A variable interval LED pulser??
Results 1 to 5 of 5
    Mar 2009
    Colorado
    Default A variable interval LED pulser??
    I need to pulse an LED (on for ~1 sec) at a variable interval from 1 sec to 3 minutes, as externally controlled by the user. I presume there is some way to use a potentiometer as a peripheral to an ADC input as a means of varying the interval between the output pulses to the LED, but not sure how to do this with the ADC input circuit or the required PICBASIC. Any ideas or examples would be appreciated!
    Perth, Australia
    You can connect one side of a pot to ground, the other side to +5v and the middle pin to an ADC pin. Then, take a look in the PBP manual under ADCIN - it will tell you how to read the value. If you are unsure what values to use in the defines, use PicMultiCalc (search this forum for it, if you dont have it).
    Once you have ADC working, you can use PicMultiCalc again to work out the timer values to create a 1Hz timer. A simple counter within the timer interrupt will let you flash the led every second, every 2 seconds, or every what every number of seconds you want. Set the target of the counter based on the ADC result.
    Aug 2005
    Michigan, USA
    Couldn't you also do it without timer interrupts? Something like this perhaps (please excuse the C code)?
    while(1)
      period = adcin(3);             // read pot'
      period = period / 10 + 1;      // scale to 1..103 (seconds)
      count = 1;                     // start new period
      while(period < count)          //
      { delay_ms(1000);              // delay 1 second
        count++;                     // bump count var'
      led = 1;                       // turn on led
      delay_us(500)                  // for 1/2 second
      led = 0;                       // and off
    You could use a circuit as simple as the "Spinning Class Strobe" (below) but you would need to change the potentiometer scale to represent a Period of 1 to 103 seconds.
    Regards, Mike
    mtrawczy's Avatar
    mtrawczy Guest
    Default Mac is that you?
    Mac is that you? it mark from inacomp
    Aug 2005
    Michigan, USA
    Quote Originally Posted by mtrawczy View Post
    Whoa! Blast from the past! Hi Mark... You got PM turned on?
    Regards, Mike McLaren, K8LH
