Resistor Voltage Divider and ADC
Results 1 to 10 of 10
    Consider BrianT answer confirmed
    This may help, near the end....
    http://www.kpsec.freeuk.com/imped.htm
    Perth, Australia
    Thanks BrianT and mackrackit.
    It still seems counter-intuitive to me, but it means that I can have accurate battery readings with less wasted current, so I'm happy.
    Aug 2010
    Chiang Mai University, Thailand
    An easy way to understand it without going into thevenin equivalent circuits.
    Consider the plus side and the 0 (ground) side of the power source as low impedance sources. In an ideal power source the + side and 0 side will each be zero ohms impedance and as such the PIC sees both the high side resistor and low side resistor going to to zero ohm sources making the value of the resistors parallel.
    Nice explanation!
    timmers's Avatar
    timmers Guest
    ...or put a largish capacitor accross the pic pin and use the ESR of the cap as your source impedance!
