without communication modbus
Results 1 to 7 of 7
    Jun 2010
    Venezuela
    Default without communication modbus
    hello all, I need help I have a modbus communication program that works very well, but sometimes I lose communication, I have noticed that if the frame or the values are very large, I lose communication (I have an LED that tells me when the interruption occurs receive information), this LED does not light and the only way to restore communication is resetting the pic, although the program has routines that verify if the information is correct, I could not correct this behavior.
    Jun 2010
    Venezuela
    Default without comunication modbus code
    this is the main code ( I forget).
    thank
    include "alldigital.pbp"
    INCLUDE "P16F877A.INC"
    DEFINE OSC 20
    '* FUSE*
    @ DEVICE HS_OSC     'OSCILADOR HIGH SPEED
    @ DEVICE WDT_ON ' Watchdog Timer desconectado
    @ DEVICE PWRT_ON ' Power-On Timer conectado
    @ DEVICE BOD_ON ' Brown-Out Detect conectado
    @ DEVICE LVP_OFF ' Low Voltage Programming desconectado
    '//******************* INICIO PUERTOS COMO SALIDAS ***************************//
    PORTA = %00111111
    PORTB = 0
    portc = %10111110
    PORTD = 0
    PORTE = %00000011
    TRISA = %00111111
    TRISB = 0
    TRISC = %10111111       ' Set TX (RC.6), RC.0 to out, rest in
    TRISD = 0
    TRISE = %00000011
    '*************** counter,index *************************************
    buffer var byte[32]             'Receiving Buffer Trama MOdbus
    crc16 var byte[2]               'for checksum
    B0        var   byte
    B1        var   byte
    W0        var   word
    MBFrame   var   byte
    NewFrame  var   bit
    Length    var   byte
    TMR1Ticks var   byte
    i         var   byte
    MINPUT    var   byte
    SlaveAddress var byte
    Baudios   VAR   BYTE
    TMR1Ticks = 0
    Length = 0
    MINPUT = 0
    '//********************* Inicializo USART *****************************
    RCSTA.7 = 1  'abilito puerto serial configura RC6 y RC7 para RX/TX
    RCSTA.6 = 0  ' seleccino modo 8 bit en recepcion
    RCSTA.5 = 0  ' no usado
    RCSTA.4 = 1  'abilito recpcion continua = 1
    RCSTA.3 = 0  'desabilito deteccion direccion
    RCSTA.2 = 0  'guarda error de trama 0 = sin error
    RCSTA.1 = 0  'guarda error de overrun 0 = sin error
    RCSTA.0 = 0  'guarda el noveno bit de los datos recibidos uso paridad
    ' Enable transmit and asynchronous mode
        if baudios=64 then
            TXSTA = %00100100
            TXSTA = %00100000
    SPBRG = Baudios          ' Baudrate =  9600 or 19200
    INTCON = %11000000	 ' Enable interrupts
    PIE1.5 = 1		 ' Enable interrupt on RECEPCION USART
    PIE1.1 = 1          	 ' Enable interrupt on TMR2
    T2CON.1 = 1 		 ' TMR1 prescaler 1:16
    TMR2 = 0                 ' TMR2 Holding register = 0
    ON INTERRUPT GoTo readMB ' Declare interrupt handler routine
    '********************* PROGRAMA PRINCIPAL ******************************
    '****************************** Read input *************************
    MINPUT.7 = not PORTE.1
    MINPUT.6 = not PORTE.0
    MINPUT.5 = not PORTA.5
    MINPUT.4 = not PORTA.4
    MINPUT.3 = not PORTA.3
    MINPUT.0 = not PORTA.0
    MINPUT.2 = not PORTA.2
    MINPUT.1 = not PORTA.1
    Goto Main
    '!!!! Desabilito interrupcion no colocar ningun codigo del user !!!!
    Disable
    '********************* interrupt  ***********************
    readMB:
    If RCSTA.1 OR RCSTA.2 then          ' If USART error then clear the error flag
          RCSTA.4=0                     ' // clear the error
          RCSTA.4=1                     ' // enable receiving again
    EndIf
    if (PIR1.5 = 1) then                        	' USART Interrupt
    TMR1Ticks = 0
     If (NewFrame = 1) Or (Length = 0) Then     	'New modbus frame start
        NewFrame = 0
        T2CON.2 = 1                         	' Enable Timer2
        Length = 1
     EndIf
     while (PIR1.5 = 1)                     	'Write modbus frame to buffer
       buffer [Length] = RCREG
       Length = Length + 1
       If Length >= 20 Then                 'Max modbus frame to buffer 20 char
        Length = 0
       EndIf
     Wend
    EndIf
    if (PIR1.1 = 1) then                      ' Timer2 interrupt
     PIR1.1 = 0
     T2CON.2 = 0                              ' Timer2 disable
     TMR1Ticks = TMR1Ticks + 1
     If TMR1Ticks > 120 Then                  ' ~ 10 ms without new char
        'There was no new char on USART => end of modbus frame
        NewFrame = 1
     Else
        T2CON.2 = 1                             'Enable timer
     EndIf
    EndIf
    Resume
    ENABLE
    Am I reading your code correctly? You have an interrupt inside an interrupt?
    If so, I do not think that will work?
    Bombay, India
    It may be possible the problem is in your crc16 or some other related section. In the code you posted, I do not see any led(did I miss it?)
    This code appears Ok to me.
    Define very large. Your buffer length seems to be 20 bytes so if the frame is longer than that I imagine you'll be in trouble. It shouldn't stop interrupting though.....
    I can't seem to find where you turn on the LED you mentioned.
    Jun 2010
    Venezuela
    Hello everyone sorry did not reply earlier.
    hello mackrackit , is enabled every time it happens the serial interrupt. is used to determine if there are no more characters to read and works. original code from modbus.pl
    If (NewFrame = 1) OR (Length = 0) then 'New modbus frame start
    NewFrame = 0
    Length = 1
    EndIf
    hello Jerson, the crc16 is working, the led is switched off in the Main, is switched on every time PIR1.5 = 1. when the fault occurs, the LED lights (I'm in the interruption) and then turn off.
    hello HenrikOlsson, explain why "Define very large", look:
    buffer[Length] = RCREG
    Length = Length + 1
    if Length >=20 then ' here check buffer
    Length = 0
    EndIf
    wend
    You said that the problem occured when the frame was large and I was asking HOW large.
    The reason I asked is that your buffer wraps around when Length is 20 you only have space for 21 characters in your buffer.
    You get you characters from RCREG and put them in Buffer[0], Buffer[1], Buffer[2].......Buffer[20]. When Length reaches 20 it wraps around to 0 and you overwrite what's in Buffer[0] and because you said the problem occured when the frame was "very large". So, is it when the frame is larger than 20 bytes?
