RS232 comms - need help with datasheet
Results 1 to 14 of 14
Threaded View
  1. #7
    malc-c's Avatar
    malc-c Guest
    Guys thanks very much for your quick input
    I have a hardware file which is then included in the main program. The config settings are
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 48
    'DEFINE  OSC 20  ; config settings 18F4580, 10mhz crystal
    ADCON1 = $0F
    I don't have a 12 Mhz crystal at the moment, but have tried with a 10Mhz one and the slowness is causing other issues with timings of the PID loops etc, I also don't get any hieroglyphics, but I only get a blank screen with a flashing cursor. So I'll pop down and get a few 12Mhz xtals from a local component suppliers and see what that does, as I really need to run this PIC as fast as it goes, and would like to resolve the comms issue.
    Thanks once again for your input,
    Sorry noticed I hadn't changed the OSC value
    OK tried this with a 10Mhz xtal, but still no joy - and is seems as slow
    'DEFINE  OSC 48
    DEFINE  OSC 40  ; config settings 18F4580, 10mhz crystal
    ADCON1 = $0F
    Will try the 12mhz xtal when I get one
    Last edited by malc-c; - 6th August 2010 at 15:19. Reason: noticed an error in the def osc
