Help on routine-Work with a button
Results 1 to 12 of 12
Threaded View
  1. #5
    Mar 2009
    or even my nooby 'take' might work?.
    if sw1=0 then
    pause 3200             ' wait 3.2 seconds (or whatever length of time you expect the user to press/hold the switch for)
    if sw1 = 0 then       ' recheck to see if sw1 is still held down
    goto label2            ' if it is then go & do some stuff in label2
    goto label 1           ' if it wasn't held down then go & do other stuff -  goto label 1
    pause 10
    label1:
    do stuff!
    pause 20           ' bit of a pause for switch debouncing
    label2:
    do other stuff!
    pause 20 '           ' bit of a pause for switch debouncing
    Of course with the method I've posted above, you have to hang around 3.2 seconds to work out whether the user input wanted label1 or label2 - it would really works betterif there was just say a half second pause to decide/glean if label1 or label 2 was required. (but if you're new to picbasic it means grappling with less commands/concepts!)
    Disclaimer: I know bo-diddley squat really!!
