Hi Again, and thanks for the replys.
Hi made this way, ad it works fine, however i don't have sure that is the best solutio;
ThanksCode:'**************************************************************** '* Name : Teste Interrupt Serial.BAS * '* Author : Hugo Oliveira * '* Notice : Copyright (c) 2010 ProSystems * '* : All Rights Reserved * '* Date : 10-08-2010 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** DEFINE OSC 4 include "modedefs.bas" INCLUDE "DT_INTS-14.bas" include "ReEnterPBP.bas" ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX_INT, _Interr, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE RX_INT ; enable external (INT) interrupts ' VARIÁVEIS ' ==================================================================== DADO var byte DADOS var byte(4) ID var byte(2) wsave VAR BYTE $70 SYSTEM ' REGISTOS PINOUT 1 = IN; 0 = OUT ' ==================================================================== '76543210 TRISA = %00000001 TRISB = %00001111 TRISC = %10000000 TRISD = %00000000 TRISE = %00000000 ADCON1 = 7 ' NOMES PINOUT ' ==================================================================== LED VAR PORTA.1 Botao var PORTA.0 TX Var PORTC.6 RX VAR PORTC.7 ' DEFINIÇÕES ' ==================================================================== DEFINE LCD_DREG PORTB ' LCD Data bits on PORTB DEFINE LCD_DBIT 4 ' PORTB starting address DEFINE LCD_RSREG PORTB ' LCD RS bit on PORTB DEFINE LCD_RSBIT 3 ' LCD RS bit address DEFINE LCD_EREG PORTB ' LCD E bit on PORTB DEFINE LCD_EBIT 2 ' LCD E bit address DEFINE LCD_BITS 4 ' LCD in 4-bit mode DEFINE LCD_LINES 2 ' LCD has 2 rows DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us DEFINE LCD_DATAUS 50 ' Set data delay time in us DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 24h 'Testado 300-20h,600-20h,1200-20h,2400-20h,4800-24h,9600-24h,14400-24h,19200-24h,28800-24h DEFINE HSER_BAUD 28800 DEFINE HSER_CLROERR 1 ' INICIO PROGRAMA ' ==================================================================== Start: HIGH LED PAUSE 500 LOW LED PAUSE 500 HIGH LED LCDOUT $fe, 1 lcdout " Teste Interrupt " lcdout $FE,$C0," Por Hugo Oliveira" pause 1000 Main: HIGH LED PAUSE 500 LOW LED PAUSE 500 goto Main Interr: Hserin [wait("OK"),STR ID\2,str DAdos\4] 'Testado 300-20h,600-20h,1200-20h,2400-20h,4800-24h,9600-24h,14400-24h,19200-24h,28800-24h if id(0)="3" and id(1)="2" then if DADOS(0)="H" and DADOS(1)="u" and DADOS(2)="g" and DADOS(3)="o" then high led LCDOUT $fe, 1 lcdout " Teste USB" lcdout $FE,$C0,"Recebido H " endif if DADOS(0)="L" and DADOS(1)="u" and DADOS(2)="L" and DADOS(3)="u" then low led LCDOUT $fe, 1 lcdout " Teste USB" lcdout $FE,$C0,"Recebido L " endif if DADOS(0)<>"L" and DADOS(0)<>"H" then LCDOUT $fe, 1 lcdout " Teste USB" lcdout $FE,$C0,"Recebido :",DADOS(0),DADOS(1),DADOS(2),DADOS(3) endif endif @ INT_RETURN END
