Generate sawtooth with PIC?
Results 1 to 11 of 11
    Default Generate sawtooth wave with PIC -- software solution.
    Great suggestions by some of the most knowledgable contributors to the list.
    I elected to go with a simple software approach using PWM, without lookup tables. Most of the code is to provide DT's Instant Interrupt.
    I initialize the 16F690 HPWM at 32kHz, zero duty. With each TMR1 interrupt I increment the duty register until I reach the desired maximum voltage on the sawtooth, then start over at zero. A low-pass RC filter smooths the output. Peak voltage and frequency are easily modified. I retained the oscope interrupt timing signal on RC.4; you will have to change some parameters if this is omitted.
    Other ways to tackle this include a 555-based generator, R2R ladder network or dedicated parallel-interface DACs. Microchip has an application note http://www.microchip.com/stellent/id...pnote=en011071 that may be helpful.
    Gary
    '*  Name    : oscope clock 16F690 sawtooth generator
    '*  Author  : gmg        Copyright (c) 2010 (yeah, right...)
    '*  Date    : 7/28/2010
    '*  Notes   : generates sawtooth wave for CRT time base
    '            Horiz: 1.5v=10 div, Vert: 2.0v=8 div max on CRT
                passive low pass RC filter on PWM output RC.5
    @ __config _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _CP_OFF & _WDT_OFF
    ADCON1=$0F                    'disable A/D
    VRCON=0                       'volt ref off
    CM1CON0.0=0 : CM2CON0.0=0   	'comparators off
    ANSEL=0 : ANSELH=0
    OSCCON=%01110000              ;8MHz intosc
    DEFINE OSC 8
    '-------------- pins
    'PWM_out           var    portc.5
    TRISC=0:TRISB=0
    PORTC=0: PORTB=0
    '-------------- variables
    version		con	107
    i               var      byte
    j               var      byte
    temp            var      BYTE
    tempword        var      word
    duty_reg        var      word
    HLevel          var      byte
    VLevel          var      byte
    HOrigin         var      byte
    CLEAR
    read 0, temp
    if temp<>version then write 0, version	'store sw version in EEPROM 0
    '----  setup HPWM on PORTC.5
    hpwm 1, 0, 32000 		'32kHz PWMN out on PORTC.5
    '----- setup DT instant interrupt TMR1
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts  (cf. asm interrupts)
    INT_LIST  macro ;            IntSource,    Label,      Type,  ResetFlag?
                    INT_Handler   TMR1_INT,   ReloadTMR1,   ASM,  no    ; MUST be first
                    INT_Handler   TMR1_INT,   _T1handler,   PBP,  yes
        endm        .
    @Freq       = 6000                 ; interrupt frequency, 1.7msec period gives 600Hz screen sweep
    @Prescaler  = 1                   ; Timers Prescaler setting
    T1CON = $00                       ; $30 = Prescaler 1:8, TMR1 OFF   ; $00=1:1, $10=1:2, $20=1:4, $30=1:8 --  NB: T1CON Must match @Prescaler value
    @ INT_ENABLE  TMR1_INT            ; enable Timer 1 interrupts
    GOSUB StartTimer                  ; Start the Timer
    '-------   Main
    while 1=1		'loop forever
    wend
    ;____This routine is Called on each TMR1 Interrupt____________________________
    T1handler:
           ISR:
    duty_reg=duty_reg+1
    if duty_reg>140 then duty_reg=0       'increment duty_reg each interrupt for ramp function
    trisc.5=1
    CCP1CON.4=duty_reg.0                 '10bit PWM
    CCP1CON.5=duty_reg.1
    tempword=duty_reg & %1111111100
    CCPR1L=tempword>>2
    trisc.5=0
       HIGH PORTC.4    		'TEMP oscope timing pulse, retained to preserve timing
       PAUSEUS 10
       LOW PORTC.4
    @ INT_RETURN
    ;---[TMR1 reload - interrupt handler]-----------------------------------------
    ASM                               ; Calculate Timer Reload Constant
    ReloadInst  = 8                   ; # of Intructions used to reload timer
      if ((Prescaler == 1)||(Prescaler == 2)||(Prescaler == 4)||(Prescaler == 8))
    MaxCount    = 65536 + (ReloadInst / Prescaler)
    TimerReload = MaxCount - (OSC*1000000/4/Prescaler/Freq)
        if ((TimerReload < 0) || (TimerReload > (65535-ReloadInst)))
            error Invalid Timer Values - check"OSC", "Freq" and "Prescaler"
          error Invalid Prescaler
    @Timer1 = TMR1L                   ; map timer registers to a word variable
    Timer1       VAR WORD EXT
    TimerReload  CON EXT              ; Get the External Constant
    TMR1ON       VAR T1CON.0          ; Alias the Timers ON/OFF bit
    ;---Reload Timer1------
    ReloadTMR1
        MOVE?CT  0, T1CON, TMR1ON     ;  1     stop timer
        MOVLW    LOW(TimerReload)     ;  1     Add TimerReload to the
        ADDWF    TMR1L,F              ;  1     value in Timer1
        BTFSC    STATUS,C             ;  1/2
        INCF     TMR1H,F              ;  1
        MOVLW    HIGH(TimerReload)    ;  1
        ADDWF    TMR1H,F              ;  1
        MOVE?CT  1, T1CON, TMR1ON     ;  1     start timer
      INT_RETURN
    ;---Start/Stop controls -----
    StartTimer:
        Timer1  = TimerReload         ; Load Timer
        TMR1ON = 1                    ; start timer
    StopTimer:
        TMR1ON = 0                    ; stop timer
    Hi, Gmg
    You could use another Pic pin for "slamming" down the descending part of the signal : input when rising, ouput low when descending.
    may be also use a slamming buffer with a BS170 i.e. ... ( ~ 3 ohms Rds on )
    just an idea
    signal is pretty clean for a PWM filtered generator ...
    timmers's Avatar
    timmers Guest
    Why not do it in analogue?
    An RC circuit and a couple of digi-pots would do it. To get a linear ramp use a high-ish target voltage for the capacitor, say 10x the trip voltage (15v).
    For a CRT timebase it must be free of any harmonics.
    Alain,
    Interesting idea. Do you mean using another pin to sink the filtered output after reaching the maximum voltage? I'll have to try that to see how it sharpens the drop.
    Timmers,
    Because I know even less about analog circuits than digital ones. You know: "when the only tool you have is a hammer, everything looks like a nail."
    Quote Originally Posted by gmglickman View Post
    Alain,
    Exactly GmG ...
    even use a small mosfet to get a sharper edge ... ( BS170 or 2N7000 )
