16F819 PortA as Outputs
Results 1 to 10 of 10
    Perth, Australia
    You beat me to it mackrackit. My response was going to be identical
    May 2010
    OK,
    I aded @ __config _INTRC_OSC_NOCLKOUT to set the PIC for Internal Oscillator allowing
    use of the OSC pins as I/O, but when I compile, the error 44 : symbol not previously defined
    appear.
    Any suggestion?
    thanks,
    Oswaldus
    Try
    _INTRC_IO
    May 2010
    mackrackit,
    I Try _INTRC_IO, but I have now: Error 118 Overwriting previous address contents (2007)
    thanks,
    oswaldus
    That sounds like you did not comment out the config lines in the chips inc file as described in the link.
    Or you could just modify the inc file and not set the config in code space.
    May 2010
    I comment out the config lines in the chips inc file as described in the link, and Port A works fine.
    Thanks for your help, Kamikaze47 and mackrackit
    Best regards,
    oswaldus
