Need 4 modes with just 3 switches - need all modes to be selectable QUICKLY!
Results 1 to 40 of 68
    Mar 2009
    Quote Originally Posted by Kamikaze47 View Post
    I assume the switches are right next to eachother? if so, why not make it so that mode 4 can be activated by pressing 2 and 3 at the same time. To do this i would suggest that for the interrupt handler for switch 3, have a quick loop that checks button 2 for a short time (something like 20ms). If it is pressed, activate mode 4, else activate mode 3.
    The "double click" can be done too, but requires a bit more logic and probably a timer.
    Thanks for your input...I'd pondered that option - and yes the switches are near each other - but I worry a little over the actual logistics. A guitarist will be selecting these switches with his right hand - this will already have a plectrum in it (between the thumb and forefinger), this leave him needing to press two switches concurrently but with two fingers partially out of action - then there's the accuracy at landing fingers on two small (3.5mm diameter) button tops 'on the fly' in mid solo etc on a dimly lit stage etc.
    How about using 1 switch as the mode switch? Use a toggle switch to select how the other 2 switches act.
    Mode switch = 1, other two act as switches 1 & 2. Mode switch = 0, other two act as switches 3 & 4.
    Or use a normally open mode switch. Press once, in mode 1. Press again, in mode 2.
    Kind of like the Shift key on your keyboard that doesn't need to be held down to select other key functions.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Perth, Australia
    Post
    In that case the double press is probably the best option. Something like this:
    button3 interrupt handler:
    IF timer is not running THEN
    set timer so it will overflow after x time (max double click time), and start timer running
    set to mode 4
    stop timer
    timer interrupt handler:
    set to mode 3
    stop timer
    Mar 2009
    Bruce,
    Thanks for the idea - I'm unable to use a toggle switches (though I'd have loved to have), because this PIC/PCB/Switches are going in a small control box with just 5.5mm headroom inside (just under 1/4"" in old money)....also the control box will affixed to the guitar body with four small adhesive pads - a toggle switch would mean the player would be applying force 'sideways' on the switch (with respect to the control box surface), which could place some stress of the adhesive fixings whereas momentary switches, the force will be down (ie pressing the adhesive pads down).
    Kamikaze47,
    i'm not a programmer...& this stuff doesn't come naturally to me....but thanks for the example to get me started, I'll see how I can weave that concept into my code over the next day or two.
    Perth, Australia
    Quote Originally Posted by HankMcSpank View Post
    Kamikaze47,
    Give it a try, and if you get stuck, post the code you have written here and we can help.
    Mar 2006
    China
    Default chords
    3 buttons right? 4 modes.....
    press button 1 to enter mode 1
    press button 2 to enter mode 2
    press button 3 to enter mode 3
    press both 1&2 to enter mode 4
    press both 2&3 to enter mode 5
    I assume the switches are right next to eachother? if so, why not make it so that mode 4 can be activated by pressing 2 and 3 at the same time. ...
    What if the accuracy wasn't as difficult?
    Maybe any 2 buttons pressed at/near the same time could be mode 4.
    You wouldn't have to find the correct 2 buttons. Any two (or 3) will do. So it should be easier for the player.
    Aug 2005
    Michigan, USA
    Three pins will easily support up to six Charlieplexed switches (requires one diode per switch).
