64-bit division
Results 1 to 16 of 16
Thread: 64-bit division
    To start with you probably need to use the MPASWIN that came with your PBP CD.
    Install MPLAB from the CD to the default place and MPASMWIN will be there. Sometimes the one downloaded will not work.
    Then I will guess that you are using Micro Code Studio as a code editor. Go to Tool on the tool bar and select compiler options then under the Assembler tab select MPASM.
    Then give it a try.
    Aug 2010
    I'm so antiquated that I still use Notepad to edit my PBP programs! Also I use Notepad to edit programs in several other languages. It doesn't have any bells and whistles, but is quick and practical.
    About installing MPLAB to the default place, that isn't possible, because for starters I run the whole PIC stuff on drive E:. Perhaps this is the reason why MPASM won't work. I do have the paths properly set up, but who knows what they do with them!
    This whole thing is getting too problematic. I had hoped that someone could propose a simple PBP routine, using the 16-bit math provided in PBP, to do this 64-bit division. I will better continue in that line, rather than setting up a new programming environment, learning to use it, perhaps reformat and repartition my hard disk, to be able to use that assembly library!
    The worst case is that I have to implement bitwise division in PBP, which would be rather slow and inelegant. Surely somebody has a better idea!
    Default Getting your installation right will save you headaches later
    Quote Originally Posted by Manfred View Post
    Darrel's N-Bit math is the only simple PBP routine I know of. 64 bits on an 8 bit device is not so simple. Most program examples and includes on this site, all require mpasm, so you will probably eventually want to go there anyway. Why not install PBP as the manual suggests (on page 5) and put PBP in a folder on the C drive. Make your life easier, not harder.
    If you want a routine, you can follow the links on Darrel's http://www.picbasic.co.uk/forum/cont...153-N-Bit_MATH and retrieve assembly code to your liking. http://avtanski.net/projects/math/
    Here is the bare assembly 64 bit division:
    #include
              ; remove this if not necessary
    #define PRECISION 64             ; byte size for registers
    M_STOR_STATUS macro WHERE
        movf    STATUS,w
        movwf   WHERE
    M_RETR_STATUS macro WHERE
        movf    WHERE,w
        movwf   STATUS
        cblock 0x20
        REG_X:PRECISION
        REG_Y:PRECISION
        REG_Z:PRECISION
        REG_COUNTER
        REG_STATUS
        REG_T1
        REG_T2
        REG_ROT_COUNTER
        endc
        org 0x00
        goto    M_TEST
        org 0x04
        goto    M_TEST
        org 0x0c
    M_TEST                          ; Test subroutine
        movlw   REG_X
        call    M_CLR               ; clear register X
        movlw   REG_Y
        call    M_CLR               ; clear register Y
        movlw   REG_Z
        call    M_CLR               ; clear register Z
        movlw   0x8A
        movwf   REG_X               ; set register X (lowest byte)
        movlw   0xFC
        movwf   REG_Z               ; set register Z (lowest byte)
        call    M_ADD               ; adds X and Z, result in Z
        movlw   0x05                ; set regiester X (lowest byte)
        movwf   REG_X
        call    M_DIV               ; divide Z by X, result in Y, remainder in Z
        sleep                       ; end of test
    M_CLR                           ; clear a register
        movwf   FSR
        movlw   PRECISION
        movwf   REG_COUNTER
    M_CLR_loop
        clrf    INDF
        incf    FSR,f
        decf    REG_COUNTER,f
        btfss   STATUS,Z
        goto    M_CLR_loop
    M_INC                           ; increment a register
        movwf   FSR
        movlw   PRECISION
        movwf   REG_COUNTER
    M_INC_loop
        incf    INDF,f
        btfss   STATUS,Z
        incf    FSR,f
        decf    REG_COUNTER,f
        btfss   STATUS,Z
        goto    M_INC_loop
    M_DEC                           ; decrement a register
        movwf   FSR
