.
    Hi Malcolm,
    I think you need to do:
    HSERIN [DEC3 NORMTEMP[0]]
    EDIT: Look at post #22 up above, Paul's already covered it, are you saying that IT isn't working either?
    malc-c's Avatar
    malc-c Guest
    Hi Henrik,
    I've tried that and it does make a difference, it drops it down to 005 rather than 051, so DEC3 tends to shift things one place to the right.
    I've changed Pauls suggestion so it displays the bombed out value on the LCD
    Term_RX:
        HSERIN[nTest]
        SELECT CASE nTest
        CASE "S"
    TempWD = 0
    	    gosub send
    RX_Bombed:
    	lcdOUT $FE,$D4,"all we got was", dec TempWD
    end select
    And the first time I launched the application and booted the PIC I got a result on the screen. I then entered another value and the LCD reported that it bombed with a result of 0. This happens on all subsequent tries, even with the PIC and application being re-started - it seems I get a result first time the PC application is launched.... but no every time - it seems random.... would reducing the baud rate give better results ?
    I just tried a somewhat modifed version here (to be able to test on my hardware).
    Term_RX:
        HSERIN[nTest]
        SELECT CASE nTest
        CASE "S"
           TempWD = 0
        gosub send
        Goto Term_Rx
    RX_Bombed:
        TimeoutCount = TimeOutCount + 1
     lcdOUT $FE,1,"all we got was", dec TempWD,", ", DEC TimeOutCount
        end select
        Goto Term_Rx
    Send:
        HSEROUT [DEC normtemp[0],10]
    This seems to work just fine when sending from the serial terminal. The only thing is that there will not be a value assigned to TempWd if HSERIN times out, as can be seen it screenshot.
    Question is if the problem is with the PIC code or with the PC application....
    malc-c's Avatar
    malc-c Guest
    Uhmm I'm beginning to wonder if it's my PC or possibly Vista ?
    I modified the code as suggested (removing the parts that were adjusted for your hardware) and using the serial comms in MCS sent S777 and the LCD reported 0 received by the PIC.
