16F819 PortA as Outputs
Results 1 to 10 of 10
    May 2010
    Default 16F819 PortA as Outputs
    Please Somebody help me!
    I need to know:
    How to set PORTA.6 and PORTA.7 as outputs in PIC 16F819?
    Thanks in advance
    Oswaldus
    Perth, Australia
    PORTA.6 and PORTA.7 on the 16F819 are the oscillator pins. I assume therefore that you are using the internal oscillator. If so, you need to make sure the config bits for the oscillator are set to _INTRC_IO (assuming you are using PMASM as your assembler).
    May 2010
    Greetings Kamikaze47,
    Thanks for your reply
    Yes I am using internal oscillator.
    I don't know How set config bits in _INTRC_IO, Can you let me know, How I make this from PicBasic Pro?
    Thanks in advance
    Oswaldus
    Perth, Australia
    You beat me to it mackrackit. My response was going to be identical
    May 2010
    OK,
    I aded @ __config _INTRC_OSC_NOCLKOUT to set the PIC for Internal Oscillator allowing
    use of the OSC pins as I/O, but when I compile, the error 44 : symbol not previously defined
    appear.
    Any suggestion?
    thanks,
    Oswaldus
    Try
    _INTRC_IO
    May 2010
    mackrackit,
    I Try _INTRC_IO, but I have now: Error 118 Overwriting previous address contents (2007)
    thanks,
    oswaldus
    That sounds like you did not comment out the config lines in the chips inc file as described in the link.
    Or you could just modify the inc file and not set the config in code space.
    May 2010
    I comment out the config lines in the chips inc file as described in the link, and Port A works fine.
    Thanks for your help, Kamikaze47 and mackrackit
    Best regards,
    oswaldus
