Need 4 modes with just 3 switches - need all modes to be selectable QUICKLY!
Results 1 to 40 of 68
    The last error is because you have config settings in your code, and in your 16F690.INC file.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2009
    Success!!! (both with the compilation and on the breadboard!) ie if I Press switch 1 the LED blinks once, press Sw2 blinks twice etc - you'd never have thought a couple of blinking LEDs could make a grown man so happy!)
    Many *many* thanks Bruce for hanging in there with me - now off to have a dabble (& work out what you've done!)
    Mar 2009
    Ok, having just dabbled with this on breadboard for a short while, my immediate thought is that the wait for the finger being lifted from the switch, ever so slightly delays the led from lighting up instantly... which makes the actual switch depress feel a tad unresponsive.
    Without the wait, then there's obviously going to be another interupt when the finger is removed - but is this such a concern? - can't this second interupt be ignored with dedicated code?
    Poor Bruce ...
    It's not a book upon PBP he'll have to write , but a 32 parts encyclopaedia ...
    sure this explains ...
    No, no, Bruce, please , ... do not strike the head
    Mar 2009
    I'm not locked into your groove there ....just feeding back what I'm experiencing. The led obviously lights up after removing the finger from the switch, which sounds fine on paper but in practise it feels a little weird to the senses (ie I guess a lifetime of pushing buttons that immediately light up, is messing with my own grey matter - "Does not compute"!!)
    By the way, I'm not asking for anyone to write further code (Bruce has gone beyond the cause here!) ....just bouncing ideas of you all! IOC is all new to me - using the three diodes and the INT pin was ultra responsive....just wondering what ideas can be tabled to make IOC feel similar.
    Hi, Hank ( Humour ON : I do love how this sounds ...)
    seriously,
    I think twisting the Switch: and Process: labels could do it... at first sight.
    Mar 2009
    so wouldn't SOMETHING as noobesque (as befits me) like this suffice...
    Switch_Interrupt:
    If sw1 = 0 then
    mode = 1
    HIGH LED1  'green LED
    LOW LED2   ' red LED
    If sw2 = 0 then
    mode = 2
    HIGH LED2   ' red LED
    If sw3 = 0 then
    mode = 3
    LOW  LED1  'green LED
    HIGH LED2   ' red LED
    @ INT_RETURN
    (Yielding either a green LED, amber-esque led, red led)
    ok, it needs padding out....just wanted to get the main cut & thrust across.... the LED would change colour pretty darned quick, thereby giving the user the feeling of 'rapido'.
    Yes, sure there'll be an interupt generated when the finger is removed from the switch, but since none of the conditions in the Switch_interrupt subroutine would be met (since the pins would be high when the second interrupt happens) nothing will happen? - a few clock cycles wasted - but hey, there's heaps more where they came from?
    or would the quick succession interrupt from the finger being removed from the switch cause probs?
    Ok. This one blinks immediately, it's 133 words smaller, and a lot faster than the last...
    Edit: I don't see why your own version wouldn't work too, but you'll need to sort out the interrupt-on-release.
    -Bruce
    tech at rentron.com
    Mar 2009
    -wow Bruce, what can I say ....that nailed the puppy - my leds are positively zippy now (they light before I've even pressed the switch - and they know which switch I'm going to press...like I say you're good!)
    Can't thank you enough - to paraphrase the woman in Poltergeist "This thread is cleeeeaaan"
    ....no more questions your honour.
    Now, back to PCB layouts....wow, look at all the new space I now have!
    Aug 2009
    Paso Robles California
    Default 4 modes
    I have a question about this setup you can get 4 modes from two switches or do you really need 5 modes or no_mode also. could you always start in mode 1 which would be no button pressed? mode 2 left button, mode 3 right button, mode 4 both buttons, it would be smaller.
    sorry I may not have followed this thread correctly.
    Mar 2009
    Quote Originally Posted by l_gaminde View Post
    Thanks for your contribution, since you've asked, then here's bit more meat on the bone wrt the switching!
