Serial Interrupt with DT_Ints - Error
Results 1 to 9 of 9
    Aug 2008
    Portugal
    Default Serial Interrupt with DT_Ints - Error
    Hi Again everyone;
    I'm trying to make a program using serial interrupt with DT_Ints, however i'm getting some erros when i compile, can somebody help me?
    PIC16F877A
    4Mhz
    PBP Pro 2.60a
    Mplab 8.53
    DEFINE  OSC 4
     include "modedefs.bas"
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    INT_LIST  macro   ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    RX_INT,    _serialin,   PBP,  no
    @   INT_ENABLE   RX_INT     ; enable external (INT) interrupts
    '                               VARIÁVEIS
    DADO  var byte
    DADOS var byte(4)
    ID    var byte(2)
    '                              REGISTOS PINOUT 1 = IN; 0 = OUT
             '76543210
    TRISA  = %00000001
    TRISB  = %00001111
    TRISC  = %10000000
    TRISD  = %00000000
    TRISE  = %00000000
    ADCON1 = 7
    '                              NOMES PINOUT
    LED    VAR PORTA.1
    Botao  var PORTA.0
    TX     Var PORTC.6
    RX     VAR PORTC.7
    '                              DEFINIÇÕES
       DEFINE LCD_DREG PORTB       ' LCD Data bits on PORTB
       DEFINE LCD_DBIT 4           ' PORTB starting address
       DEFINE LCD_RSREG PORTB      ' LCD RS bit on PORTB
       DEFINE LCD_RSBIT 3          ' LCD RS bit address
       DEFINE LCD_EREG PORTB       ' LCD E bit on PORTB
       DEFINE LCD_EBIT 2           ' LCD E bit address
       DEFINE LCD_BITS 4           ' LCD in 4-bit mode
       DEFINE LCD_LINES 2          ' LCD has 2 rows
       DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
       DEFINE LCD_DATAUS 50        ' Set data delay time in us
    '                             INICIO PROGRAMA
    Start:
     HIGH LED
     PAUSE 500
     LOW LED
     PAUSE 500
     HIGH LED
     LCDOUT $fe, 1
     lcdout "  Teste  Interrupt  "
     lcdout $FE,$C0," Por Hugo  Oliveira"
     toggle led
     Pause 1000
    serialin:				        ' Buffer the character received
    @  INT_RETURN
    The Erros are;
    xecuting: "C:\Programas\PBP\PBPMPLAB.BAT" -ampasmwin -k#   -p16F877A "Interrupt.pbp"
    Executing: "C:\Programas\PBP\PBPW.EXE" -ampasmwin -k# -p16F877A "Interrupt.pbp"
    PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Error[113]   C:\PROGRAMAS\PBP\PBPPIC14.LIB 1181 : Symbol not previously defined (wsave)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 383 : ERROR: (wsave variable not found,)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 347 : ERROR: ("                     Add:"       wsave VAR BYTE $70 SYSTEM)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 404 : ERROR: (Chip has RAM in BANK1, but wsave1 was not found.)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 354 : ERROR: ("   Add:"       wsave1 VAR BYTE $A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 420 : ERROR: (Chip has RAM in BANK2, but wsave2 was not found.)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 361 : ERROR: ("   Add:"       wsave2 VAR BYTE $120 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 430 : ERROR: (Chip has RAM in BANK3, but wsave3 was not found.)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 368 : ERROR: ("   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Halting build on first failure as requested.
    BUILD FAILED: Tue Aug 10 02:48:20 2010
    The answer is in the error ...
    Aug 2008
    Portugal
    Many Thanks Darrel for the answer.
    Itt compiles fine now.
    However, cam up another issue;
    how can i get a string of chars, like i use in Hserin, for instance;
    Hserin [wait("OK"),STR ID\2,str DAdos\4]
    I Will Send to the pic "OK32Hugo" and then i want to compare the "ID" and the "Dados".
    I'm trying to figure out the example that you gave int the
    http://www.picbasic.co.uk/forum/show...8336#post28336
    but i'm not getting there, can you help me here on this? Waht to i have to put in the
    serialin:
    @  INT_RETURN
    To Receive the data?
    There are many ways you can do it. It depends on what you need.
    If you want the main program to continue running while it's receiving data, then you'll need to use the buffer method as shown in that thread.
    If you just want the main program to stop what it's doing and grab the serial data, then simply put your HSERIN in the serialin handler.
    You should add a timeout if you do that though.
    Aug 2008
    Portugal
    Hi Again, and thanks for the replys.
