Beginner problems with 18F66J50
Results 1 to 14 of 14
    Feb 2010
    USA, New England
    Have you tried it with extended instruction set disabled?
    I just tried that, still no joy. Thank you, though.
    Best Regards,
    Paul
    Miami, Florida USA
    Have you tried a different "Oscillator Selection"?
    Anonymous
    Feb 2010
    USA, New England
    I've now gone and tried all of them again, this time with extended instruction set disabled. No luck. Thanks for trying.
    Best Regards,
    Paul
    Miami, Florida USA
    Quote Originally Posted by prstein View Post
    Best Regards,
    Paul
    I also see that you don't have a diode in MCRL protecting Vdd from Vpp. From the PIC datasheet, the maximum absolute value that Vdd can take is around 4.5 V. If the programming voltage, Vpp, is greater than 4.5V you might have damaged the PIC by no using a diode.
    I don't see anything else that might be causing problems.
    Anonymous
    The drawing also only has half of the OSC connected. But I am sure that is only on the drawing...
    Why not try just for fun, setting the configs not with the programmers software but in the *.inc or code space?
    The settings in the *.inc straight from the install for this chip should have you running with a 20 OSC.
    Then
    DEFINE OSC 48
    Me thinks.
    Feb 2010
    USA, New England
    Then
    DEFINE OSC 48
    Me thinks.
    Thanks for catching the error in the schematic, but as you surmised the resonator is indeed connected.
    I don't alter the inc file because I have no luck figuring out what they should be, at least in this case. I'm happy to try most anything to get this to work...
    I tried adding the define (and also several sets of configuration settings), with the same negative result.
    Best Regards,
    Paul
    Feb 2010
    USA, New England
    Default Solved
    Thanks to everyone who replied. You were all headed in the right direction. Turned out to be the beta MELabs U2 programming software. For some reason it wasn't picking up the settings in the .inc file. I went back to the earlier version of the programmer software (and had to copy 18F66J50.inc to that folder--not supporting that chip was why I tried the beta download) and everything worked fine.
    Now knowing the proper programmer settings I tried the beta again, still wouldn't work. I guess I should report a bug to MEL.
    Best Regards,
    Paul
    Feb 2010
    USA, New England
    Thanks again, Robert. The ISCP is not providing Vdd for the board. Vdd comes from a 2.5V regulator. I verified with a 'scope that Vdd is not changing during programming. I can see the programming data coming in at 5V, but PORTB is 5.5V tolerant.
    Best Regards,
    Paul
