Nap and sleep commands
Results 1 to 16 of 16
    Jun 2005
    Surrey, England
    Since our production circuit board has been professionally produced, there is not room for an extra Xtal and caps to drive TMR1 so I am trying to get the WDT to do the wake from sleep but with only partial success. In particular it doesnt seem to matter what I put as a postscaler value the WDT seems to cycle at a fixed period of around 578 mSec (suspiciously similar to Nap 5 frequency!). I am setting CONFIG2H by using this instead of the corresponding (commented out) line in 18F4550.INC:
    asm
           __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_256_2H
    ;must comment out in 18F4550.INC, or change there, else duplicate error
    endasm
    and then:
                i = 0
    lowpower:   lcdout $FE, $02, "WDT ", hex2 i,
                i = i + 1
                ' Do all the other stuff here (read ADC, store to Mem)
                clearwdt
                WDTCON = 1       'SWDTEN
    '           OSCCON.7 = 0     'Clear IDLEN - switch to SLEEP
                OSCCON.7 = 1     'Set IDLEN - switch to SEC_IDLE
    @           SLEEP
    @           NOP
                WDTCON = 0    ' WDT off
                goto lowpower
    and i increments 128 in 74 secs (period = 578mSec), but different values of _WDTPS_1024_2H etc. make no difference. What am I missing here? It makes no difference whether I make the CPU sleep or idle (except to the current consumption 3 or 15 mA - most of the 3 lost in the 9v voltage regulator).
    DEFINE NO_CLRWDT 1 makes no difference and the CLEARWDT also seems to make no difference!
    I would like to have the ability to control the frequency as expected and am thinking I can sleep for most of the 1 second I want and fine tune with another timer while awake - PAUSE would be the simplest. Any ideas gratefully received!
    Peter
    PS It just occurs to me that I am using a Bootloader - could this mean that the Postscaler is set by the bootloader and not changed by my program - if so can I do anything to change this ??edit the bootloader somehow.
    Most bootloaders will not allow you to change config settings, but the Microchip USB loader will, or you can change WDT config settings at runtime.
    See these threads:
    http://www.picbasic.co.uk/forum/showthread.php?t=4093
    http://www.picbasic.co.uk/forum/show...ghlight=config
    Or just open the loader .HEX file, make your changes, save it, and reprogram the PIC with the new loader firmware.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2005
    Surrey, England
    Now that is seriously helpful - Sorry I didnt spot those earlier on my searches - thank you so much for your help Bruce (and Darrel) - you are amazing!
    Peter
