Need 4 modes with just 3 switches - need all modes to be selectable QUICKLY!
Results 1 to 40 of 68
    Aug 2005
    Michigan, USA
    Hey Bruce,
    Despite the very warm welcome from everyone here I feel that posting non-PBP examples isn't cool and probably is not helping anyone so perhaps it's best if I just stay on the sidelines and stop preaching (lol).
    Cheerful regards, Mike
    Hi Mike,
    Sorry you feel that way, but i think everything you post has some benefit to some.
    Large portions of Darells' code that everyone uses BIG time here is in assembler, and that doesn't detract from its usefulness.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    See if this works.
    -Bruce
    tech at rentron.com
    Mar 2009
    See if this works.
    Bruce,
    Many thanks for the example - you're a diamond.
    Alas, it's not compiling on my PC - I'm certain that I've a parameter wrong somewhere or other on my machine, becuase after finishing posting last night such was my keeness, I spent another hour trying to get a very minimalist IOC test program to compile - & I was getting the same type of compilation errors.
    The errors I'm seeing (both last night & now with your program) are as follows....
    Error[128] [filepath]test_ioc.asm: Missing Arguments
    Error[113] [filepath]test_ioc.asm: Symbol not previously defined (IntFlagReg)
    Error[113] [filepath]test_ioc.asm: Symbol not previously defined (IntFlagBit)
    Error[101] [filepath]test_ioc.asm: ERROR (Interupt Source (IntFlagReg, IntFlagBit) not found
    If I remove the RABC_INT entry in in the interupt header & replace with INT_INT - it always compiles fine.
    Any tips greatfully received, as I'm not getting off the ground with this IOC melarkey (& I'm chomping at the bit to breadboard the MKII 'no diodes' puppy!)
    Many thanks once again.
    Hank.
    (PS I'm using V1.0 - the latest DTS-14.BAS)
    Quote Originally Posted by HankMcSpank View Post
    Bruce,
    Hi hank ...
    Did you select the right processor ???
    Compiles fine, here ( 386 Words ).
    PBP 2.60 " not patched yet" ...
    Mar 2009
    Hi hank ...
    Compiles fine, here ( 336 Words ).
    Hi Alain,
    I'm selecting my intended PIC (a 16F690)
    Likewise PBP V2.6 (unpatched) but just patched it about 20 mins ago - still didn't compile (same errors)
    I'm thinking it's likely something to do with my DTS_INTS-14.bas (I used the one at the bottom of this page... http://darreltaylor.com/DT_INTS-14/intro2.html )
    ( A quick search for some of the errors I'm seeing brings up stuff relating to DT's interupt routines - so likely something I've not got right wrt that aspect )
    Drop a copy of DT_INTS-14.bas and ReEnterPBP.bas in the same directory as the file you're compiling, or save the file to the same directory they're already in.
    -Bruce
    tech at rentron.com