        movlw   PRECISION
        movwf   REG_COUNTER
    M_DEC_loop
        decf    INDF,f
        movlw   0xFF
        subwf   INDF,w
        btfss   STATUS,Z
        incf    FSR,f
        decf    REG_COUNTER,f
        btfss   STATUS,Z
        goto    M_DEC_loop
    M_ROL                           ; rotate a register to the left
        movwf   FSR
        M_STOR_STATUS REG_STATUS
        clrf    REG_COUNTER
    M_ROL_loop
        M_RETR_STATUS REG_STATUS
        rlf     INDF,f
        incf    FSR,f
        incf    REG_COUNTER,f
        movlw   PRECISION
        subwf   REG_COUNTER,w
        btfss   STATUS,Z
        goto    M_ROL_loop
    M_ROR                           ; rotates a register to the right
        movwf   FSR
        movlw   PRECISION-1
        addwf   FSR,f
        clrf    REG_COUNTER
    M_ROR_loop
        rrf     INDF,f
        decf    FSR,f
        incf    REG_COUNTER,f
        movlw   PRECISION
        subwf   REG_COUNTER,w
        btfss   STATUS,Z
        goto    M_ROR_loop
    M_CMP                           ; Z <=> X -> STATUS(C,Z)
                                    ; STATUS,C set if Z => X;
                                    ; STATUS,Z set if Z == X
        clrf    REG_COUNTER
    M_CMP_loop
        movf    REG_COUNTER,w
        sublw   REG_Z+PRECISION-1
        movwf   FSR
        movf    INDF,w
        movwf   REG_T1
        movf    REG_COUNTER,w
        sublw   REG_X+PRECISION-1
        movwf   FSR
        movf    INDF,w
        subwf   REG_T1,f
        btfss   STATUS,Z
        incf    REG_COUNTER,f
        movlw   PRECISION
        subwf   REG_COUNTER,w
        btfss   STATUS,Z
        goto    M_CMP_loop
    M_ADD                           ; Z + X -> Z
        bcf     STATUS,C
        clrf    REG_STATUS
        clrf    REG_COUNTER
    M_ADD_loop
        clrf    REG_T1
        btfsc   REG_STATUS,C
        incf    REG_T1,f
        clrf    REG_STATUS
        movlw   REG_X
        addwf   REG_COUNTER,w
        movwf   FSR
        movf    INDF,w
        addwf   REG_T1,f
        btfsc   STATUS,C
        bsf     REG_STATUS,C
        movlw   REG_Z
        addwf   REG_COUNTER,w
        movwf   FSR
        movf    INDF,w
        addwf   REG_T1,f
        btfsc   STATUS,C
        bsf     REG_STATUS,C
        movf    REG_T1,w
        movwf   INDF
        incf    REG_COUNTER,f
        movlw   PRECISION
        subwf   REG_COUNTER,w
        btfss   STATUS,Z
        goto    M_ADD_loop
    M_SUB                           ; Z - X -> Z
        clrf    REG_COUNTER
        bsf     REG_STATUS,C
    M_SUB_loop
        bsf     REG_T2,C
        movlw   REG_Z
        addwf   REG_COUNTER,w
        movwf   FSR
        movf    INDF,w
        movwf   REG_T1
        movlw   REG_X
        addwf   REG_COUNTER,w
        movwf   FSR
        movf    INDF,w
        subwf   REG_T1,f
        btfss   STATUS,C
        bcf     REG_T2,C
        btfsc   REG_STATUS,C
        goto    M_SUB_no_carry
        movlw   0x01
        subwf   REG_T1,f
        btfss   STATUS,C
        bcf     REG_T2,C
    M_SUB_no_carry
        movlw   REG_Z
        addwf   REG_COUNTER,w
        movwf   FSR
        movf    REG_T1,w
        movwf   INDF
        bsf     REG_STATUS,C
        btfss   REG_T2,C
        bcf     REG_STATUS,C
        incf    REG_COUNTER,f
        movlw   PRECISION
        subwf   REG_COUNTER,w
        btfss   STATUS,Z
        goto    M_SUB_loop
        btfss   REG_STATUS,C
        bcf     STATUS,C
    M_MUL                           ; X * Y -> Z
        movlw   REG_Z
        call    M_CLR
        movlw   PRECISION*8+1
        movwf   REG_ROT_COUNTER
    M_MUL_loop
        decf    REG_ROT_COUNTER,f
        btfsc   STATUS,Z
        btfsc   REG_Y,0
        call    M_ADD
        bcf     STATUS,C
        movlw   REG_Y
        call    M_ROR
        bcf     STATUS,C
        movlw   REG_X
        call    M_ROL
        goto    M_MUL_loop
    M_DIV                           ; Z / X -> Y;  remainder -> Z
        movlw   REG_Y
        call    M_CLR
        movlw   PRECISION*8
    M_DIV_rot_loop
        btfsc   REG_X+PRECISION-1,7
        goto    M_DIV_loop
        movlw   REG_X
        bcf     STATUS,C
