RS232 comms - need help with datasheet
Results 1 to 14 of 14
Threaded View
  1. #3
    Hi, Malc
    There's an error somewhere on your side ...
    - OR your Xtal is 20 Mhz and you run the HS Osc ... and you have to declare 20 Mhz as a define
    - OR your Xtal is a 12 Mhz and you run the HS PLL Osc ... then you get real 48 Mhz as a clock frequency
    a 20 Mhz Xtal with HS PLL would give 80 Mhz ... if the clock could run those frequencies ( I only reached 64 Mhz ... but hardly !!! )
    (so, I do hope it's just a typo from yours ...)
    Just try
    - a 12Mhz Xtal in HS PLL mode with 48 Mhz as a DEFINE
    OR
    - a 10 Mhz Xtal .... With 40 Mhz as a DEFINE.
    of course, the UART values have to be set accordingly to the DEFINEd freq. ...
    looks Mr E's calculator does not agree with you ...
    DEFINE HSER_SPBRG 25  ' 115200 Baud @ 48MHz, 0.16%
    SPBRGH = 0
    OR
    DEFINE HSER_SPBRG 86  ' 115200 Baud @ 40MHz, -0.22%
    SPBRGH = 0
    Aheum ....
