serial coms - again
Results 1 to 40 of 58
    malc-c's Avatar
    malc-c Guest
    That sounds promising.
    At the moment I've used Henriks suggestion to send three digits per record which helps with the formatting when the data is received by the application written by a chap from another forum who offered to help (he used liberty basic). However I'm trying to learn VB so your suggestion will help (I'm running two versions of PBP code side by side so I can develop either one )
    At the moment the PIC sends data as
    Hserout [DEC3 Temperatures(0)]
    Hserout [DEC3 Temperatures(1)]
    Hserout [DEC3 Temperatures(2)]
    Hserout [DEC3 Temperatures(3)]
    HSEROUT [dec3 normtemp[0]]
    HSEROUT [dec3 normtemp[1]]
    HSEROUT [dec3 normtemp[2]]
    HSEROUT [dec3 normtemp[3]]
    Hserout [dec3 alarmlow[0]]
    Hserout [dec3 alarmlow[1]]
    Hserout [dec alarmlow[2]]
    Hserout [dec alarmlow[3]]
    Hserout [dec3 alarmhigh[0]]
    Hserout [dec3 alarmhigh[1]]
    Hserout [dec3 alarmhigh[2]]
    Hserout [dec3 alarmhigh[3]]
    hserout [#StartHour[0] DIG 1,#StartHour[0] DIG 0,#StartMin[0] DIG 1,#StartMin[0] DIG 0]
    hserout [#StartHour[1] DIG 1,#StartHour[1] DIG 0,#StartMin[1] DIG 1,#StartMin[1] DIG 0]
    hserout [#StartHour[2] DIG 1,#StartHour[2] DIG 0,#StartMin[2] DIG 1,#StartMin[2] DIG 0]
    hserout [#StartHour[3] DIG 1,#StartHour[3] DIG 0,#StartMin[3] DIG 1,#StartMin[3] DIG 0]
    hserout [#StopHour[0] DIG 1,#StopHour[0] DIG 0,#StopMin[0] DIG 1,#StopMin[0] DIG 0]
    hserout [#StopHour[1] DIG 1,#StopHour[1] DIG 0,#StopMin[1] DIG 1,#StopMin[1] DIG 0]
    hserout [#StopHour[2] DIG 1,#StopHour[2] DIG 0,#StopMin[2] DIG 1,#StopMin[2] DIG 0]
    hserout [#StopHour[3] DIG 1,#StopHour[3] DIG 0,#StopMin[3] DIG 1,#StopMin[3] DIG 0]
    Hserout [dec3 Droptemp[0]]
    Hserout [dec3 Droptemp[1]]
    Hserout [dec3 Droptemp[2]]
    Hserout [dec3 Droptemp[3]]
    hserout [#lightsetHR[0] DIG 1,#lightsetHR[0] DIG 0,#lightsetMN[0] DIG 1,#lightsetMN[0] DIG 0]
    hserout [#lightsetHR[1] DIG 1,#lightsetHR[1] DIG 0,#lightsetMN[1] DIG 1,#lightsetMN[1] DIG 0]
    hserout [#lightsetHR[2] DIG 1,#lightsetHR[2] DIG 0,#lightsetMN[2] DIG 1,#lightsetMN[2] DIG 0]
    hserout [#lightsetHR[3] DIG 1,#lightsetHR[3] DIG 0,#lightsetMN[3] DIG 1,#lightsetMN[3] DIG 0]
    hserout [#lightoffHR[0] DIG 1,#lightoffHR[0] DIG 0,#lightoffMN[0] DIG 1,#lightOFFMN[0] DIG 0]
    hserout [#lightoffHR[1] DIG 1,#lightoffHR[1] DIG 0,#lightoffMN[1] DIG 1,#lightOFFMN[1] DIG 0]
    hserout [#lightoffHR[2] DIG 1,#lightoffHR[2] DIG 0,#lightoffMN[2] DIG 1,#lightOFFMN[2] DIG 0]
    hserout [#lightoffHR[3] DIG 1,#lightoffHR[3] DIG 0,#lightoffMN[3] DIG 1,#lightOFFMN[3] DIG 0]
    I assume if I need to prefix each section to apply the same code to make each set of three digits get placed in the right text box ?
    Also how would I modify the PBP code to send S1, S2 etc as part of the data, would it be "hserout [S1,dec3 temperatures[0]]
    Last edited by malc-c; - 22nd August 2010 at 10:38. Reason: forgot to ask about the pbp side
    malc-c's Avatar
    malc-c Guest
    Default Serial in
    Guys and Gals, need your help.