        call    M_ROL
        btfss   STATUS,Z
        goto    M_DIV_rot_loop
        bsf     STATUS,Z
    M_DIV_loop
        call    M_CMP
        M_STOR_STATUS REG_T2
        movlw   REG_Y
        call    M_ROL
        M_RETR_STATUS REG_T2
        btfsc   STATUS,C
        call    M_SUB
        bcf     STATUS,Z
        bcf     STATUS,C
        movlw   REG_X
        call    M_ROR
        incf    REG_ROT_COUNTER,f
        movlw   PRECISION*8+1
        subwf   REG_ROT_COUNTER,w
        btfss   STATUS,Z
        goto    M_DIV_loop
    But I still think installing PBP right, and using Mpasm with Darrels N Bit Math is the way to go. Especially if you want easy. Once you get your program set up right, you will be able to easily add different include files.
    http://www.scalerobotics.com
    Aug 2010
    Well, I'm getting old, and as you surely know, we old guys tend be get used to our own ways of doing things! http://www.picbasic.co.uk/forum/images/smilies/wink.gif
    Thank you a lot for all your help, but it simply seems too complicate to have all that looooong assembly code put in, just to do one single division! Reconfiguring my PC to be able to install PBP in the default configuration, and then learning to use the new programs, and so on, would simply take FAR too long. I want to get my project going soon, instead of embarking in a new project of PC reconfiguration, learning to use a new programming environment, and who knows what else.
    So I have totally turned around the way I calculate the value I need. Instead of the routine that required the 64 bit division to arrive at the final 32 bit tuning value I need for my DDS, I prepare the data in 16 bit chunks and calculate the 32 bit tuning value as the last step in the process, using PBP's "*" and "**" operators. In doing so, I loose some tuning range, and some tuning resolution, compared to the method that needs the 64 bit division. But both of these losses are acceptable for this particular project, so I will keep this for now.
    In the future I will probably do more demanding projects using a DDS, and at that point I will get back to needing multibit division... But based on the newly acquired experience, I will then use an 18-series PIC, so I can use PBP's 32 bit math, which should allow enough tuning range and resolution for even quite high requirements, using the same algorithm I implemented a while ago.
    By the way, the configuration of my PC has evolved from the very first PC I owned, almost 30 years ago, and that's why it doesn't conform to modern Windows practice. I use a large quantity of specific programs , many of them written by myself. Over the years, I have added to this setup, and transferred it from each PC to the next more modern one.
    Any attempts I have done to set up a new system on a new PC, and getting everything to work there, have proven to take so much time that I threw the towel before getting anywhere close to finishing. That's why I still use my old configuration.
    Thanks again. I have learned that apparently there is no simple way to use PBP's 16 bit math to create 32 or 64 bit math, and so it's better for me to use a workaround.
    Using note pad is cool. And to talk about non standard setups I mostly run on Linux and either use Emacs or gEdit for code writing.
    I just figured you were a newb that is why I assumed you were using Micro Code Studio ... Sorry.
    When you do start using 18F's MPASM will be required. It cam be evoked from the command line from just about anyplace. When you get to that point and maybe need some help we will be here.
    Aug 2010
    I should not have much trouble using MPASM. I just tried it with the present version of my program, and it works well. It only reported that strange error when there was the n-bit math code present.
    Without that code, it assembles my program well, but still reports over 200 messages about crossing page boundaries. I hope these messages can be disabled somehow, because they make any real error messages scroll out of the window AND out of the screen buffer!
    I guess that with enough time, things will fall into place.
