Help with code in Assembly ! Something is Wrong
Results 1 to 7 of 7
    Default Help with code in Assembly ! Something is Wrong
    Someone helped me with this interrupt part of the code in assembly when I was creating a dimmer progam for my fan. Unfortunately I cannot get hold of that person & I don't have any knowledge of assembly, so if someone can help me correct the problem...
    This is the only part of the code in assembly, rest is in PBP & I am comfortable dealing with it. Now, this following code controls the speed of a fan based on a variable DimmerVal which is a byte. In my code when I assign DimmerVal=0, fan stops & DimmerVal=255 takes it to full speed. The problem is that the fan speed sometimes variates & automatically goes back to the assigned speed after some moments, looks like some kind of synchronisation error with zero-detector input, but I am not sure because I can't understand this code. can someone help please....
    ISR:
    asm
            movwf   wsave
            swapf   STATUS, W
            clrf    STATUS
            movwf   ssave
            movf    FSR,w
            movf    fsave
            movf    PCLATH, W
            movwf   psave
            ; get ready to jump within the ISR page
            movlw   ((INTHAND) >> 8)
            movwf   PCLATH
            btfsc   INTCON, INTF
            goto    ZeroCrossingInt
            btfss   INTCON, T0IF
            goto    EndInt
    T0Overflow
            bcf     INTCON, T0IF
            bsf     _oDimmer
            goto    EndInt
    ZeroCrossingInt
            bcf     INTCON, INTF
            movf    _DimmerVal,w
            movwf   TMR0
            bcf     _oDimmer
    EndInt  ; restore the machine state and return from interrupts
            movf    fsave,w
            movwf   FSR             ; restore FSR
            movf    psave,w
            movwf   PCLATH          ; restore PCH
            swapf   ssave,w
            movwf   STATUS          ; restore Status
            swapf   wsave,f
            swapf   wsave,w         ; restore WREG
            retfie
    endasm
    ___________________
    WHY things get boring when they work just fine?
    Perth, Australia
    If it helps, I have commented the ASM code with the equivalent PBP commands. Its hard to say what the problem is without the rest of the program.
    ISR:
    asm
            movwf   wsave             ; Save the machine state for restore at end of interrupt routine
            swapf   STATUS, W
            clrf    STATUS
            movwf   ssave
            movf    FSR,w
            movf    fsave
            movf    PCLATH, W
            movwf   psave
            movlw   ((INTHAND) >> 8)                ; PCLATH=INTHAND>>8
            movwf   PCLATH
            btfsc   INTCON, INTF                    ; If INTF=1 THEN GOTO ZeroCrossingInt
            btfss   INTCON, T0IF                    ; If T0IF=0 THEN GOTO EndInt
            goto    EndInt
    T0Overflow                                      ; T0Overflow:
            bcf     INTCON, T0IF                    ; T0IF=0
            bsf     _oDimmer                        ; oDimmer=1
            goto    EndInt                          ; GOTO EndInt
    ZeroCrossingInt                                 ; ZeroCrossingInt:
            bcf     INTCON, INTF                    ; INTF=0
            movf    _DimmerVal,w                    ; TMR0=DimmerVal
            movwf   TMR0
            bcf     _oDimmer                        ; oDimmer=0
            movf    fsave,w
            movf    psave,w
            swapf   ssave,w
            swapf   wsave,f
            retfie
    endasm
    Perth, Australia
    This may be more helpful to you. This is the same thing, but done using DT's instant interrupts. You also need to INCLUDE the DT_INTS and ReEnterPBP files relevant to your PIC.
    INT_LIST macro ;    IntSource, Label,       Type, ResetFlag?
            INT_Handler TMR0_INT,  tmr0_handler, PBP,  yes
            INT_Handler INT_INT,   int_handler,  PBP,  yes
        INT_CREATE
    @ INT_ENABLE TMR0_INT
    @ INT_ENABLE INT_INT
    ' your main program
    tmr0_handler:
    oDimmer=1
    @ INT_RETURN
    int_handler:
    TMR0=DimmerVal
    oDimmer=0
    @ INT_RETURN
    Question Getting there.......
    Quote Originally Posted by Kamikaze47 View Post
        INT_CREATE
    ' your main program
    tmr0_handler:
    oDimmer=1
    @ INT_RETURN
    int_handler:
    TMR0=DimmerVal
    oDimmer=0
    @ INT_RETURN
    I am still trying to understand the above code -
    Is this code running timer0 interrupt all the time?
    I learnt that in DIMMERS, you have to control the +ve half of the cycle only, so timer0 should be loaded after checking the positive half making the PIC pin HIGH and keeping the triac ON for that period.
    ALSO FOR THE ASM PART:
            btfsc   INTCON, INTF                    ; If INTF=1 THEN GOTO ZeroCrossingInt (1)
            goto    ZeroCrossingInt                 ;        (2)
            btfss   INTCON, T0IF                    ; If T0IF=0 THEN GOTO EndInt                (3)
            goto    EndInt                              ;                                                           (4)
    T0Overflow                                      ; T0Overflow: (5)
            bcf     INTCON, T0IF                    ; T0IF=0  (6)
            bsf     _oDimmer                        ; oDimmer=1 (7)
            goto    EndInt                          ; GOTO EndInt (8)
    ZeroCrossingInt                                 ; ZeroCrossingInt: (9)
            bcf     INTCON, INTF                    ; INTF=0 (10)
            movf    _DimmerVal,w                    ; TMR0=DimmerVal(11)
            movwf   TMR0                             ;(12)
            bcf     _oDimmer                        ; oDimmer=0(13)
    I believe everytime this interrupt will be entered: (Please correct me where I go wrong)
    --- Statement (1) in the code will always be true (this is the reason why interrupt has happened), so the code will jump to (9), it will act on (10) & then (11) & (12) -- SO WHERE DOES IT WAIT FOR TIMER0 TO RUN OUT & WHY STATEMENT (13) IS THERE CLEARING _oDimmer when this bit is not set in the sequence I just understood and explained above.
    --- When does code enters (5) ? Does after (13) code goes to (3)?
    ___________________
    Perth, Australia
    Statement (1) will not always be true. The interrupt routine services all interrupts. Statements (1)-(4) are just checking which interrupt flag is set (which interrupt went off). If it was the INT interrupt then it jumps to the ZeroCrossingInt section. If it was the TMR0 interrupt then it continues on to the T0Overflow section.
    I don't know what else is happening in your program, so I can only tell you what that interrupt routine is doing which is this:
    When timer0 overflows: set oDimmer to 1.
    When external interrupt (INT) occurs: set timer0 value to "DimmerVal" and set oDimmer to 0.
    Is it possible to PM you?
    ___________________
    Perth, Australia
    If you like, but if its a question that you think others may benefit from the answer too, then you may as well ask in the thread.
