Serin2 and Button command
Results 1 to 9 of 9
    Aug 2004
    Default Serin2 and Button command
    Dear Friends,
    Is there anybody can explain me why Serin2 and Button command do not work together?.
    I write a simple program just receive some bytes from another pic and same program was controlling one button if it is pressed or not. If pressed it was planned to make one led on or off (Toggle).
    When I start the program the serin2 command is working very well. But the button was not working. If I cancel (take out) the Serin2 command the button is working.
    I looked to the registers by one simulating program the PORT A where the button is connected was never changing.
    I tried also the SERIN command but the result was again same.
    I need really your helps.
    ERO
    reason is simple... serin hserin serin2 will wait untill they receive at least the number of variable or character you decide to receive... once they receive, you'll be able to jump to your button statement. BUT you can use a timeout label to exit serin after xyz time and proceed to another statement and do a loop. be carefull with that. other statement must not take too much time and you time out label should not be too small too. If so, you have chance to miss or have strange result when receiving data.
    If your PIC have USART, a great way is to use the USART interrupt.
    OR using kinda flow control. One specific interrupt pin that tell to your PIC that data is knocking on your PIC's door. This pin make your program jump to your serial data reception.
    Aug 2004
    @miter_e,
    Thank you for the reply. I was thinking that something was making busy the port and everything is clear now.
    I will try your suggestions.
    Thanks again
    ERO
    Aug 2004
    @Mister_e,
    Yesterday, I made a lot of try in order to find a way for using the button. I have to tell you the result is still neagtive.
    First of all I used Tiemout and label and tried from 1 ms up to 250 ms. If I put 1 ms the button working very well but meanwhile serin does not receive any data. If use 2 ms. serin starts to receive datas and the button is working randomly. It means you push the button (continuously on) it is not working but if you make continuously on/off one moment the button is working.
    All other figures from 3-250 ms. does not work.
    I tried to use also RB0 interrupt for the serial input. In this way the serin is working very well but button again does not work.
    I was using 16F628 pic and it has USART and I decided to use also HSERIN it is also not working. I was so nervous and finally I stop the work and I put mechanical switch to my system.
    I gave this information just for your information.
    ERO
    do you still have your code ?!?
    Aug 2004
    @Mister_e,
    I give you here the code. It is changed a lot of time but it is the last one which I used and by this program button is working a little bit for instance after 1-2 minutes it is making on and again 2-3 minutes later it making off also.
    OPTION_REG.7=1
    @ DEVICE pic16F628
    @ DEVICE pic16F628, WDT_ON
    @ DEVICE pic16F628, PWRT_ON
    @ DEVICE pic16F628, PROTECT_OFF
    @ DEVICE pic16F628, MCLR_OFF
    @ DEVICE pic16F628, INTRC_OSC_NOCLKOUT
    '---------------------------Variab..------------------------------
    AL VAR BYTE
    TOPLAM var byte
    KOMBI VAR BYTE
    GIRIS VAR PORTB.0
    ROLE VAR PORTA.1
    TUS var PORTA.6
    LED VAR PORTB.3
    YANDI VAR byte
    SONDU VAR Byte
    I VAR BYTE
    '-----------------------------MAIN ---------------------------
    CMCON=7
    CLEAR:TRISA=%01100000
    TRISB=%00000011
    PAUSE 500:AL=88:sondu=0:KOMBI=0:LOW LED
    START:
    BUTTON TUS,0,200,5,I,1,BAK
    SerIn2 GIRIS,1646,10,ATLA,[WAIT ("ER"),AL]
    ATLA:
    IF AL=88 THEN
    IF SONDU=1 THEN ARA 'if already off then ara
    GOSUB SON 'gosub off
    GOTO START
    IF AL=66 THEN
    IF YANDI=1 THEN ARA 'if already on then ara
    GOSUB YAN 'gosub on
    GOTO START
    pause 1
    ARA: GOTO START
    '--------------------if button is pushed -------------------------
    BAK: IF KOMBI=1 THEN 'if already on then gosub offf
    GOSUB SON
    AL=88
    GOTO START
    GOSUB YAN 'it is already off then gosub on
    AL=66
    GOTO START
    YAN: '------------------on section-------------------
    KOMBI=1
    YANDI=1:SONDU=0
    HIGH ROLE
    HIGH LED
    pause 1
    SON: '-----------------off section---------------------
    LOW LED:KOMBI=0
    SONDU=1:YANDI=0
    LOW ROLE
    pause 1
    some things can cause this. Let's look this snip
    IF AL=88 THEN
         GOTO START
    You exit several time from a IF THEN and/or a nested IF THEN ELSE with a goto... not a good practice. You probably overflow the stack pointer.
    as i read SONDU will be 0 or 1 so
    ReturnToStart var Bit
    Start:
    ReturnToStart = 0
    IF AL=88 THEN
         IF SONDU=0 THEN
         ReturnToStart = 1
    if ReturnToStart then GotoStart
    about the BUTTON statement... i'm not a fan of this statement. i'll prefer do 2-3 lines myself.
    Let's say i want to monitor a pushButon on PORTA.1
    TRISA.1=1
    PushButton VAR PORTA.1
    start:
         If PushButton then    ' Pushbutton active
              While PushButton ' wait untill it's release
              Wend
              Pause 50 ' debounce time
              Gosub XYZ
    Aug 2004
    Dear Steve,
    Thank you for the tricks. You right I checked the program again and I saw that there are a lot of cunfusions. It was working but as you have said the reason can be the stack due to that cınfusions.Anyhow, I changed the program to make one loop only. I taken out all the zig-zags in the program. I did not yet tried. I was busy. I will try it within two days and let you know the result.
    It would be good idea if I can check the program with one debugger. It is a pity that I have not mcs plus. By the way I would see where the program was going without touching the button command.
    Thanks again
    ERO
    Aug 2004
    Steve,
    Yesterday evening, I tested all the possibilities again after I made a new program which is only one loop. It was checking the button first after it was passing to SERIN2 command and passing to control what was arrived by SERIN2. Anyhow I have to tell you that the serin or serin2 command does not work with any button control. I tested all the timeout figures starting from 2 ms up to 2000 ms. I am sure there is a bug in the compiler.
    I tested again the HSERIN command by making some changing on the pcb and I saw that it is working very well. Today I will change all the PCB and the program for working with HSERIN command.
    I wanted to give you again the result of my work which can be intersting for other people.
    Thanks again for your helps.
    Ero
