writing word variables to data memory
Results 1 to 14 of 14
    malc-c's Avatar
    malc-c Guest
    The part I really find it hard to grasp is the WA[1], WA[2] bit and how to format the two eprom locations
    So assuming the start address is 80
    Could this then be changed to
    For x = 0 to 3
    For fn = 0 to 8
    Write Word (80+fn) AlarmHigh[fx] highbyte
    If fn >= 4 then
    x = 0
    Write Word (80+fn) AlarmHigh[fx] lowbyte
    Next fn
    Next x
    I just can't seem to make this sink in !
    [QUOTE=malc-c;92222]
    For x = 0 to 3
    For fn = 0 to 8
    If fn >= 4 then
    x = 0
    Next fn
    Next x
    Oh my god ... you really thick ... ( YOU told it, not me ... )
    following your explanation:
    [code]
    For fn = 0 to 3
    Write (80+2*fn), Word AlarmHigh[fn+1]
    next fn
    [code]
    LOCATION MUST BE PLACED BEFORE THE DATA !!!
    ( sorry for other users , but it's the 4 th time I repeat ... )
    Business looks to have turned you deaf and blind ...
    malc-c's Avatar
    malc-c Guest
    This seems to compile
      for fn = 0 to 3
      write (10*fn + 80),lightsetHR[fn]
      write (10*fn + 82),lightsetMN[fn]
      write (10*fn + 84),lightoffHR[fn]
      write (10*fn + 86),lightoffMN[fn]
      write (10*fn + 88),word droptemp[fn]
      write (10*fn + 90),word normtemp[fn]
      write (10*fn + 92),StartHour[fn]
      write (10*fn + 94),StartMin[fn]
      write (10*fn + 96),StopHour[fn]
      write (10*fn + 98),StopMin[fn]
      write (10*fn + 100),word alarmhigh[fn]
      Write (10*fn + 102),word alarmlow[fn]
      next fn
    Quote Originally Posted by malc-c View Post
      for fn = 0 to 3
      next fn
    Malc,
    Yes, It compiles BUT:
    IF fn = 1 ...
    @ location 110 & 111 you write AlarmHigh[1]
    IF fn = 2
    location 110 & 111 are overwritten by NormTemp[2]
    IF fn = 3
    location 110 is overwritten by lighsetHR[3]
    and I only give you 3 examples ...
    so, ... try
     write  80,lightsetHR[1]),lightsetMN[1],lightoffHR[1],lightoffMN[1],word droptemp[1] ,word normtemp[1],StartMin[1],StopHour[1],StopMin[1],word alarmhigh[1],StartHour[1],word alarmlow[1] ; need 16 locations
     write  100,lightsetHR[2]),lightsetMN[2],lightoffHR[2],lightoffMN[2],word droptemp[2] ,word normtemp[2],StartMin[2],StopHour[2],StopMin[2],word alarmhigh[2],StartHour[2],word alarmlow[2]
     write  120,lightsetHR[3]),lightsetMN[3],lightoffHR[3],lightoffMN[3],word droptemp[3] ,word normtemp[3],StartMin[3],StopHour[3],StopMin[3],word alarmhigh[3],StartHour[3],word alarmlow[3]
     write  140,lightsetHR[4]),lightsetMN[4],lightoffHR[4],lightoffMN[4],word droptemp[4] ,word normtemp[4],StartMin[4],StopHour[4],StopMin[4],word alarmhigh[4],StartHour[4],word alarmlow[4]
    This Way, your EEPROM Map is neat ... and you know where to find What ...
    What did you tell me by PM ???
    I just call that pedagogics ...
    malc-c's Avatar
    malc-c Guest
    Alain,
    Many thanks......
    Apologies for the PM - just having a bad day.
    I'll give that a try in the morning
    Miami, Florida USA
      for fn = 0 to 3
      next fn
    Malcolm,
    This code won't work anymore like Alain already mentioned. Now, you have words instead of bytes. Also, now you have 12 variables instead of 10 .
    Now, if you try to write 12*2*4=96 bytes at location 80 then you are going to overwrite all the stuff that you wrote at location 150 with your DATA command (from your other post).
    I would suggest that you should try first to clear up the mess by organizing the data that you put in EEPROM. It looks like the amount of data that you are putting in memory by doing "Data @0,0 and Data @150" is 58 bytes for each DATA command. So, instead of "Data @0,0 and Data @150" try something like "Data @0,0 and Data @58". Then from location 116 and up you have no data that could get overwritten.
    Next, try the same code as above but with the following changes.
    for fn = 0 to 3
      write (12*fn + 116),lightsetHR[fn]
      write (12*fn + 118),lightsetMN[fn]
      write (12*fn + 120),lightoffHR[fn]
      write (12*fn + 122),lightoffMN[fn]
      write (12*fn + 124),word droptemp[fn]
      write (12*fn + 126),word normtemp[fn]
      write (12*fn + 128),StartHour[fn]
      write (12*fn + 130),StartMin[fn]
      write (12*fn + 132),StopHour[fn]
      write (12*fn + 134),StopMin[fn]
      write (12*fn + 136),word alarmhigh[fn]
      write (12*fn + 138),word alarmlow[fn]
    next fn
    I replaced 10 by 12 since now you have 12 variables. I hope that this helps.
    Anonymous
    malc-c's Avatar
    malc-c Guest
    Default Thanks
    Robert, thanks for the input, and yes I agree that it needs tidying up. I've already moved Alain's code down by 10 (ie first line starts at 70, the second 90 etc as I thought that I might be getting close to over-writing data at the 150 location.
    Guys, I appreciate the time and trouble you have gone to... sorry that it seemed an uphill struggle - it must be the medication I'm on (that's my story and I'm sticking to it )
    Lightbulb
    Hi, Malc you also can optimize memory use a bit not to hit location 150 ... see: 80 = $ 50 ... as you need 16 locations per fn value ... locations $50 ...$5F for fn = 1 ............ $60 ...$6F for fn = 2 ... ... .............$80 ... $8F for fn = 4 ... $8F = 143 ... it makes it !!! so, simply change locations to:
    write  $50,lightsetHR[1]),lightsetMN[1],lightoffHR[1],lightoffMN[1],word droptemp[1] ,word normtemp[1],StartMin[1],StopHour[1],StopMin[1],word alarmhigh[1],StartHour[1],word alarmlow[1] ; need 16 locations
     write  $60,lightsetHR[2]),lightsetMN[2],lightoffHR[2],lightoffMN[2],word droptemp[2] ,word normtemp[2],StartMin[2],StopHour[2],StopMin[2],word alarmhigh[2],StartHour[2],word alarmlow[2]
     write  $70,lightsetHR[3]),lightsetMN[3],lightoffHR[3],lightoffMN[3],word droptemp[3] ,word normtemp[3],StartMin[3],StopHour[3],StopMin[3],word alarmhigh[3],StartHour[3],word alarmlow[3]
     write  $80,lightsetHR[4]),lightsetMN[4],lightoffHR[4],lightoffMN[4],word droptemp[4] ,word normtemp[4],StartMin[4],StopHour[4],StopMin[4],word alarmhigh[4],StartHour[4],word alarmlow[4]
    and moreover, you'll see your values nicely ordered into your EEPROM Watch Window ... Have a nice day Alain PS: sorry , but there's a forum bug with " carriage return ", it seems ...