    Through an other forum I've had the offer of some assistance from one of it's members. He has written an application (I believe it's in Liberty Basic) and so far we've got it to read the data stream from the PIC and display it in boxes
    We're now trying to get the application to send new values back to the PIC and this is where I need some guidance.
    This is how he is sending data from the application
    This version will send only the target temperatures.
    It should send "S" followed by carriage return
    Then it should send 12 digits (4 sensors * 3 digits) followed by carriage return
    It should then wait 3 seconds to give you time to process stuff, then it will query everything and expect all 108 characters back.
    It will then wait 4 seconds, and display what it received.
    The PBP code contains the following sections
        FOR TempWD = 0 TO 1000
            IF RCIF THEN GOSUB Term_RX
            PAUSE 1
        NEXT TempWD
    I've removed the original code that DT had written which displayed PID info via hyperterminal and replaced it with
    Term_RX:
     HSERIN [Char]
        SELECT CASE Char
            CASE "S","s"
    Hserin [DEC3 normtemp(0)]
    Hserin [DEC3 normtemp(1)]
    Hserin [DEC3 normtemp(2)]
    Hserin [DEC3 normtemp(3)]
        END SELECT
    But when the update button is clicked on the PC app the PIC appears to lock up.
    I would welcome suggestions on what I'm doing wrong, or what's needed to work with the protocol my friend has evolved.
    For reference here is the section that Darrel coded which used to set just one thermostat channel (ie would send just one value ) at a time
    Term_RX:
        HSERIN [Char]
        SELECT CASE Char
            CASE "S","s"                            ' Enter Setpoint
                X=1 : Y=22 : GOSUB MoveCursor
                HSEROUT ["Enter SetPoint ... (340=34.0",$F8,"): "]
                HSERIN [DEC SetPoints(EditChannel)]
                GOSUB  TerminalMenu
                SELECT CASE EditChannel
                  CASE 0 : Bvar = EE_SetPoint1
                  CASE 1 : Bvar = EE_SetPoint2
                  CASE 2 : Bvar = EE_SetPoint3
                  CASE 3 : Bvar = EE_SetPoint4
                END SELECT
                WRITE Bvar, WORD SetPoints(EditChannel)
    I've got a routine within the code that contains SetPoints(0)=normtemp(0) etc so please don't get confused over the actual variables.
    Feb 2010
    USA, New England
    Instead, try:
    It should send "S"(single character, no carriage return)
    It should wait for the PIC to reply with "K" (or your favorite acknowledge character)
    Then in your main loop add something like:
    nTest var byte
    If PIR1.5 = 1 Then 'check to see if there is data in the serial buffer
    	HSERIN[nTest]
    	if nTest = "S" then
    		HSEROUT["K"]  'Let the PC know to start sending data
    		HSERIN[....all the rest of your stuff...]
    I suspect the PIC appears to lock because it misses a byte. The above slows everything just a little and uses a positive acknowledgement to make sure everything is set.
    Hope this helps somehow...
    Best Regards,
    Paul
    malc-c's Avatar
    malc-c Guest
    Paul,
    Many thanks for the prompt reply.
    One further question, in the original code there was the command to WRITE the result
    Would I need to use a similar line to update the normtemp variable with the data received from the PC, or will
    suffice.
    Also I'll add Bruce's time out as suggested, but should I also have the PIC send something at the end to tell the PC to signify data recived ?
    Feb 2010
    USA, New England
    Hello Malcom,
    I confess the line "WRITE Bvar, WORD SetPoints(EditChannel)" doesn't make a lot of sense to me. I guess use it or not, depending on if you want non-volatile storage of the data. Just wait until *after* all the serial data is received as writing to the EEPROM takes (precious) time.
    Regarding sending a final acknowledgement to the PC, I probably wouldn't bother if it was working well. Primarily because it can get complicated quickly between the PC program and PIC code, and it becomes extra frustrating if you are only writing one side and someone else is on the other.
    Uncle Paul's general advice for serial ports:
    0. Use the hardware USART/EUSART whenever possible. The software serial routines work well enough but are far trickier because there is no buffer.
    1. Never try to read serial data until PIR1.5 = 1. Otherwise there is no data to be read and the firmware will hang. You can make this an interrupt source but I generally put it as an item in the main program loop.