    Hi made this way, ad it works fine, however i don't have sure that is the best solutio;
    '*  Name    : Teste Interrupt Serial.BAS                                      *
    '*  Author  : Hugo Oliveira                                     *
    '*  Notice  : Copyright (c) 2010 ProSystems                     *
    '*  Date    : 10-08-2010                                        *
     DEFINE  OSC 4
     include "ReEnterPBP.bas"
            INT_Handler    RX_INT,        _Interr,   PBP,  yes
    '                               VARIÁVEIS
    DADO  var byte
    DADOS var byte(4)
    ID    var byte(2)
             '76543210
    TRISA  = %00000001
    TRISB  = %00001111
    TRISC  = %10000000
    TRISD  = %00000000
    TRISE  = %00000000
    ADCON1 = 7
    '                              NOMES PINOUT
    LED    VAR PORTA.1
    Botao  var PORTA.0
    TX     Var PORTC.6
    RX     VAR PORTC.7
    '                              DEFINIÇÕES
       DEFINE HSER_RCSTA 90h
       DEFINE HSER_TXSTA 24h 'Testado 300-20h,600-20h,1200-20h,2400-20h,4800-24h,9600-24h,14400-24h,19200-24h,28800-24h
       DEFINE HSER_BAUD 28800
       DEFINE HSER_CLROERR 1
    '                             INICIO PROGRAMA
    Start:
     HIGH LED
     PAUSE 500
     LOW LED
     PAUSE 500
     HIGH LED
     LCDOUT $fe, 1
     HIGH LED
     PAUSE 500
     LOW LED
     PAUSE 500
    goto Main
    Interr:
     Hserin [wait("OK"),STR ID\2,str DAdos\4] 'Testado 300-20h,600-20h,1200-20h,2400-20h,4800-24h,9600-24h,14400-24h,19200-24h,28800-24h
    if id(0)="3" and id(1)="2" then
        if DADOS(0)="H" and DADOS(1)="u" and DADOS(2)="g" and DADOS(3)="o" then
            high led
            LCDOUT $fe, 1
            lcdout "      Teste USB"
            lcdout $FE,$C0,"Recebido H          "
        if DADOS(0)="L" and DADOS(1)="u" and DADOS(2)="L" and DADOS(3)="u" then
            low led
            LCDOUT $fe, 1
            lcdout "      Teste USB"
            lcdout $FE,$C0,"Recebido L          "
        if DADOS(0)<>"L" and DADOS(0)<>"H"  then
            LCDOUT $fe, 1
            lcdout "      Teste USB"
            lcdout $FE,$C0,"Recebido    :",DADOS(0),DADOS(1),DADOS(2),DADOS(3)
    @ INT_RETURN
    The best solution ... I've never found one of those.
    Found things that "work" along the way, but there's always something better.
    Don't know if this is better or not, but it is definitely different.
    <font color="#000000"><b>ID     </b><font color="#008000"><b>VAR BYTE
    </b></font><b>Interr</b>:
        <font color="#008000"><b>Hserin </b></font><font color="#800000"><b>100</b></font>,<b>RXfail</b>, [<b>wait</b>(<font color="#FF0000">&quot;OK&quot;</font>),<font color="#008000"><b>DEC2 </b></font><b>ID</b>, <font color="#008000"><b>str </b></font><b>DAdos</b>\<font color="#800000"><b>4</b></font>]
        <font color="#008000"><b>if </b></font><b>ID </b>= <font color="#800000"><b>32 </b></font><font color="#008000"><b>then
            </b></font><b>ARRAYREAD DAdos</b>, <font color="#800000"><b>4</b></font>,<b>No_Hugo</b>,[<b>WAIT</b>(<font color="#FF0000">&quot;Hugo&quot;</font>)]
                <font color="#008000"><b>high </b></font><b>led
                </b><font color="#008000"><b>LCDOUT </b></font><font color="#800000"><b>$fe</b></font>, <font color="#800000"><b>1
                </b></font><font color="#008000"><b>lcdout </b></font><font color="#FF0000">&quot;      Teste USB&quot;
                </font><font color="#008000"><b>lcdout </b></font><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0</b></font>,<font color="#FF0000">&quot;Recebido H          &quot;
            </font><b>No_Hugo</b>:
            <b>ARRAYREAD DAdos</b>, <font color="#800000"><b>4</b></font>,<b>No_LuLu</b>,[<b>WAIT</b>(<font color="#FF0000">&quot;LuLu&quot;</font>)]
                <font color="#008000"><b>low </b></font><b>led
                </font><font color="#008000"><b>lcdout </b></font><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0</b></font>,<font color="#FF0000">&quot;Recebido L          &quot;
            </font><b>No_LuLu</b>:
            <b>ARRAYREAD DAdos</b>, <font color="#800000"><b>2</b></font>,<b>NO_LH</b>,[<b>WAIT</b>(<font color="#FF0000">&quot;LH&quot;</font>)]
                </font><font color="#008000"><b>lcdout </b></font><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0</b></font>,<font color="#FF0000">&quot;Recebido    :&quot;</font>,<font color="#008000"><b>STR </b></font><b>DADOS</b>\<font color="#800000"><b>4
            </b></font><b>NO_LH</b>:
        <font color="#008000"><b>endif
    </b></font><b>RXfail</b>:
    <font color="#000080">@ INT_RETURN
    </font>
    If nothing else, you should add the RXfail timeout to the HSERIN statement.
