Serial Interrupt with DT_Ints - Error
Results 1 to 9 of 9
Threaded View
    Aug 2008
    Portugal
    Default Serial Interrupt with DT_Ints - Error
    Hi Again everyone;
    I'm trying to make a program using serial interrupt with DT_Ints, however i'm getting some erros when i compile, can somebody help me?
    PIC16F877A
    4Mhz
    PBP Pro 2.60a
    Mplab 8.53
    DEFINE  OSC 4
     include "modedefs.bas"
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    INT_LIST  macro   ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    RX_INT,    _serialin,   PBP,  no
    @   INT_ENABLE   RX_INT     ; enable external (INT) interrupts
    '                               VARIÁVEIS
    DADO  var byte
    DADOS var byte(4)
    ID    var byte(2)
    '                              REGISTOS PINOUT 1 = IN; 0 = OUT
             '76543210
    TRISA  = %00000001
    TRISB  = %00001111
    TRISC  = %10000000
    TRISD  = %00000000
    TRISE  = %00000000
    ADCON1 = 7
    '                              NOMES PINOUT
    LED    VAR PORTA.1
    Botao  var PORTA.0
    TX     Var PORTC.6
    RX     VAR PORTC.7
    '                              DEFINIÇÕES
       DEFINE LCD_DREG PORTB       ' LCD Data bits on PORTB
       DEFINE LCD_DBIT 4           ' PORTB starting address
       DEFINE LCD_RSREG PORTB      ' LCD RS bit on PORTB
       DEFINE LCD_RSBIT 3          ' LCD RS bit address
       DEFINE LCD_EREG PORTB       ' LCD E bit on PORTB
       DEFINE LCD_EBIT 2           ' LCD E bit address
       DEFINE LCD_BITS 4           ' LCD in 4-bit mode
       DEFINE LCD_LINES 2          ' LCD has 2 rows
       DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
       DEFINE LCD_DATAUS 50        ' Set data delay time in us
    '                             INICIO PROGRAMA
    Start:
     HIGH LED
     PAUSE 500
     LOW LED
     PAUSE 500
     HIGH LED
     LCDOUT $fe, 1
     lcdout "  Teste  Interrupt  "
     lcdout $FE,$C0," Por Hugo  Oliveira"
     toggle led
     Pause 1000
    serialin:				        ' Buffer the character received
    @  INT_RETURN
    The Erros are;
    xecuting: "C:\Programas\PBP\PBPMPLAB.BAT" -ampasmwin -k#   -p16F877A "Interrupt.pbp"
    Executing: "C:\Programas\PBP\PBPW.EXE" -ampasmwin -k# -p16F877A "Interrupt.pbp"
    PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Error[113]   C:\PROGRAMAS\PBP\PBPPIC14.LIB 1181 : Symbol not previously defined (wsave)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 383 : ERROR: (wsave variable not found,)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 347 : ERROR: ("                     Add:"       wsave VAR BYTE $70 SYSTEM)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 404 : ERROR: (Chip has RAM in BANK1, but wsave1 was not found.)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 354 : ERROR: ("   Add:"       wsave1 VAR BYTE $A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 420 : ERROR: (Chip has RAM in BANK2, but wsave2 was not found.)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 361 : ERROR: ("   Add:"       wsave2 VAR BYTE $120 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 430 : ERROR: (Chip has RAM in BANK3, but wsave3 was not found.)
    Error[101]   C:\DOCUMENTS AND SETTINGS\HUGO OLIVEIRA\AMBIENTE DE TRABALHO\NOVA PASTA\INTERRUPT.ASM 368 : ERROR: ("   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Halting build on first failure as requested.
    BUILD FAILED: Tue Aug 10 02:48:20 2010
