Thanks Hank. But you're good too. You spotted this. Good catch. Interrupt-on-change is exactly what it means, but you have to know how it works to really take advantage of it.
So here's a quick tutorial.
Sample the port/ports first, then enable interrupt-on-change, but only after all port pins with this interrupt enabled are in the non pressed state.
This takes a snap-shot of pins, which is used later on to determin the change-of-state when a switch is pressed. I.E. a transition from logic 1 to 0, assuming a switch grounds the pin, and it has internal pull-ups enabled.
What you'll normally want to do is use a WHILE WEND statement to WAIT until all switches are in the un-pressed state. I.E. just wait until all port pins that have interrupt-on-change enabled return a value indicating the switch is NOT pressed. Then enable int-on-change.
The last read of the port is saved & used to determine the transition from un-pressed to pressed - or the transition from logic 1 to 0.
And - yes - I know Mike will yell at me for suggestiing this, but I normally wait for the pin to return to the un-pressed state in my interrupt handler, then exit & clear the interrupt flag bit. It's just so much easier than sampling pins for a switch-press in a timer-based interrupt. But - Mike does have some cool stuff to do this if you're interested.
Interrupt-on-change requires you to read the port first to end the miss-match condition before it will allow you to clear the interrupt flag bit, so it just makes sense to wait until the switch is released before clearing the flag bit & exiting the int handler.
If you don't (like you just mentioned), then you end up having an interrupt generated by switch press & switch release - because both events = a change after you have read the port, and cleared the int-on-change flag bit, and exit the int handler.
Assuming the user isn't going to press & hold a switch down for any length of time, this is for sure the way to go, and it can be incredibly fast if the user just taps & releases the switch.
If the user does hold a switch down, it will simply wait for them to release the switch before exiting the interrupt handler, which also works fine, but it does delay exit from your inerrupt handler until switch release.
This is really simple with just a few extra lines of code in your interrupt handler like this:
And you can do this for any port pin with int-on-change enabled.Code:IF PORTB.6 = 0 THEN WHILE PORTB.6 = 0 WEND ENDIF
Hope this helps!
