Cheap PCB manufacturer
Results 1 to 27 of 27
    Thanks Mike,
    As for the SparkFun advise on board layout, I've had a few hundred thousand boards made, and never had a problem with sloppy drill holes, but i do appreciate the link.
    If we did ever have boards made with such sloppy drill holes disconnecting a trace from a via, or lousy etching with ground planes connecting to traces, we definitely would not go with that board house again. That's why we normally have a few proto boards made before going for production quantities..
    I'm just looking for the absolute best pricing on panelized boards for the StickOS project.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    USA - Arizona
    You may already know this, but just in case. If you have used Sparkfun in the past (i.e. BatchPCB), then you have used Gold Phoenix. Gold Phoenix is the PCB house for BatchPCB. I have not used them directly, but have used BatchPCB with very good results (other than the time of course). The BatchPCB sub-section on the Sparkfun forum has many users of Gold Phoenix.
    Thanks for the tips.
    -Bruce
    tech at rentron.com
    Sorry I did not have more time to specify... at the bottom of that link in the comments section tere was info on orders from goldphoenix... "Because Gold Phoenix can do down to 7mil for a two-sided board it shows that their masks have quite good resolution."..
    I think a while back sparkfun even had an official tutorial on ordering from goldphoenix... but I may be mistaken...
    regards,
    mike
    malc-c's Avatar
    malc-c Guest
    Default more possible options
    Bruce,
    Lester referred me to the following for production runs. I've not used them so can comment on the quality, but the pricing looks good, and if Lester recommends them then they must be good
    http://www.wedirekt.de/index.php/pcb
    One other recommendation (your side of the pond I think) is http://www.pcbwing.com/index.php?from=everythingpcb
    Again, not tried them, but seem to be very competitive on the price and slightly cheaper in comparison for the same board.
    Jan 2006
    Istanbul
    FYI
    1. http://www.baskidevre.com.tr/default.asp?lang=en
    2. http://www.odakpcb.com/Angliyski/
    These two PCB makers are located in Turkey and they both export worldwide.
    malc-c's Avatar
    malc-c Guest
    Or Olimex
    http://olimex.com/pcb/index.html
    Have used them in the past (6 years ago !) and the boards are fine.
