I went from the 4550 to the 2550 and have an interesting problem.
Went back to the basics http://www.picbasic.co.uk/forum/showthread.php?t=5806 and I still do not see what I am doing wrong.
In order for the device to connect I have to move the USBINIT below the FOR/NEXT loop...If USBINIT is in the "correct" place the device will not connet.
Doing that the device connects and will send data but the data looks like this.
` ($#_H! c 8 X- &X6USB CONNECTED!
The same happens on a 32 or 64 bit machine.
I have a 1.0uF cap on VUSB and I am running the chip at 3.3 volts as I do with a 4550.
The machine I am on tonight is running PBP 2.50
The code.
'USB_2550
@ __CONFIG   _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
@ __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
@ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
@ __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
@ __CONFIG    _CONFIG4L, _LVP_OFF_4L
DEFINE    OSC 48
Buffer    VAR BYTE[16]
Cnt       VAR BYTE
B0        VAR BYTE
B1        VAR BYTE
ADCON1 = 15               ' Set all I/Os to Digital
CMCON = 7                 ' Disable Comparators
Cnt = 16
for b0 = 0 to 15
    lookup b0,["USB CONNECTED!",10,13],B1
    BUFFER(B0) = B1
    NEXT B0
 USBINIT
' Main Program Loop
Loop:
    USBService        ' Must service USB regularly
    USBOut 3, Buffer, Cnt, loop
    goto loop
Same code, same machine(s) with a 4550 works fine.
