Help on routine-Work with a button
Results 1 to 12 of 12
    Mar 2009
    or even my nooby 'take' might work?.
    if sw1=0 then
    pause 3200             ' wait 3.2 seconds (or whatever length of time you expect the user to press/hold the switch for)
    if sw1 = 0 then       ' recheck to see if sw1 is still held down
    goto label2            ' if it is then go & do some stuff in label2
    goto label 1           ' if it wasn't held down then go & do other stuff -  goto label 1
    pause 10
    label1:
    do stuff!
    pause 20           ' bit of a pause for switch debouncing
    label2:
    do other stuff!
    pause 20 '           ' bit of a pause for switch debouncing
    Of course with the method I've posted above, you have to hang around 3.2 seconds to work out whether the user input wanted label1 or label2 - it would really works betterif there was just say a half second pause to decide/glean if label1 or label 2 was required. (but if you're new to picbasic it means grappling with less commands/concepts!)
    Disclaimer: I know bo-diddley squat really!!
    Aug 2005
    Michigan, USA
    This might be a good candidate for switch state logic. Remember that you can detect the following states when using a switch state latch;
    (1) new = 1, old = 0 --> new press
    (2) new = 0, old = 1 --> new release
    (3) new = 1, old = 1 --> still pressed
    (4) new = 0, old = 0 --> still released
    Start a 3-second timer when you detect the "new press" state. If the timer times out while the switch is held pressed then set a "long" flag. If you detect a "new release" state before the timer times out then set a "short" flag.
    Another C example (sorry Gentlemen) based on a 50-msec loop time (sample/debounce/timer interval) that generates a single 'beep' on a "new press" and a double beep at the 3-second time-out;
    ;  unsigned char swnew = 0;     // fresh switch sample
    ;  unsigned char swold = 0;     // switch state latch
    ;  unsigned char swtmr = 0;     // 3-second switch timer
    ;  #define newpress     swnew.0 == 1 && swold.0 == 0
    ;  #define newrelease   swnew.0 == 0 && swold.0 == 1
    ;  while(1)                     //
    ;  { delay_ms(50);              // 50-msec sample/debounce interval
    ;    swnew = ~gpio;             // sample active lo switches
    ;    if(newpress)               // if "new press"
    ;    { swold.0 = 1;             // update switch state latch
    ;      swtmr = 3000/50;         // start 3 second timer
    ;      beep1();                 // send "new press" beep
    ;    if(newrelease)             // if "new release"
    ;    { swold.0 = 0;             // update switch state latch
    ;      if(swtmr)                // if 'short' press
    ;        swtmr = 0;             // turn off switch timer
    ;        sflag = 1;             // set "short" flag
    ;    if(swtmr)                  // if switch timer running
    ;    { swtmr--;                 // decrement it and
    ;      if(swtmr == 0)           // if 3 second timeout
    ;      { beep2();               // send double beep and
    ;        lflag = 1;             // set "long" flag
    ;    if(sflag)                  // if "short" press
    ;    if(lflag)                  // if "long" press
    Add a little more logic for safety (and outputs) and you've got one of those novelty lighted single switch ignition systems (I don't endorse or recommend anyone trying this as it's just too dangerous, IMO);
    ;  unsigned char swtmr = 0;     // 1-second switch timer
    ;  #define ignition    gpio.0   // GP0, active hi relay output
    ;  #define starter     gpio.1   // GP1, active hi relay output
    ;  #define running     swold.0  // flag
    ;  #define newpress    swnew.3 == 1 && swold.3 == 0
    ;  #define newrelease  swnew.3 == 0 && swold.3 == 1
    ;  #define allowstart  ignition == 1 && running == 0
    ;  while(1)
    ;  { delay_ms(32);              // 32-msec debounce intervals
    ;    swnew = ~gpio;             // sample active lo switch GP3
    ;    { swold.3 = 1;             //   update switch state latch
    ;      swtmr = 1000/32;         //   start 1 second timer
    ;      beep1();                 //   send a single beep
    ;    { swold.3 = 0;             //   update switch state latch
    ;      starter = 0;             //   turn GP1 "starter" off
    ;      if(swtmr)                //   if "short" press
    ;      { ignition ^= 1;         //     toggle GP0 "ignition"
    ;        swtmr = 0;             //     turn 1 second timer off
    ;        running = 0;           //     clear "running" flag
    ;    if(swtmr)                  // if 1 second timer running
    ;      if(swtmr == 0)           //   if timed out
    ;      { beep2();               //     send a double beep
    ;        if(allowstart)         //     if start allowed
    ;        { running = 1;         //       set "running" flag
    ;          starter = 1;         //       turn GP1 "starter" on
    Aug 2008
    Portugal
    Thanks you for all the reaplys, I will analyse all of them...in the mean time, if anyone have more options, please post.!!