    The is for a guitar widget...as such the control box that the final pcb will be going into will be rather very small - I can actually only shoehorn four momentary (6mm square) switches in there - one of these switches acts as an analogue signal 'kill switch' (it simply shorts the guitar signal to ground giving a gated type effect - guitarist love kill switches!) The fourth switch is not integrated into the PIC circuitry at all - that leaves three switches.
    Ok, wrt the switching itself....when external power is unit is applied to the circuit, it just sits there waiting in standby for one of the switches to be pressed
    Now I could have used just one switch & have the player toggle through the differnt modes - but the modes are used in such a way, they need to be instantly accessible., hence...
    Pressing Switch1 takes the unit out of standby & instantly into Mode 1
    Pressing Switch2 takes the unit out of standby & instantly into Mode 2
    Pressing Switch3 takes the unit out of standby & instantly into Mode 3
    once the unit is active (ie in Mode 1, 2 or 3), you can switch between modes freely by just pressing any of the other switches (in other words, you don't have to deacrivate a mode by pressing the dedicated switch again, prior to selecting another switch/mode).
    the unit is deactivated by pressing on the switch for whichever mode is active, so if Mode 2 is active, press mode 2 switch & the unit goes into standy again ( an LED gives visual representation of whichever mode is active)
    That's pretty much the background - what flushed out this thread was me seeking ideas how to squeeze a 4th, 5th mode etc out of the three switches - obviously such requirements starts invoking double presses, holding switches down for longer or pressing two switches at once (I've still not decided on the final version ...but for now I've settled on pressing two switches together to get a 4th mode)
    Then Bruce came along - took a look at the way I'd implemented my interrupts on my schematic ...and chimed in that by changing the interrupt type from the shared 'INT' pin....to Interrupt on Change - I could save on some components/space. That was a fantastic bit of input, but then I hit some issues (I didn't know how to implement IOC - Bruce sorted this....then I got some compilation errors when I tried to combine IOC Interrupts & TMR1 Interrupts ....Darrel has hopefully sorted the latter)
    And you're pretty much bang up to date - the thread has took a few bends & curves...but I now know how to implement IOC interrupts, I've therefore saved some space on my (crammed PCB), this has allowed better track layout (but has also meant I've had to redesign my PCB....but worse, redesign/rebuild my test tig (I have a hinged pogo pin endowed test/debug setup - this allows me to program my PIC in situ, as well as facilitating a debug pin (I use the PICKIT2 UART2 to view stuff on my PC) as well as test points for monitoring the analogue aspect of the circuit etc)...
    (you can see the four switches I'm referring to on the PCB above - that space to the left will be filled up with other stuff so it's not free space)
    The closer I get to finishing this project - the further the goalposts seems to get away!
    I'm now using the downtime wrt my interrupt probs being sorted by Darrel, to hack an old eprom eraser my work was throwing away to reutilize as a UV lightbox (with a nice new PIC countdown timer) - I'v just removed the old clunky analogue switch....
    I started work on the UV Timer program (& PCB) earlier this afternoon - hope to have it finished over the weekend!
    Spanky,
    I've finished the changes to DT_INTS-14.
    You can download the new files from http://www.darreltaylor.com/DT_INTS-14/downloads.htm
    Anyone else using ver 1.00 should get them too.
    In trying to add some optimization to ver 1.00, I introduced a problem that caused the error when the Handlers crossed a Page boundary.
    I'm pretty sure that's fixed now.
    In your program it was right at the edge, and only 1 of the handlers crossed the boundary, which is why commenting one of them allowed it to compile.
    It also gave me a chance to fix a problem caused by MPLAB 8.53 when using 16F1 chips.
    Thanks again for bringing the problem to my attention HankMcSpank.
    Mar 2009
    Spanky,
    And thank you for such great support - it compiles like a dream now....
    http://www.tweak3d.net/forums/imageh...85fadccc3b.gif
    (btw: if you'd waited another 90 mins, the new DTS_INTS-14.bas have been released on my birthday (UK time) ....& in that vein, I promise not to use it until then! )
    OK, enough celebration.
    Get back to work on that guitar thingy.
