Resistor Voltage Divider and ADC
Results 1 to 10 of 10
    Perth, Australia
    Default Resistor Voltage Divider and ADC
    I need to measure the voltage of a battery, so i'm going to be using a resistor voltage divider to drop the voltage down to <5v that the ADC can handle. Like this:
    Battery +ve ------- 18k Resistor ------- ADC Pin ------- 4.7k Resistor ------- Ground
    My question is, what is my impedance for calculating the min ADC acquisition time in this instance? Is it just the impedance to ground (i.e. 4.7k)? Or do I have to consider the 18k resistor as well?
    Default Impedance is the parallel combination
    Your effective input impedance is the parallel combination of 4k7 and 18k.
    Formula is R1*R2/(R1 + R2).
    HTH
    BrianT
    Perth, Australia
    Oh, really? I cant say I understand why that is the case, but i'll take your word for it.
    In that case I should be able to use even higher resistor values (to reduce the wasted current) without violating the PIC's specification of a 10k maximum impedance on ADC inputs?
    Something like:
    Battery +ve ------- 47k Resistor ------- ADC Pin ------- 12k Resistor ------- Ground
    = 9.56k input impedance ~ 10uS ADC acquisition time (and only wasting fractions of a mA of battery current)
    Perth, Australia
    Thanks. I don't have any trouble working out the divisor so that it wont go over 5v for my input range. It's the impedance that I was worried about (but still want to minimise wasted current).
    It's a shame that DT's calculator there doesn't have the impedance in the result. I have yet to find confirmation elsewhere that the input impedance is the parallel impedance of the 2 resistors. It seems a little counter-intuitive to me. If anything, I would have thought that it would be the series impedance.
    Consider BrianT answer confirmed
    This may help, near the end....
    http://www.kpsec.freeuk.com/imped.htm