    2. Have the PC application send initially only 1 or 2 bytes of data to get the PIC's attention (because the PIC's serial buffer is 2 bytes so you are GUARANTEED to get that much successfully). Then the PC must patiently wait for the PIC to respond.
    3. When the PIC is ready to receive the clump of data ("clump" means greater than two bytes), have it send a character or two back to the PC to signify "I'm ready."
    4. After the PC receives the "I'm ready" message it should immediately send the data clump.
    I don't work at all with VB or other forms of BASIC for the PC so I can't say anything specific about that. I generally use Delphi or C++, make use of the PC's multi-threading and serial buffer capabilities.
    Hope I'm not missing the point here...8^)
    Best Regards,
    Paul
    malc-c's Avatar
    malc-c Guest
    Paul, thanks once again for the reply.
    To simplify the testing between the applicatication this chap in Canada has written and my PBP code I've gone back to basics and written a simple test application that simply sends the output to the PC and then test the updating from the PC application.
    ;----[USART defines]--------------------------------------------------------
    DEFINE HSER_RCSTA 90h                           ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 20h                           ' Enable transmit, BRGH = 0
    DEFINE HSER_CLROERR 1                           ' Clear overflow automatically
    DEFINE HSER_SPBRG 25                            ' 115200 Baud @ 48MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1                                   ' Enable 16 bit baudrate generator
    ColumnWidth CON 10
    TempWD            VAR WORD
    RCIF              VAR PIR1.5                    ' USART receive flag
    GIE               VAR INTCON.7
    alarmhigh         VAR WORD[4]                   ' used to store the desired high temp alarm values
        alarmhigh1       VAR alarmhigh[0]
        alarmhigh2       VAR alarmhigh[1]
        alarmhigh3       VAR alarmhigh[2]
        alarmhigh4       VAR alarmhigh[3]
    alarmlow        VAR WORD[4]                   ' used to store the desired low temp alarm values
        alarmlow1       VAR alarmlow[0]
        alarmlow2       VAR alarmlow[1]
        alarmlow3       VAR alarmlow[2]
        alarmlow4       VAR alarmlow[3]
    lightsetHR          VAR WORD[4]                 ' user to set light on hour
      lightsetHR1       VAR lightsetHR[0]
      lightsetHR2       VAR lightsetHR[1]
      lightsetHR3       VAR lightsetHR[2]
      lightsetHR4       VAR lightsetHR[3]
    lightsetMN          VAR WORD[4]
      lightsetMN1       VAR lightsetMN[0]
      lightsetMN2       VAR lightsetMN[1]
      lightsetMN3       VAR lightsetMN[2]
      lightsetMN4       VAR lightsetMN[3]
    lightoffHR          VAR WORD[4]
      lightoffHR1       VAR lightoffHR[0]
      lightoffHR2       VAR lightoffHR[1]
      lightoffHR3       VAR lightoffHR[2]
      lightoffHR4       VAR lightoffHR[3]
    lightoffMN          VAR WORD[4]
      lightoffMN1       VAR lightoffMN[0]
      lightoffMN2       VAR lightoffMN[1]
      lightoffMN3       VAR lightoffMN[2]
      lightoffMN4       VAR lightoffMN[3]
    StartHour	         VAR WORD[4]
      StartHour1         VAR StartHour[0]
      StartHour2         VAR StartHour[1]
      StartHour3         VAR StartHour[2]
      StartHour4         VAR StartHour[3]
    StartMin             VAR WORD[4]
      StartMin1          VAR StartMin[0]
      StartMin2          VAR StartMin[1]
      StartMin3          VAR StartMin[2]
      StartMin4          VAR StartMin[3]
    StopHour   	         VAR WORD[4]
      StopHour1          VAR StopHour[0]
      StopHour2          VAR StopHour[1]
      StopHour3          VAR StopHour[2]
      StopHour4          VAR StopHour[3]
    StopMin     	     VAR WORD[4]
      StopMin1           VAR StopMin[0]
      StopMin2           VAR StopMin[1]
      StopMin3           VAR StopMin[2]
      StopMin4           VAR StopMin[3]
    Droptemp	     VAR WORD[4]
    droptemp1     var Droptemp[0]