    Aug 2008
    Portugal
    Hi Again;
    I made this code, however is not working like i wont, only sometimes, can somebody tell me why;
    '                         INCLUDE's e FUSES
    '                     CONFIGURAÇÃO DAS INTERRUPÇÕES
    '                               VARIÁVEIS
    VAR1 var byte
    VAR2 var byte
    I    var byte
    var1=0
    var2=0
    '                        REGISTOS PINOUT 1 = IN; 0 = OUT
              '76543210
     TRISA  = %00000001
     TRISB  = %00000000
     TRISC  = %10000000
     TRISD  = %00000000
     TRISE  = %00000000
     ADCON1 = 7
    '                              NOMES PINOUT
     LED1  VAR PORTC.0
     LED2  var PORTD.0
     Botao var PORTA.0
    '                              DEFINIÇÕES
       DEFINE LCD_DREG PORTB       ' LCD Data bits on PORTB
       DEFINE LCD_DBIT 0           ' PORTB starting address
       DEFINE LCD_RSREG PORTB      ' LCD RS bit on PORTB
       DEFINE LCD_RSBIT 4          ' LCD RS bit address
       DEFINE LCD_EREG PORTB       ' LCD E bit on PORTB
       DEFINE LCD_EBIT 5           ' LCD E bit address
       DEFINE LCD_BITS 4           ' LCD in 4-bit mode
       DEFINE LCD_LINES 2          ' LCD has 2 rows
       DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
       DEFINE LCD_DATAUS 50        ' Set data delay time in us
    '                             INICIO PROGRAMA
     low led1
     low lED2
     LCDOUT $fe, 1
     lcdout "  Teste     Botoes  "
     lcdout $FE,$C0," Por Hugo  Oliveira "
        if botao = 1 then  'Button presse
            pause 80      'debounce for 80ms
            If Botao = 0 then BotaoClick 'Button Unpressed -> Only Click
            if Botao = 1 then  'Button Still pressed
                for i = 1 to 6
                    pause 486
                    If Botao = 0 then Main 'Test if was unpressed in the mean while
                next
            If Botao = 1 then BotaoClickHold 'IF Still pressed after 3s -> Click&Hold
    GOTO MAIN
    '                          SUB-ROTINAS
    BotaoClick:
        if var1 = 0 then
            high led1
            var1 = 1
            low led1
            var1 = 0
    Goto Main
    BotaoClickHold:
        if var2 = 0 then
            high led2
            var2 = 1
            low led2
            var2 = 0
    Goto Main
    Quote Originally Posted by gadelhas View Post
    Hi Again;
    Hi, Hugo
    While Button pressed
      Wait a bit
      Increment a counter
    WEND
    Is Counter limit reached ?
    I do not see those two actions in your program ...
    PS for Administrators ... There is a bug with high size characters: suppress the blank lines inserted after " wait a bit " and it will appear ...
    Aug 2008
    Portugal
    Hi, thanks Acetronics;
    Hi made thsi way, and its working, however later, i will make more tests.
     '                         INCLUDE's e FUSES
    '                               VARIÁVEIS
    VAR1 var byte
    VAR2 var byte
    I    var byte
    counter var byte
              '76543210
     TRISA  = %00000001
     TRISB  = %00000000
     TRISC  = %10000000
     TRISD  = %00000000
     TRISE  = %00000000
     ADCON1 = 7
    '                              NOMES PINOUT
     LED1  VAR PORTC.0
     LED2  var PORTD.0
     Botao var PORTA.0
    '                              DEFINIÇÕES
    '                             INICIO PROGRAMA
     low led1
     low lED2
     LCDOUT $fe, 1
      while botao = 1
          counter = counter + 1
      Wend
        if counter >= 30 then  BotaoClickHold
        if counter>0 and counter<=5  then  BotaoClick
    counter=0
    GOTO MAIN
    '                          SUB-ROTINAS
    BotaoClick:
    counter = 0
        if var1 = 0 then
            high led1
            var1 = 1
            low led1
            var1 = 0
    Goto Main
    BotaoClickHold:
    counter = 0
        if var2 = 0 then
            high led2
            var2 = 1
            low led2
            var2 = 0
    Goto Main
    Thanks Again.
    Aug 2008
    Portugal
    Hi;
    It's Working just like the way i want, just made this change in the Main loop, from the code above;
     '                         INCLUDE's e FUSES
    '                               VARIÁVEIS
    VAR1 var byte
    VAR2 var byte
    I    var byte
    counter var byte
              '76543210
     TRISA  = %00000001
     TRISB  = %00000000
     TRISC  = %10000000
     TRISD  = %00000000
     TRISE  = %00000000
     ADCON1 = 7
    '                              NOMES PINOUT
     LED1  VAR PORTC.0
     LED2  var PORTD.0
     Botao var PORTA.0
    '                              DEFINIÇÕES
    '                             INICIO PROGRAMA
     low led1
     low lED2
     LCDOUT $fe, 1
      while botao = 1
          if counter = 30 then  BotaoClickHold
      Wend
    counter=0
    GOTO MAIN
    '                          SUB-ROTINAS
    BotaoClick:
    counter = 0
        if var1 = 0 then
            high led1
            var1 = 1
            low led1
            var1 = 0
    Goto Main
    BotaoClickHold:
    counter = 0
        if var2 = 0 then
            high led2
            var2 = 1
            low led2
            var2 = 0
    Goto Main
    Thanks Again.