    droptemp2       var Droptemp[1]
    droptemp3       var Droptemp[2]
    droptemp4       var Droptemp[3]
    Temperatures      VAR WORD[4]
      Temp1           VAR Temperatures[0]
      Temp2           VAR Temperatures[1]
      Temp3           VAR Temperatures[2]
      Temp4           VAR Temperatures[3]
    SetPoints         VAR WORD[4]                   ' used to store the desired temperature setting
      SetPoint1       VAR SetPoints[0]
      SetPoint2       VAR SetPoints[1]
      SetPoint3       VAR SetPoints[2]
      SetPoint4       VAR SetPoints[3]
    normtemp          VAR WORD[4]                   ' used to store the desired temperature setting
      normtemp1       VAR normtemp[0]
      normtemp2       VAR normtemp[1]
      normtemp3       VAR normtemp[2]
      normtemp4       VAR normtemp[3]
    FlashStar         VAR BIT
    nTest var byte
    ;set test values
    Temperatures[0]=230
    Temperatures[1]=240
    Temperatures[2]=250
    Temperatures[3]=260
    normtemp[0]=240
    normtemp[1]=250
    normtemp[2]=260
    normtemp[3]=270
    alarmlow[0]=180
    alarmlow[1]=180
    alarmlow[2]=180
    alarmlow[3]=180
    alarmhigh[0]=360
    alarmhigh[1]=360
    alarmhigh[2]=360
    alarmhigh[3]=360
    StartHour1=00
    StartHour2=00
    StartHour3=00
    StartHour4=00
    StartMin1=00
    StartMin2=00
    StartMin3=00
    StartMin4=00
    StopHour1=00
    StopHour2=00
    StopHour3=00
    StopHour4=00
    StopMin1=00
    StopMin2=00
    StopMin3=00
    StopMin4=00
    Droptemp[0]=180
    Droptemp[1]=180
    Droptemp[2]=180
    Droptemp[3]=180
    lightsetHR1=00
    lightsetHR2=00
    lightsetMN1=00
    lightsetMN2=00
    lightoffHR1=00
    lightoffHR2=00
    lightoffMN1=00
    lightoffMN2=00
      ;______________________________________________________________
    	HSERIN[nTest]
    	if nTest = "S" then
    gosub Term_RX
    for tempwd = 0 to 3
    setpoints(tempwd)=normtemp(tempwd)
    next
    LCDOut $FE,$D4+8,#setpoints(0)dig 2,#setpoints(0)dig 1,$FE,$D4+11,#setpoints(1)dig 2,#setpoints(1)dig 1  ' show current set temperatures
    LCDOut $FE,$D4+14,#setpoints(2)dig 2,#setpoints(2)dig 1,$FE,$D4+17,#setpoints(3)dig 2,#setpoints(3)dig 1
    LCDOUT $FE,$80 + 18,("*"&FlashStar*$FF)|(" "&~(FlashStar*$FF)) ; flash a star to show sample time, but used to indicate Alarm settings monitored
        FlashStar = !FlashStar
    Hserout [DEC3 Temperatures[0]]
    Hserout [DEC3 Temperatures[1]]
    Hserout [DEC3 Temperatures[2]]
    Hserout [DEC3 Temperatures[3]]
    pause 200
    Term_RX:
    HSERin [dec3 normtemp[0]]
    The application is simply sending S followed by three digits for normtemp[0] in DEC format, with no carriage returns - However when I click the update button of the application the PIC freezes for around 10 min. I've proved the PIC is responding to the PC app by changing the "S" to "X" (or any other character) which is ignored when the update button is pressed.
    Unfortunately given the time difference (I'm in the UK he's in Canada) the logistics of implementing the suggestions of handshaking the way you suggest is not forthcoming.
    Any suggestions
    Feb 2010
    USA, New England
    Hi Malcom,
    Try changing the end of your code to this:
    Term_RX:
    	TempWD = 0
    	HSERIN 1000,RX_Bombed,[DEC3 TempWD]
    	normtemp[0] = TempWD
    RX_Bombed:
    	HSEROUT ["Term_RX bombed out, all we got was", dec TempWD,13,10]
    This should at least provide some insight into what's going on inside the PIC.
    In your test application you ought to put a pause of at least 10 msec or so between when the "S" and the rest of the data are sent. You could also probably test this using the Serial Communicator inside of MicroCode Studio, if you have that. Hyperterm would also work.
    I couldn't find your OSC define in this thread. Which oscillator speed are you using?
    Oh, and DOH! I just recalled that I think you "terminate" the DEC3 by sending something that isn't a numeric ASCII character. Try sending a carriage return or a line feed after the 3-character value.
    Best Regards,
    Paul
